RSS Bot Posted May 20, 2006 Share Posted May 20, 2006 I've got a preliminary graphic converter working in PHP. Right now I have to hard-code the URL for the image to convert, I plan to make it user-selectable at a later date. It's also forcing the leftmost pixel of each row to be "on" which can cause some alignment issues. I need to make it smart enough to "shift" the bits if needed when the rightmost pixel is blank. mm20060519PAL.binmm20060519NTSC.bin http://www.atariage.com/forums/index.php?a...&showentry=1574 Link to comment Share on other sites More sharing options...
