GT Turbo Posted May 26, 2006 Share Posted May 26, 2006 (edited) Orion_, has done a great progam called FalcXfer, it was written for files transfert between PC and Falcon with only a parallel wire. It run under XP and you can use it on normal Falcon or fast Falcon (Tried under CT63) Let's download an enjoy this great prog : FalcXfer GT Turbo (Jagware) Edited May 26, 2006 by GT Turbo Quote Link to comment Share on other sites More sharing options...
belboz Posted May 26, 2006 Share Posted May 26, 2006 Sounds cool. Any chance for TT support? Orion_, has done a great progam called FalcXfer, it was written for files transfert between PC and Falcon with only a parallel wire. It run under XP and you can use it on normal Falcon or fast Falcon (Tried under CT63) Let's download an enjoy this great prog : FalcXfer GT Turbo (Jagware) Quote Link to comment Share on other sites More sharing options...
Orion_ Posted May 26, 2006 Share Posted May 26, 2006 If the TT has the Yamaha sound chip like ST or Falcon at the same address, then it should work Quote Link to comment Share on other sites More sharing options...
belboz Posted May 26, 2006 Share Posted May 26, 2006 I believe it does, I will try to give it a test. Have to see what I have cable wise. I know I have a 25 to 25 pin cable that was used for PC Anywhere (old version) on the pc for remote control and file copy over the parallel ports. Will see if that cable is the same as you spec out in your documentation. If the TT has the Yamaha sound chip like ST or Falcon at the same address, then it should work Quote Link to comment Share on other sites More sharing options...
GT Turbo Posted May 26, 2006 Author Share Posted May 26, 2006 (edited) Has Orion has said, normally it must works, without problems on this great machine GT Turbo (Jagware) Edited May 26, 2006 by GT Turbo Quote Link to comment Share on other sites More sharing options...
+remowilliams Posted May 26, 2006 Share Posted May 26, 2006 Very cool! I'll have to try this out with my Falcon and PCAnywhere parallel cable and see if it works. Floppy xfer is annoying! Quote Link to comment Share on other sites More sharing options...
GT Turbo Posted May 27, 2006 Author Share Posted May 27, 2006 (edited) A little modification, FalcXfer will be available here now GT Turbo (Jagware) Edited May 27, 2006 by GT Turbo Quote Link to comment Share on other sites More sharing options...
krupkaj Posted May 27, 2006 Share Posted May 27, 2006 (edited) nice, BTW do you know PARCP ? I am not sure how it woks under XP, but I have used it often back in the day I have not ethernet. Edited May 27, 2006 by krupkaj Quote Link to comment Share on other sites More sharing options...
