Adding a missile
Ok, I've followed Andrews great tutorials and am up to the point where I have a cool lil' guy running around the screen.
I am now attempting to add a "missile". I was reading the Stella programmers guide I gathered that to get a missile to display I just had to enable it with
lda #1
sta ENAM0
Then at the correct x position (which I just did after the xpositioning code of the player):
sta RESM1
I do that straight after the player positioning and I thought i would see a missile that was as tall as my screen a couple of pixels right of my player. But I saw nothing. Is there anything else I need to set?
Thanks!
Actually, I have another question for you (well I have thousands of questions, but I'll stick to the one on the top of the heap...)
I have 3 objects on screen now, and in the vertical blank time I do a WSYNC, then run the XPosition code for player 1, then another WSYNC then x positiong for player 2 and another WSYNC then Missile 1 postioning all using the "Battlezone variant"
That works lovely. but the Y positioning - how do I fit in all the ypositioning code for all the objects into a scanline? I am using the "skipdraw" method (i think!) like so:
	sec
tya
sbc SpriteEnd
adc #SpriteHeight
bcs .MBDraw3
nop; Make y drawing always
nop; use same amount of cycles
sec
bcs .skipMBDraw3
.MBDraw3
lda (SpriteTablePtr),y
sta GRP0
sta GRP1
.skipMBDraw3
Do I just run exactly the same code for each object on screen? Is there a standard method to achieve the vertical positioning checks?
Darrell's my name, SpiceWare's my alias. I've been doing software under SpiceWare name since the early 80s. here's an example of my logo from 88.
It's all tradeoffs when programming the Atari as there's a limited amount of time to do everything you have to do. In Medieval Mayhem I'm controlling 5 objects, the playfield, changing the playfield color and reading the paddles. There's no way I could do that on every scanline so I'm using a 2-line-kernel where most things are updated every other scanline(the playfield has to be updated every scanline).
One of the tricks I'm using is my sprites are limited in the Y range they can be drawn at, so I've chosen to pad the graphics with 0s:
TopShieldFacingDown
.byte zz________
.byte zz__XXXX__
.byte zz_XXXXXX_
.byte zzXXXXXXXX
.byte zzXXXXXXXX
.byte zzXX____XX
.byte zzX______X
.byte zz________
.byte 0,0,0,0,0,0,0,0; 2 brick rows
TopShieldFacingSideways
.byte zz________
.byte zzXXXXX___
.byte zz_XXXXX__
.byte zz__XXXXX_
.byte zz__XXXXX_
.byte zz__XXXXX_
.byte zz_XXXXX__
.byte zzXXXXX___
TopShieldFacingDiagonal
.byte zz___XXX__
.byte zz__XXXXX_
.byte zz_XXXXXXX
.byte zzXXXXXXXX
.byte zz___XXXXX
.byte zz____XXX_
.byte zz____XX__
.byte zz____X___
TopShieldDead
.byte 0,0,0,0,0,0,0,0; for "dead" shape
and just draw the shields on every line w/out using any skipdraw logic
lda (P1Shield),y
sta GRP0
lda (P3Shield),y
sta GRP1
It's different in that it's faster during the display kernel. I had too many things to display and could not spare SkipDraw's 17-18 cycles per player. The method I use only takes 8 cycles per player.
Outside of the kernel I have to add zeros to either side of the sprite image(taking up extra ROM space) and adjust the pointer to the sprite (the value in P1Shield) up/down based on the Y value.
Is that the kind of technique they would have used to make a frogger style game? I was thinking of doing something like this as a project to bring together all the stuff I've been reading here - I've got it kinda working, but I've just been ignoring all the line-changes that the sprites do mid-frame :)
What would be the best way to store multiple sprites on fixed y coordinates a-la frogger?
