RSS Bot Posted June 1, 2006 Share Posted June 1, 2006 B-52's in the background Due to popular request, I've added routines for brick flash and king flash. I'm going to have to revamp the main menu to add a flash control option, with values of None, Brick, King and Both. I don't want to make the letters smaller, so I'm thinking about making the list scroll up/down to show all the options. The 2 options are currently turned on until I redo the menu. There is a quirk with the king flash - if another sound effect starts on the same channel(left/right), the flashing will stop prematurely. My sound routines don't have a priority, guess I'll need to change that. I also fixed that problem I found where your king could be killed if 2 fireballs hit one of your castle bricks at the exact same time. mm20060531PAL.binMedieval_Mayhem.zipmm20060531NTSC.bin http://www.atariage.com/forums/index.php?a...&showentry=1601 Link to comment Share on other sites More sharing options...
