Adventure_Knight Posted June 27, 2006 Share Posted June 27, 2006 I used the Create You Own Adventure tool to make an Adventure hack, but when I finished, and I try to run DASM, the program won't run! Someone can help me? Quote Link to comment Share on other sites More sharing options...
atwwong Posted June 29, 2006 Share Posted June 29, 2006 Welcome to the forums. Under File in the CYOA toolbar, choose Create Source and Binary Files, then create a source file. This file will compile using DASM. If you need details on how to compile source files, read the DASM readme text file. Here's the syntax: dasm filename.asm -f3 -ofilename.bin where filename is your source file (can be filename.txt). DASM compiles your source and outputs it as a binary file. Note that you need to run DASM as a command line, and not just click on it, if you are using Windows. You can make a batch file using the sample syntax (in this example, the source filename would be cyoa.txt, and the output created would be cyoa.bin). If you are just playing with new rooms/mazes, you can use CYOA's Create Binary feature. However, DASM is very useful for compiling the source file if you make changes with your favourite text editor . Cheers, Tony Quote Link to comment Share on other sites More sharing options...
