RSS Bot Posted July 15, 2006 Share Posted July 15, 2006 Here's my mode file for jEdit for batari BASIC: batari_BASIC.xml.zip To use the syntax highlighting, put the batari BASIC.xml file in the MODES directory of jEdit. Then edit the catalog file in the same directory and add the following. CODE<MODE NAME="batari BASIC" FILE="batari BASIC.xml" FILE_NAME_GLOB="*.bas" /> I disable the vbscript mode file as it also uses *.bas for the file extension. I disabled it by changing its entry in the catalog file as follows CODE<!-- MODE NAME="vbscript" FILE="vbscript.xml" FILE_NAME_GLOB="*.{vbs,bas,cls}" /--> http://www.atariage.com/forums/index.php?a...;showentry=1728 Link to comment Share on other sites More sharing options...
