Slickus Posted July 17, 2006 Share Posted July 17, 2006 A question for all of those forum members that have successfully modded their flashback 2’s. I just finished trying to install a cartridge port on my flashback and all I get when I insert a cartridge is random noise and random screen video (interestingly the noise and random video change each time the console is turned on with a cart inserted). The carts I’ve used to test are Asteroids, Pitfall, and Ms. Pacman. I’ve checked all of my connections to the cart port with a multi-meter for continuity and they seem to check out ok. The original games still work when I use the DPDT switch. I though I might have wired the cart port backwards, so I reversed it – but still no dice. Here’s an annotated picture of the cart port and the way I soldered the leads. Any ideas as to what I might be doing wrong here? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Slickus Posted July 17, 2006 Author Share Posted July 17, 2006 Also, any forum members have recommendations for a good solder? I'm using Radio Shack silver solder and it doesn't seem to flow/adhere very well using a temp controlled soldering station set to 350 C. I tired of dealing with RS's inconsistent solder. I was thinking of getting some Kester 62/36/2, but then I found a site selling Cardas solder (tin, lead, silver, copper eutectic. 61/35/3/1) for less. I've heard good things about Cardas solder especially that its very easy to work with, but I'm wary of the whole audiophile snake-oil phenom. Thanks. Quote Link to comment Share on other sites More sharing options...
garf512 Posted July 22, 2006 Share Posted July 22, 2006 I had the same result with a failed FB2 mod. I backed out all my changes and got the same results when I powered up the unit. I figured that heat from the soldering iron nuked the chip and shelved the unit. Quote Link to comment Share on other sites More sharing options...
+batari Posted July 22, 2006 Share Posted July 22, 2006 Also, any forum members have recommendations for a good solder? I'm using Radio Shack silver solder and it doesn't seem to flow/adhere very well using a temp controlled soldering station set to 350 C. I tired of dealing with RS's inconsistent solder. I was thinking of getting some Kester 62/36/2, but then I found a site selling Cardas solder (tin, lead, silver, copper eutectic. 61/35/3/1) for less. I've heard good things about Cardas solder especially that its very easy to work with, but I'm wary of the whole audiophile snake-oil phenom. Thanks. I checked my FB2, and your connections are correct. Quote Link to comment Share on other sites More sharing options...
Kokovec Posted July 23, 2006 Share Posted July 23, 2006 (edited) You might want to check for shorts between your wires. I had a similar issue with one of the FB2's I modded and it turned out to be a short. I also use RS solder. I find that it works just fine. Just wait until lead-free soldering is mandated here in the US. That's when it will get a little tougher to mod a board. Edited July 23, 2006 by Kokovec Quote Link to comment Share on other sites More sharing options...
mmocha Posted September 4, 2006 Share Posted September 4, 2006 (edited) Sounds like a solder pad is bridged or the connections are wrong. You'll just have to trouble shoot the circuit. Edited September 4, 2006 by mmocha Quote Link to comment Share on other sites More sharing options...
