Paul Slocum Posted January 10, 2002 Share Posted January 10, 2002 My ST has a special board with a 80286 chip installed so it can emulate a PC. The add on is called AT-SPEED. I've been able to boot a DOS 3.3 disk on it. Anyone know much about this? Is this a common modification? Also, if I wanted to add a hard drive, what's the cheapest way? -Paul Quote Link to comment Share on other sites More sharing options...
Goochman Posted January 11, 2002 Share Posted January 11, 2002 I had an AT-Speed board in my Mega 2. It worked ok. Graphic apps were slow and I believe Hercules mono was supported(and CGA)??? Text apps worked pretty good. I used Work Perfect 5.1 for DOS on it at the time and was happy with it. I also used a Desktop Publisher program but it was slowwwwwwwwwwww If you ahve text apps you want to run that are 286 compat it will do the trick! Quote Link to comment Share on other sites More sharing options...
