t.skid Posted January 26, 2002 Share Posted January 26, 2002 I've to connect a Falcon to a VGA monitor. Apart buy it, there is someone that have the schematics to build? If it's possible to do it... Quote Link to comment Share on other sites More sharing options...
Eckhard Stolberg Posted January 27, 2002 Share Posted January 27, 2002 I don't have a Falcon or know how build a VGA adapter, but I have a magazine with a Falcon test, that says that the Falcon is supposed to come with an adapter for connecting it to VGA monitors. So it should be possible. Also the magazine described the monitor connector on the Falcon. Maybe this helps you a bit to figure out the connection yourself. The connector is a male DB19. The top row of pins is numbered 10 to 1 and the bottom row is numbered 11 to 19. The pins are: 01 Red 02 Green 03 Blue 04 Mono/Overlay 05 GND 06 Red GND 07 Green GND 08 Blue GND 09 Audio Out 10 GND 11 GND 12 Composite Sync/V 13 Horizontal Sync 14 Vertical Sync 15 External Clock Inp 16 External Sync Er 17 +12V 18 M1 19 M0 Ciao, Eckhard Stolberg Quote Link to comment Share on other sites More sharing options...
t.skid Posted January 28, 2002 Author Share Posted January 28, 2002 Thanks Eckhard, now I will work on it. If I get some results, I post it here!! Quote Link to comment Share on other sites More sharing options...
Clint Thompson Posted February 4, 2002 Share Posted February 4, 2002 Do you have an RGB Monitor? (the SC1224 or the other one?) If so I would prolly just stick with that unless you have a game that requires VGA? From what I remember, using VGA on my Falcon was slooooow. The adaptor itself I remember took me by $30! Good luck on building that adaptor! Clint Quote Link to comment Share on other sites More sharing options...
Gaiyan Posted February 5, 2002 Share Posted February 5, 2002 There's really no difference in speed between VGA and RGB if you compare the same resolutions. The fact that VGA will run on a higher resolution taxes the performance of the system. When my stock Falcon ran at 800x608 in 256 colors, it was very slow. RGB is awesome for games and VGA is more for serious stuff. Joshua. Quote Link to comment Share on other sites More sharing options...
Gaiyan Posted February 5, 2002 Share Posted February 5, 2002 I never did a VGA adapter but I was succesful in making an RGB adapter for my Commodore monitor. One thing to remember is how you connect the M0 and M1 lines. The combination of them tells the Falcon what monitor you're using. If you manage to wire the monitor wires correctly but don't ground the 'sense' lines (M0 M1) properly, it just won't work. I'll look around for info on it and post it here. Joshua. [ 02-05-2002: Message edited by: Lord Gaiyan ] Quote Link to comment Share on other sites More sharing options...
t.skid Posted February 5, 2002 Author Share Posted February 5, 2002 Thanks Joshua, let us know. BTW, I've abandoned the idea to build a vga adapter, and orderer it.... Quote Link to comment Share on other sites More sharing options...
ROOP Posted August 15, 2002 Share Posted August 15, 2002 I HAVE A VGA ADAPTOR FOR THE FALCON IM IN THE UK £20 P+P FREE Quote Link to comment Share on other sites More sharing options...
