Paranoid Posted September 10, 2006 Share Posted September 10, 2006 I'm using a ATR image of MyDOS 5.53/4.... I've created a 16mb .atr image using APE. My goal is to copy a bunch of .xex files to the 16mb ATR image file. So, I use O to attach the 16mb drive and then I to initalize it and H to write DOS files to the disk. It works, I now have a 16mb .atr image that will work as D1: I use ALT-H to map a virtual hard drive as H1: to the physical path C:\temp\atari\executables Where my xex files reside. I do a directory A H1:*.* And it lists the xex files on my physical hard drive. I try to COPY the files C H1:*.*,D1: And I get an error -- 170 But I can copy an individual file for example C H1:BATLZNE.XEX,D1:BATLZNE.XEX Although C H1:BATLZNE.XEX,D1: Will fail. I have to type in the destination file name Any ideas what I'm doing wrong here? Quote Link to comment Share on other sites More sharing options...
Paranoid Posted September 12, 2006 Author Share Posted September 12, 2006 If anyone is interested, my finally analysis is that the Atari800Win PLus implementation of "H: drives" is flawed and unreliable. I found a work around, I'll post more later. Quote Link to comment Share on other sites More sharing options...
iratanam Posted September 12, 2006 Share Posted September 12, 2006 If anyone is interested, my finally analysis is that the Atari800Win PLus implementation of "H: drives" is flawed and unreliable. I found a work around, I'll post more later. Yea please do, I'm interested, I haven't tried the H: Drive through Atari800Win+ yet so I'll be interested to know how your luck turns out. Quote Link to comment Share on other sites More sharing options...
Paranoid Posted September 13, 2006 Author Share Posted September 13, 2006 http://www.atariage.com/forums/index.php?s...t&p=1137362 Iratanam... on the workaround: The same disk image that I create for the MyIDE cartridge can be used in emulation to make xex files on a PC accessible in emulation without using the H: Patch. In the document, this is the step titled "Creating a Hard Drive Image File". You can use MakeATR or APE to perform this action. Quote Link to comment Share on other sites More sharing options...
