GAME_FREAK Posted June 11, 2002 Share Posted June 11, 2002 hey everyone! i just purchased an atari 2600 from a thrift store with 2 games. here is my problem when i connect the cord to the video in connector on my tv and turn on the atari nothing happens. so i decided to use a nintendo cable adapter (where there is a little box that you put the TV cable into and the game plug) but when i turn it on now it just makes the screen really blurry and have lines all across it. if you can help me make it work please do Quote Link to comment Share on other sites More sharing options...
Malix Posted June 11, 2002 Share Posted June 11, 2002 Sounds like you need a new switch box. Go to Radio Shack and buy one. They are black and silver. The nintendo ones will not work. I am sure someone else here can give you the exact numbers on the box. Quote Link to comment Share on other sites More sharing options...
lonesome_pa Posted June 11, 2002 Share Posted June 11, 2002 Any video game switch will work as long as they are a manual one. Automatic ones will not work as the 2600 doesn't produce enough power to switch the box over itself. Or, for better picture quality, you can use an RCA to Coaxle connector (also at Radio Shack) for about $2.49. I use that with an A/B switch and the sound and picture are extremely better. Quote Link to comment Share on other sites More sharing options...
GAME_FREAK Posted June 11, 2002 Author Share Posted June 11, 2002 if i dont have a controller plugged in would that affect anyhting? because i purchased it and i couldnt find a controller at the thrift store Quote Link to comment Share on other sites More sharing options...
lonesome_pa Posted June 11, 2002 Share Posted June 11, 2002 No. The system should still power up and display the game. Obviously, you just can't do anything. Quote Link to comment Share on other sites More sharing options...
Room 34 Posted June 11, 2002 Share Posted June 11, 2002 if i dont have a controller plugged in would that affect anyhting? because i purchased it and i couldnt find a controller at the thrift store Like lonesome_pa said, the controller doesn't matter. It's all about the RF switchbox. Do you have one yet? The RCA cable that comes out of the back of the Atari 2600 has to go into an RF switchbox. It's a composite signal with both the video and audio on it, and if you plug it into one of the RCA jacks on a modern TV, you won't get anything. Also be sure the TV is on the right channel. The back of the Atari has a switch to set either channel 2 or 3 as the active channel for the Atari. Make sure that and the TV are on the same channel, and that the RF switchbox is set to "Game" or "Computer" and not to "TV". Quote Link to comment Share on other sites More sharing options...
GAME_FREAK Posted June 11, 2002 Author Share Posted June 11, 2002 thanks... its still not working so i guess it must be a defective system, after all it cost me 1$ Quote Link to comment Share on other sites More sharing options...
mvigor Posted June 11, 2002 Share Posted June 11, 2002 the 2600 doesn't produce enough power to switch the box over itself. That makes me wonder how difficult a hack it would be to bump up the power and MAKE the automatic switch thing work. Has anyone tried this? -Matt Quote Link to comment Share on other sites More sharing options...
Chris++ Posted June 11, 2002 Share Posted June 11, 2002 Game Freak: 1. Buy a switchbox at Radio Shack that has a little slider in the middle, allowing you to select either TV or GAME. The latter option might say COMPUTER instead. You get the idea. This switchbox has to be the kind with a co-ax plug hanging out of it. Tell the clerk to show you. Avoid buying the kind of switchbox with two prongs hanging out of it instead, to save you an extra step and possible reception headaches. 2. There should, therefore, be a thick little cord sticking out of one side of the switchbox; at the end of this cord, there should be a co-ax plug. It's the kind of plug that looks like a standard metal nut, except it has a very thin little pin sticking out of its middle, and the "nut" revolves, allowing you to screw the plug into a co-ax jack. Makes sense, right? So screw this co-ax plug into the big jack on the back of your TV. 3. If the back of your TV doesn't have a co-ax jack, then this plug will fit into the back of your VCR instead (assuming you have one). Set the VCR up so that it works. You get a picture. Say, the Channel 7 news comes in through your VCR. Now, put the VCR on channel 3. Screw the switchbox's co-ax plug into the jack on the back of your VCR that says IN FROM ANTENNA. Make sure your 2600's Channel 3/4 switch is on Channel 3. Turn the 2600 on. If you only get a fuzzy picture, then the 2600's Channel switch is on 4, so move it to its other position. If you're STILL not getting a good picture, turn off the VCR (I'm serious!) and see if it gets better. 4. Remember that the Channel 3/4 switch on the back of your Atari, AND the channel on the TV (or VCR), have to match up. Otherwise, the picture will be very fuzzy and distorted. Also remember to test more than one cartridge, to make sure that's not the problem. Finally, make sure the power supply is 9-volt. CF Quote Link to comment Share on other sites More sharing options...
Bez Posted June 11, 2002 Share Posted June 11, 2002 Game Freak, You need a MANUAL switchbox for to connect the TV with your Atari. The Nintendo one is automatic and won´t work with the VCS. Good luck! I´m sure it willl work out just fine. /Bez Quote Link to comment Share on other sites More sharing options...
GAME_FREAK Posted June 12, 2002 Author Share Posted June 12, 2002 thanks everyone it works great.... now i just hav to find a controller Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted June 12, 2002 Share Posted June 12, 2002 Sega Genesis controllers work, if you don't mind mixing the old with the new (at least until you can find an authentic CX40). Quote Link to comment Share on other sites More sharing options...
