Stupid question I probably shouldn't be asking...
Dragnerok X
By the way, if you ever have a long series of ifs that contain similar ands or ors (&& or ||), you can almost always simplify (and optimize) them by taking out the similar portions and making them separate ifs, and have it jump over the other ifs if the condition isn't met (e.g., all of your original ifs had "if t = 1," so use "if t <> 1" to jump over the other ifs). And once you start simplifying in these ways, you can generally end up with something even simpler-- the way you can take a very complicated equation, start to simplify it in different ways, with each simplification giving rise to further possible simplifications, until you end up with something that looks much simpler than the original and yet says exactly the same thing!
Michael
Statements with || are handled quite inefficiently, so this is indeed true for them. The next release of bB should handle these more efficiently.
Statements with &&, however, are fairly efficient and recoding may or may not save any space. If it does save space it will likely just be a few bytes.
  if t = 1 && a = 1 && e = 0 then v = 1
  if t = 1 && a = 2 && e = 0 then v = 2
  if t = 1 && a = 3 && e = 0 then v = 3
  if t = 1 && a = 4 && e = 0 then v = 4
  if t = 1 && a = 5 && e = 0 then v = 5
  if t = 1 && a = 6 && e = 0 then v = 6
  if t = 1 && a = 7 && e = 0 then v = 7
  if t = 1 && a = 8 && e = 0 then v = 8
  if t = 1 && a = 9 && e = 0 then v = 9
  if t = 1 && a = 10 && e = 0 then v = 10
  if t = 1 && a = 11 && e = 0 then v = 11
  if t = 1 && a = 12 && e = 0 then v = 12
  if t = 1 && a = 13 && e = 0 then v = 13
  if t = 1 && a = 14 && e = 0 then v = 14
  if t = 1 && a = 15 && e = 0 then v = 15
  if t = 1 && a = 16 && e = 0 then v = 16
  if t = 1 && a = 1 && e = 1 then v = 9
  if t = 1 && a = 2 && e = 1 then v = 10
  if t = 1 && a = 3 && e = 1 then v = 11
  if t = 1 && a = 4 && e = 1 then v = 12
  if t = 1 && a = 5 && e = 1 then v = 13
  if t = 1 && a = 6 && e = 1 then v = 14
  if t = 1 && a = 7 && e = 1 then v = 15
  if t = 1 && a = 8 && e = 1 then v = 16
  if t = 1 && a = 9 && e = 1 then v = 1
  if t = 1 && a = 10 && e = 1 then v = 2
  if t = 1 && a = 11 && e = 1 then v = 3
  if t = 1 && a = 12 && e = 1 then v = 4
  if t = 1 && a = 13 && e = 1 then v = 5
  if t = 1 && a = 14 && e = 1 then v = 6
  if t = 1 && a = 15 && e = 1 then v = 7
  if t = 1 && a = 16 && e = 1 then v = 8
Yikes.
 if t<>1  then goto skip_te
 if e>1 then goto skip_te
 a=a-1
 if a > 15 then goto skip_te_inc
 v=a
 if e-1 then v=v ^ 8
 v=v+1
skip_te_inc:
 a=a+1
skip_te:
Yikes.
What's even scarrier about it is that when I started I was 100 bytes in the negative, now I have 1200 bytes to spare! ;)
Edited by Dragnerok X
You can save a few more by changing lines like these:
  b = b + 1
  if b = 16 then b = b - 16
  c = c + 1
  if c = 7 then c = c - 7
  d = d + 1
  if d = 2 then d = d - 2
to lines like these:
  b = b + 1
  if b = 16 then b = 0
  c = c + 1
  if c = 7 then c = 0
  d = d + 1
  if d = 2 then d = 0
I made those changes, plus some others, and now there's 938 bytes free in bank 1, and 1313 bytes free in bank 2.
Michael
combat_DX.bas
Combat_DX.bas.bin
Edited by SeaGtGruff
  b = b + 1
  c = c + 1
  d = d + 1
or...
 b = b & 15
 b = b + 1
 c = c + 1
 if c = 7 then c = 0
 d = d ^ 1
Shouldn't that be
  b = b + 1
  b = b & 15
And the d thing I don't understand. Anything to the power of 1 is itself, so d won't change-- or isn't the caret used for exponentiation in bB? Shouldn't it be
  d = d + 1
  d = d & 1
Michael
The caret is used for exclusive OR. bB doesn't support exponentiation, and I personally can't see any need for it in the language. I know that other Basics use it for exponentiation, But C uses the caret, and I had already settled on &&, ||, & and | just like C uses for its other operators.
The reason I used C-style operators in the first place is that they are much easier to parse than keywords like AND, OR and XOR, and AFAIK, most classic Basics that I've used don't even have bitwise operators.
Ah ha! I knew it it isn't Basic at all is it! It's compiled, it uses C operators.... hmmmm. I think you'd better change your name to Catari. :D
I'm pretty sure Commodore computers implemented those as bitwise operators. I'll powerup the old VIC tonight to confirm it.
Maybe batari BasiC would be more appropriate...
You could be right about CBM Basic, but I am pretty sure that Apple II Basic interpreted them as logical operators even in an assignment, i.e. A=(1 AND 2) should make A=1, not A=0. Edited by batari
  b = b + 1
  c = c + 1
  d = d + 1
  b = b + 1
  c = c + 1
  if c = 7 then c = 0
  d = d + 1
  if d = 2 then d = 0
Michael
Thank's for the optimization! It's MORE (*cough* *cough* ;)) than enough. Now, on to tank destruction, I suppose. Any suggestions? (perhaps on a way I could randomly position a "dead" player back on the map)
Cool, I did not know that. I just checked Applesoft Basic and it is not.
What about Integer Basic?
Same as Applesoft.
I used online emulator http://www.virtualapple.org/integerhirescardgamesdisk.html Starts in applesoft but could type INT to get into integer basic loaded into the language card. Type FP to go back to Applesoft.
Edited by djmips
Same as Applesoft.
I'm surprised at that. Especially in integer basic, doing the arithmetic in binary wouldn't be any harder than forcing boolean logic, though maybe people hadn't figured out the value of making "true" be -1. And I guess the use of addressible latches ("soft switches") rather than parallel latches mitigates the lack of binary operators. Even so, though, many things are a real pain without the boolean operators.
Does Integer Basic provide a function to read lores pixels? If not, I wonder how Little Brick Out works.
Do these forums have a branching function, wouldn't it be cool if a subtopic like this could be more or less automatically branched into a separate forum? :ponder:
:) But anyways I doubt there was a function to read pixels or even one to write them. It would have come down to peeks and pokes I'm sure.
EDIT -> ...Was curious and I checked the Integer Basic Spec and I was wrong. For Lo-Res graphics a precursor of the commands in Applesoft were included
GR Sets lores graphics mode and clears screen
COLOR=x Sets lores drawing color to x
PLOT x,y Draws a dot at location x,y
HLIN x1,x2 at y Draws a horizontal line from x1,y to x2,y
VLIN y1,y2 at x Draws a vertical line from x,y1 to x,y2
SCRN(x,y) The color of the dot at location x,y.
http://www.landsnail.com/a2ref2.htm
Edited by djmips
Okay, so scrn() would have avoided the need to use bitwise logic when doing a lo-res game like Little Brick Out. Still, I think the Commodore's machines deserve credit for allowing AND/OR to be used with integers. Back in the day my code was sometimes bloated because I hadn't realized that "X=(X and 127) or X=((not X) and 128)" could be greatly simplified as "X=(X+128) and 255" (note that CBM BASIC didn't have XOR). In any case, any of that's better than X=X+128-256*(X>=128).
  • 3 weeks later...
Well, after much procrastinating (as you can plainly tell) I finally got my act together and started working on this game. I've got my basic "explosion then random" idea out, but, as always, it's buggier than hell.
Here's what I've noticed.
1. After ~3 shots per player, the game crashes.
2. When a player is being blown up, the other player's movement goes crazy.
3. The "random" positioning is far from random. My guess is that it's because the "random" formula is working in a pattern and when it crashes, the pattern is reset.
4. I'm trying to have the exploded players color-cycle, but for some reason it isn't working.
Still though, I think I pulled off a pretty sweet explosion sprite here. :cool:
( I took it from missile command and added a few frames )
Combat_DX.bas
Combat_DX.bas.bin
A little bit more work and here's where I am.
3. The "random" positioning is far from random. My guess is that it's because the "random" formula is working in a pattern and when it crashes, the pattern is reset. (didn't work, not sure, now)
As you can see, I've changed the kill "loops" to subroutines thus allowing me to access the code in it's entirety and fixing both the first and second bugs. The fourth I've also fixed by tying the player colors to their "animation" variable (either x or y). It looks good, but I still would like your opinion whether I should switch to it. So, which one? :ponder:
NEW:
Combat_DX_Flash.bin
OLD:
Combat_DX_White.bas.bin
Still, I am still stuck with how I could get this to randomize properly (it seems all the random values are too high), so any suggestions would be appreciated. This is an open boat I'm on, don't be afraid to share your comments! Well, at least of course, if you want it to turn out right.
