dinosaurjr Posted December 30, 2006 Share Posted December 30, 2006 If you are playing one game, can you change to another game without having to turn the Flashback 2 off and then on? Thanks in advance! Quote Link to comment Share on other sites More sharing options...
Retro Rogue Posted December 30, 2006 Share Posted December 30, 2006 If you are playing one game, can you change to another game without having to turn the Flashback 2 off and then on? Thanks in advance! No. The FB2 is an actual Atari 2600 inside, and as with the original Atari 2600 you need to turn it off to "switch cartridges". Even though the games are built in to this one, they are still stored physically seperately from the actual "2600 brain" and function just like inserting a cartridge. Quote Link to comment Share on other sites More sharing options...
Feralstorm Posted December 31, 2006 Share Posted December 31, 2006 I sometimes wondered if it wouldn't have been a bad idea to include a system reset button, even if all it really does is momentarily interrupt the power circuit. I'd imagine from the Manufacturing POV, it's cheaper to make someone hit a power button twice, instead of adding a new button that you only hit once. Quote Link to comment Share on other sites More sharing options...
dinosaurjr Posted December 31, 2006 Author Share Posted December 31, 2006 No. The FB2 is an actual Atari 2600 inside, and as with the original Atari 2600 you need to turn it off to "switch cartridges". Even though the games are built in to this one, they are still stored physically seperately from the actual "2600 brain" and function just like inserting a cartridge. Thanks! Quote Link to comment Share on other sites More sharing options...
supercat Posted December 31, 2006 Share Posted December 31, 2006 No. The FB2 is an actual Atari 2600 inside, and as with the original Atari 2600 you need to turn it off to "switch cartridges". I don't think there would have been any particular difficulty in designing the FB2 to allow switching games without power-cycling. I believe there's even a connection inside which, if shorted to ground, will perform that function. The biggest reason I think there wasn't a button for that is simply that an extra button would have cost more money. A button combination like select+reset might have been fine as a means of exiting some games, but would cause problems on other games where both must be pushed simultaneously. Quote Link to comment Share on other sites More sharing options...
Retro Rogue Posted December 31, 2006 Share Posted December 31, 2006 No. The FB2 is an actual Atari 2600 inside, and as with the original Atari 2600 you need to turn it off to "switch cartridges". I don't think there would have been any particular difficulty in designing the FB2 to allow switching games without power-cycling. I believe there's even a connection inside which, if shorted to ground, will perform that function. I did not imply there was a difficulty in doing that or give an explination as to why that was done (I believe Curt's already done that in previous threads). Simply stating that because it is an exact reproduction designed to function as an actual 2600, you need to switch it off to "switch cartridges" the same as the original 2600. Quote Link to comment Share on other sites More sharing options...
policelimit Posted January 18, 2007 Share Posted January 18, 2007 Yup the FB2 purposefully operates as the original 2600 did, with no added "improvements." To do so would create the need to alter the orginal hardware specs and great care was taken NOT to do that. After the wholel FB1 fiasco, Atari learned it's lesson in what classic gamers really want in retro systems. Hats off to Curt. Quote Link to comment Share on other sites More sharing options...
