    43
    36
    65,552
Use a better text editor when programming.
frankodragon
Nothing is more frustrating when you're making a game and you have to "find" the error when the compiler gives an "error" message. I used notepad to write code and now I wish I knew about other text editors which have number lines as references. So I downloaded an application called Notepad ++ which is free and has reference line numbers.
I had errors caused by misspelling, forgetting to add a "rem" to a line or even forgetting to add a colon. Using original notepad was a pain because trying to search for the error through a thousand lines of code was usually looking for a needle in a haystack.
Then using Notepad ++ was so much easier finding the error in a line of code. When compiling in 7800 Basic, you may get an error like this:
First look in the Command Prompt for the error. It will be a number in parenthesis followed by an "ERROR"
The error I made (which I put in there on purpose) was in line 1708; I forgot to add a remark.
If you're still using a text editor without reference numbers, do yourself a favor and get one that does. It will save you a headache.
3 Comments
I've been using Notepad++ since March of 2014. I love the built-in spell checker that works like the Firefox spell checker. I also love how you can use it to search text files for a word or phrase. It has more than that to love about it, but those are my two favorite things.
Ctrl-G in the original Notepad will go to a line number. You can also turn on the status line which will show the line & character numbers. (Note: these features don't work if you have word wrap enabled.)
FYI - as part of my jEdit project I plan to create some mode files for Atari 7800 assembly and 7800basic.
Basically you'll get
  • colorized keywords
  • ability to clearly see graphics within binary data
  • compile from jEdit
  • launch your emulator from jEdit
You can see examples of how that works over in this topic of the 2600 programming forum.
