In case you don't follow my GoSub project for Intellivision, I attempted to make a level selection screen using the second controller. I could have just as easily made it for the first controller, but it's supposed to be somewhat hidden in case you don't read the AtariAge website where I post all the info. Anyway, I spent a couple of hours trying to make it so when you press a number it goes to the other number. To aide me, I put the numbers on the screen so I would know if it was working or not. But I finally got it working after a lot of attempts. And then I took the numbers off the screen. There are two digits: firstdigit and seconddigit. Since there are going to be 30 levels in the game, in case you type in 31 or higher, it goes to the level 1. But if you press, say, 30, it would go to the last level. I am going to put in a special code for those who don't use the level select code and start at the beginning. You'd only be able to see the best ending if you were to play through all 30 levels. And tomorrow I'll be able to test this on real hardware to see if it works on an actual Intellivision if the package comes when it's supposed to. I'm really excited about that. If it all goes well, I'll post a YouTube video of the first part of the game. Which reminds me, I'm right in the middle of uploading an episode of "As the World Turns." part by part.
entries
4,955 -
comments
2,719 -
views
1,809,700
Recently Browsing 0 members
