More bacon
I decided to work on I Like Bacon for the Odyssey 2 some more. This took a few tries to get correct. Saving my work whenever something gets right so I have a good starting point in case I mess up is essential. I made the elevators only go up when you get on them. When I was finished with that, I decided to let the user decide whether to go up or down instead of it going up and down by itself. I discovered a weird bug that I think I got when you go up and get off the ledge, a few seconds later the elevator went back down again. I have decided to not do jumping since the elevators are there. If an enemy is in your way, you can just go on the elevator and go above or below it. I have also decided what to do with the sprites. Sprite 0 will be the enemy, sprite 2 the guy to guide, and sprite 3 will be the bacon. I don't know about sprite 1 yet. I have decided to make sprite 2 be multicolored and put in a character for the shirt or something like that. I have to be careful it doesn't touch the guy because all characters use the same collision code, and the elevators are 4 characters. This means I have 8 left, and four groups of four, two of which will make up the score. So anyway, I've been plugging away on this. It's sad though that Plumber and Boney McBones didn't ever get published. Hopefully I Like Bacon will.
