    41
    373
    63,961
Eine kleine mazemusik
batari
With sid2tia, even folks like me can add a little tune to a game! Thanks to Manuel for making it. The hardest part was listening to several hundred SID tunes, trying to find ones I liked.
Once I selected a few dozen candidates, I ran sid2tia on each, trying various settings to make just the right sound. Conversion didn't always go well. The TIA is so finicky, 90% of the tunes were totally off-key or otherwise sounded awful (as many have weird effects that I couldn't remove using the settings.)
Then one stood out above the rest - a catchy tune, basically on-key, and not terribly annoying (to me, at least.)
Other than music, there's now a title screen with game selection, and I improved the bot AI. The AI was really hard to do, and it's why I haven't posted an update in a while.
Selections (1-6)
1 - stupid bot, normal maze
2 - stupid bot, braided maze
3 - average bot, normal maze
4 - average bot, braided maze
5 - smart bot, normal maze
6 - smart bot, braided maze
The smart bot can complete a maze in as little as 3 minutes.
When the bot is about the finish, the score will turn red. When the bot does finish, the score turns a salmon color.
There's still more work to do.
10 Comments
Hehe, cool!
I bet most real musicians will scream bloody murder when hearing this, but I think it sounds pretty '2600 authentic' and very video-gamish :ponder:
Did you try the patternized output, writing your own driver? Was it easy?
I just derived one from Crazy Balloon which does read data indirect Y indexed, in case the pattern bits don't fit into a page for both channels. (The CB driver is assuming all data is in a single page. And it could also run both channels a indepently from each other)
I noticed that in patternized output I forgot to add the "
Looks good; the tune is nice as well, though a little out-of-tune for my taste. Pretty good for the 2600, though. ;)
I also like the "tune" that plays while it is creating the maze; neat!
I was expecting something to happen when I beat the maze though - a little disappointing to get to the end and...nothing. :ponder:
I bet most real musicians will scream bloody murder when hearing this, but I think it sounds pretty '2600 authentic' and very video-gamish ;)
That's what I was thinking. The old games didn't have the funky beats that newer stuff (a la Paul Slocum) has. And I don't have the patience (or the skill) to make anything like that, especially since this game won't be sold... Or more accurately, I will allow anyone to sell this game royalty-free if they wish :ponder:
I noticed that in patternized output I forgot to add the "<" symbols in the pattern tables, but that's easy to fix with search and replace.
No, I just used the normal output, but I might try it later, as I did notice a lot of repeated data. The song takes up ~750 bytes, which is a good chunk of the upper 2k needed for the selection screen (and the code and data to self-modify the lower 4k of game code, to which more will be added in the form of game options.)
It's probably not in perfect tune, but my hearing ain't great, so it sounds acceptable to me... what?
That's what happens when you've got 8 bytes free... I need to do more optimizing to get that in. Chances are, the clock will stop, the screen will flash and maybe you'll get some simple sound.
Just had a thought...is the bot deterministic? Will it solve the same maze at the same speed every time?
Because, if so, it might be cool to stop the clock, flash the maze, freeze the player, and then, after about 5 seconds or so, show the (still-running) clock again until the bot reaches the end, then change the clock to show by how much you beat the bot. Assuming you beat the bot, that is. :ponder:
If you don't beat the bot, it could show how much you lost by.
Yup, the bot is deterministic. I can see the appeal of showing both times. I'll see how much ROM space I can dig up...
Nice Music. Hey, is there any possibility of making PF0 striped so that there isn't a blank vertical strip on the left and right. I find it disorienting.
Good work!
Rob
Me too, aso on the top and bottom of the maze. The frame should look different than the playfield area.
Changing COLUBK at the bottom of the maze is easy, but for the top, there's no margin in Stella. Is there one in z26?
Robert, is this what you meant by a striped PF0? See attachment:
http://www.atariage.com/forums/index.php?a...q=attach&id=997
P.S. I also shrunk the vertical size by two scanlines per block, making it look more square and giving more rows on the visible screen.
The f version looks much better. Only the top line problem remains. There are a few brown lines at the top, which are quite irritating. One single grey line at the bottom of those lines would probably solve the problem.
