pineapples in october.
Not to be confused with "Lemons in August." So I wondered today while looking at my incredibly long code about the banana movement in my pineapple game, if I could shorten it by adding a couple of extra variables. As a result, the code is a lot shorter with only three variables added. Right now I'm up to var47. The highest I got on GoSub was var39. So while it may seem that there's a lot less involved in this game, there actually is a lot more happening. This is the banana moving code.
movementtt_of_banana if bananadir=1 && bananay>150 then bananadir=3 : bananawall=1 if bananadir=1 && bananax<8 then bananadir=2 : bananawall=1 if bananadir=2 && bananay>150 then bananadir=4 : bananawall=1 if bananadir=2 && bananax>144 then bananadir=1 : bananawall=1 if bananadir=3 && bananay<18 then bananadir=1 : bananawall=1 if bananadir=3 && bananax<8 then bananadir=4 : bananawall=1 if bananadir=4 && bananay<18 then bananadir=2 : bananawall=1 if bananadir=4 && bananax>144 then bananadir=3 : bananawall=1 if bananadir=1 then bananax=bananax-1 : bananay=bananay+2 if bananadir=2 then bananax=bananax+1 : bananay=bananay+2 if bananadir=3 then bananax=bananax-1 : bananay=bananay-2 if bananadir=4 then bananax=bananax+1 : bananay=bananay-2 return
To use it, I call up a banana's x, y and direction, feed it into the code, and then put the result back, like so:
bananadir=banana1dir : bananay=banana1y : bananax=banana1x gosub movementtt_of_banana banana1dir=bananadir : banana1y=bananay : banana1x=bananax
Pretty clever, huh? The way it was before was having code keep track of each banana this way. Now there's a lot less code.
While I was at it, I also changed some colors. I thought the purplish-brown color was too dark, so I made it pink. Now it looks like strawberry ice cream. I made the papaya a darker green. So now at least I can add more bananas way easier. My limit of the number of stuff I can have in a certain ZONE is 31. I just think of that as the entire screen because I doubt that I'll add 22 extra bananas bouncing around. I think the limit to the number of variables I can have is var99, so I'm good with that. Now I'm bored again.
