    4,957
    2,719
    1,809,849
Not a good morning
atari2600land
After struggling with my code for 6 hours (I woke up at around 4 a.m. and quit at about 10) I went to fix some White Castle microwave burgers. And wouldn't you know it, I promptly had one of my choking fits where I couldn't keep water down. I don't know why but stuff apparently gets stuck in my throat, or I have no idea what goes on when that happens, but anyway, after a half-hour of forcing my finger down my throat, I found the problem.
So after that I went back to work on my game. It is now about 1 p.m. and I just now decided to quit for the day. I think I have accomplished the castle. When I went to test it on a real Odyssey 2, there was a triangle on room 1 of the first floor. But I eventually got rid of it. I worked and worked to try to get Jack not to get stuck accidentally in the walls.
It should not have to be this hard to do. All I thought I would need to do is check to see if Jack is touching the wall and if he is, go the opposite direction so he isn't touching it any more. But noooo. Nothing I try is working. I'm going to give up for now and come back to it later. At least I got the key in, something I was fearing I wouldn't have enough room to do, but I did and I don't have very much room left, something I predicted.
