    657
    2,702
    901,783
Limited enhanced, variable AI speeds
The biggest change is the AI players' speeds now vary depending on the game speed and the number of fireballs in play. When I redo the menu I'll relabel the Speed settings as follows:
1 = Childrens
2 = Slow
3 = Fast
4 = Wicked
The speeds are controlled by the following table which tell each player how far they can move each frame. The values are looked up using FRAMECOUNT AND 7.
AIplayerSpeeds
; where GameSpeed = 1(slowest) thru 4(fasest)
; Speed = GameSpeed - 1 + FireballCount - 1
; effect Speeds 0 thru 5
; X = Y * 1.2
; PAL = NTSC * 1.2
;                         N T S C                  --------SPEED---------
;         -------X-------  -------Y-------   X  Y   0   1   2   3   4   5
    .byte 2,1,1,1,2,1,1,1, 1,1,1,1,1,1,1,1; 10  8  P1
    .byte 2,1,1,2,1,1,2,1, 2,1,1,1,1,1,1,1; 11  9  P2  P1
    .byte 1,2,1,2,1,2,1,2, 2,1,1,1,2,1,1,1; 12 10  P3  P2  P1
    .byte 1,2,2,2,1,2,2,2, 2,1,2,1,2,1,2,1; 14 12  P4  P3  P2  P1
    .byte 3,2,2,2,2,2,2,2, 1,2,2,2,1,2,2,2; 17 14      P4  P3  P2  P1
    .byte 3,2,2,3,2,2,3,2, 2,2,2,2,2,2,2,2; 19 16          P4  P3  P2  P1
    .byte 2,3,3,3,2,3,3,3, 3,2,2,2,3,2,2,2; 22 18              P4  P3  P2
    .byte 3,3,3,3,3,3,3,3, 3,2,3,2,3,2,3,2; 24 20                  P4  P3
    .byte 4,3,3,3,4,3,3,3, 2,3,3,3,2,3,3,3; 26 22                      P4
I've also modified the Limited Catch to support limiting at a player level so that, for instance, player 1 could be limited while the other players have normal catch. Please note the current menu doesn't fully support setting each player. For now, the dots added above the M in limited will denote which players are limited. The first dot is player 1, second player 2 and so on. When the dots come off they come off from the end.
All players with Limited Catch
Players 1 & 2 have limited catch, players 3 & 4 have full catch.
I would greatly appreciate any feedback on how the different AI speeds work, such as is the childrens setting option appropriate for children.
Medieval_Mayhem.zip mm20061006NTSC.bin mm20061006PAL.bin
4 Comments
Thanks for the suggestion, but I like how the right-aligned shorter words help reinforce "option value" instead of "option name"
It should be possible to put Medieval in a smaller font while keeping the same general appearance.
That may work.
I've got the menu scrolling up/down, now to reimplement the changing of the values.
I've expanded upon Limited Catch by Player and gave each player a Yes/No/Limited Catch setting.
