    430
    1,870
    662,868
Failed Robotron 2600 Experiment
Cybergoth
Hi there!
I've been trying to see what happens if I push my multisprite engine to the limit. This is a demo of 32 sprites at once: 8k_sideluxe.zip
Usage: Launch it, press fire, then wait a few secs until it stabilizes.
Notes: DONT USE ON A REAL TV!! Tried & tested only with the latest Z26 DOS version.
This is just multiplexing 1 sprite. The crosshair is the second. Another engine approach could probably multiplex both sprites, which'd reduce the overall flicker, but at the cost of flickering the player as well. (I think Bob wrote one that does? It should be very interesting to compare both engines side by side doing the "Robotron" task :))
Greetings,
Manuel
20 Comments
If you single out a "robot" and try following its path, you'll notice the main problem - regular "worst case clusters". There an "unlucky" sprite may disappear completely for a couple of frames.
Now this is just random movement. The real Robotron AI will explicitely boost the building of such clusters, especially with all enemies heading towards the players spot :)
IMO my two-sprite-multiplex engine offered only marginal improvement, though it could undoubtedly be bettered.
24 sprites: http://www.atariage.com/forums/index.php?a...;showentry=1127
I also wrote a space shooter using the same engine with 12 sprites (two for the player's ship) plus missiles as bullets. This one has complete collision detection. I don't think I ever shared it, though (except I think at NWCGE a year ago), so I'll post it now: http://www.atariage.com/forums/index.php?a...;showentry=2943
Could you detail your approach a bit? I'd be interested in how many different scanlines your engine needs and what tasks they perform.
I think I'm possibly overcomplicating things with mine, as I require switching between 4 different 2 scanline blocks, requiring at least a 4 scanline gap between two displayed sprites IIRC.
In fact, I find it a major achievment that you got a 2 sprite multiplexer going: How do you reposition one sprite while you're drawing the other?
Hi Manuel,
I don't know if you missed it but Bob posted about this on [stella]. There should be some source there too. :) :)
I went into a bunch of detail on my blog when I was working on this. See:
http://www.atariage.com/forums/index.php?a...;showentry=1138
http://www.atariage.com/forums/index.php?a...;showentry=1163
http://www.atariage.com/forums/index.php?a...;showentry=1167
If you read the comments in those threads you will see that you helped me think through things! :)
The main problem is that there just isn't enough time to do all the stuff you need to do, both in-kernel and outside the kernel.
I think my algorigthm (in the kernel) goes like this (assuming we begin by displaying no sprites):
#1. Check for sprite begin. yes=goto #2, else goto #1
#2. Position player 0.
#3. Draw player 0, check for next sprite beginning (yes=goto #4, else check for end of player 0, yes=goto #1, else goto #3)
#4. Draw player 0, position player 1.
#5. Draw player 0, player 1, check for end of player 0 (goto #6), check for end of player 1 (goto #3)
#6. Draw player 1, check for next sprite beginning (yes=goto #7, else check for end of player 1 (yes=goto #1, else goto #6)
#7. Draw player 1, position player 0. Goto #5
A *lot* of mini kernels. And I can't remember exactly but there were some issues with the flicker being screwed up if the sprite list wasn't sorted correctly. It was very complicated. I probably should revisit it at some point, I suppose. :)
Were I not so dismally lacking in round tuits, I might try a robot-swarm game in 4A50 banking using something a little bit like my ruby runner kernel. Basically that would give an 80x128 bitmap overlaid on a 20x16 color grid (each grid square would be 4x4 double-height pixels). Each grid square could accommodate one background color (black or dark gray) and one of four foreground colors (cyan, orange, magenta, or greenish-yellow). Unlimited stuff on screen all for 30Hz flicker blinds.
Thanks for reposting all the details :)
I think one of the issues might be that you're rather slow in skipping "too late" sprites?
Do you think you can possibly update this bitmap fast enough to still have it qualify as an action game?
I'd like to see you try that.
If you watch the coinop game, or at least the 7800 version, I don't think even it moves every sprite at once. It kind of cycles through them.
I'd like to try this in Stella. What is the banking scheme? Just getting a blank screen right now.
You have to press fire to make it start, since I just quickly hacked this into the Colony 7 source :)
I should think so. The tricky part would be deciding what objects should move freely and what objects should be bound to the grid. Overlaying objects would look like a mess, so my inclination would be to have most objects be bound to the grid, but allow a fast-moving object to share a grid square with a slower-moving object. The slower-moving object would be obscured when the faster one was on top of it, but such a condition shouldn't last long. The most practical arrangement would probably be to allow the player to move freely and have everything else confined to the grid. If any part of the player shares a grid square with an object, the player is deemed to have collided.
So, it comes down to how many grid-cells you can update per frame?
I'd assume each moving enemy would require clearing of 1-2 cells and writing 1-2 cells.
Also if the player can move freely, it may require clearing 1-4 and writing of (1-4)*2 cells, since you'd have to restore the enemies on those cells and the player.
So, the worst case would possibly be:
4C+8W + n*(2C+2W)
(C= Clears, W= Writes, n=# of Enemies)
So what would you think, what would the maximum n be for a single frame?
I would figure one cell for the grunts, obstacles, and probably enemy shots. Some larger enemies would be 2x2. Having shots take up a full cell would be ugly, but would make them show up far better than any other reasonable method of handling them.
The player would be unable to share a cell with anything else, but updating the player could still require read-modify-write drawing on four double-cell areas of the bitmap (cells are four pixels wide, but bytes are of course eight).
Not sure the game would work well enough to be worth $50 or so, and I have too many other things on my plate to want to branch very far in that direction.
After seeing this, I think the flicker is too severe in return for the number of sprites generated. I think you have to somehow use the 2 and 3 copy mode. Either have robots move in squads or have them pass in and out of squad formation like Super Football does when the players run up to the scrimmage line.
Unfortunately that already is just enough sprites required for the first Robotron level. The 2nd already needs more and in higher levels the Arcade seems to throw 100 or more sprites on the screen :)
That would definitely be an option. But it seems pretty given that Robotron is way more than what the poor VCS can chew.
Yes... but this might work for, oh... the Grid Bugs levels in Tron. :)
