Planning ship positioning, velocity and accel.
Hello,Sorry for the long delay. I have included in this entry my thoughts on simulating the position, velocity and acceleration of the lander in the game. Comments, thoughts, corrections are always welcome.
; Ship position, velocity and acceleration implementation.; =========================================================;; The ship position shall be stored internally in 4 bytes per axis. Below is; a diagram of the 4 byte value and below that is a description of each section.; ; %NNNNNNNN ssssssss dddddddd dddddddd; ; The first byte declares the screen the player is on. The game play area; is a grid of linked screens. The first byte of X and Y pos sets place the ; ship within the grid of screens.;; The second byte is the integral scanline/pixel position of the ship within; the current active screen. ;; The 3rd and 4th bytes are the decimal portion of the ship's position on that; axis.;; The X&Y position is interpreted in software as follows:; - Given:; ShipY = char[4]; ShipY = char[4]; Maginification = enum { 1x, 2x } = 1x; ShipDisplayY = char; ShipDisplayX = char; ActiveScreen = struct { baseX, baseY, Scale(1x/2x), Landing Zones }; - The code will look at the 1st bytes to determine the active game screen; - The code will search a list of zoomed areas within the active screen.; The second bytes of X and Y are compared to the zoom boxes. If one; matches, then the active screen is set to the zoomed screen, and the; magnification setting is changed from 1x to 2x.;; // NOTE: Each active screen is 128 scanlines tall and 128 pixels wide.; // The actual displayed screen is larger than 128 x 128, but when the; // ship leaves a 128x128 area it has entered a different active screen.; // At that point the ship position wraps to the other side of the active; // screen and the landscape rendered on the screen is updated.; // So based on the dimesions 128x128 we say that the upper 7 bits; // of the second position of each axis shall form the on screen; // position of the ship within the active screen area.;; // Within each active screen there are 0 or more zoomed areas where all; // dimensions are magnified 2x normal. For that case, we use the full; // second position byte offset to the origin of the zoomed area to find; // the X and Y Display values. Including the least significant byte will; // effectively mulitply the ship position resolution by 2x.; - IF Magnification = 1x THEN; - ShipYDisplay = ShipY[1] / 2 + ConstantYOffset <=(8 diagram see below); - ShipXDisplay = ShipX[1] / 2 + ConstantXOffset; ELSE // Magnification is 2x; - ShipYDisplay = ShipY[1] - ActiveScreen.baseY + ConstantYOffset; - ShipXDisplay = ShipY[1] - ActiveScreen.baseX + ConstantXOffset; ENDIF; ; Here is a simple diagram that will hopefully clarify the above thoughts:;; Pixels; |<------- 144 ------------->|; | |<------ 128 ------>| |; | 8 | | 8 | ; V V V V; =======>+---------------------------+; | 8 | Rendered Screen | ; S | ===>| +-------------------+ |; C | | | | Active Screen | |; A 144 | | | | |; N | | | | | |; L | 128 | | | |; I | | | | | |; N | | | | | |; E | | | |PF1 |PF2 |PF2 |PF1 | |; S | ===>| +-------------------+ |; | 8 | |; =======>+---------------------------+; | | Control panels |; 48 | |; | | |; =====>+---------------------------+;; Velocity:; ---------; The velocity in each axis shall be represented by a signed 32-bit value.; Each frame we will add the velocity for each axis to the 32-bit position; value. This is an overkill approach since by my calculations a 18-bit; value would cover all the possible velocities for a lander game, but I ; don't have a shortage of RAM, so I will go ahead and waste 3+ bytes. :P;; Accelleration:; --------------; Every frame the lander is accelerated by gravity, and by one or more ; lander thrusters. Gravity is simply a constant applied to the vertical; velocity accelerating the ship downward. The thrusters will we implemented; as a table of constants indexed by the rotational position of the ship, and; added to the X and Y velocities. We will apply all acellerations for a ; frame before applying the velocities. ;; I am also thinking that the main thruster should take 3 or 4 frames to ; increase to full thrust. The easiest way to do this is to have the thrust; values in the table be the minimal values that we multiply by a factor ; reflecting the time the thruster has been active. The resulting game play ; will be that a single burn of N frames will produce more thrust than; multiple burns spaced over N frames. I plan that fuel consumption per frame; of active thrust will be constant, since that will reward the player who; lands with the fewest firings of the main thruster.;; The actual constant value to use for gravity is going to be a challenge to ; get right for comfortable play. Acceleration on the moon is 1.62 m/s2. It; is simple enough to simulate that in the game; we just need to decide how; tall (in meters) a scanline is for our simulation and then calulate our ; constants from there. The trick is picking a scale for the game/ship that; produces a comfortable and enjoyable feeling for the player. The main; thrust must be strong enough to feel responsive, but not easily overpowering; making it too hard for the player to set the ship down. I suspect the; correect values will become evident with actual game play. I believe the; actual value for lunar gravity will be usable, but I am willing to reduce; its value for the simulation if it makes the game more fun to play.;
The code option on the forums butchers my formatting, so I will attach an image of the diagram from above. Cheers!
