All Activity
- Past hour
The Official NEO-GEO Thread!
Charlie Cat replied to Charlie Cat's topic in Classic Console Discussion
Hi guys, More gameplay footage of City Of The Wolves from NeoGeoNow. Enjoy. Anthony.. -
Yes, that's one of about 10 different videos I have watched last week. What I also did the two weekend mornings was taking an old (broken by me when I still had not enough clue of what I was doing ) phono pre-amplifier board and practicing de- and on- soldering smaller and bigger chips, just to get a good feel of the iron, the temperatures to use, and to see how to work with SMD components smaller than 0805. So far I feel confident. Speaking of SPDIF, I wanted to bring something else up last week, but forgot - what are the chances to get an HDMI compatible audio out of PokeyMax? I mean, having Sophia 2 board I can imagine cooking up a small breakout board to take the DVI signals and a compatible signal from PokeyMax to feed it all into an HDMI socket... Doable?
How To Fix: Find a USB-C data cable to plug into the PC and into the AGSP, you can use the one that comes with the Atari2600 Plus, I did... . TIP: When I unscrewed the bottom panel of the console that has the weight in it to make the console heavier I used it so I could hang the buttons over the corner of my desk so you do not press down on them and turn on the console on my accident so put the weight on the left side of the console it keep it balanced so I could press the power button when I needed too. If yours does not boot then open it up and unscrew the main PCB board, its black, you will need the ribbon cable connected to turn it on, now turn over the board, I black taped the green board then stuck the black board on it with blue tac to hold it in place, you need to short the 2 pin holes next to the NAND Chip, its above the SD Card slot on the right side of the board as you turn it on, I used a jump pin wire that has two pins on it one at each end, I held down the RESET button too as I was doing it, so hold RESET, power button and then wiggle the pin wire until you see `MASKROM on the RKDebvTool v2.72 then you can stop and let go, once you get into that mode then you can flash it with the firmware 1.30. Now move the firmware folder `3. Firmware` to your desktop and remove the space in the folders name `3. Firmware` to `3.Firmware` and added from the folder the Loader.bin and Firmware.img to the RKDevTool v2.72 and you should see them all blue, then press RUN Button on it and it will then flashed the firmware OK and get it working again... Found MASKROMM from the AGSP Added Loader.bin Added Firmware.img Pressed RUN Button to start flashing and finished all OK and its.. ALIVE... ALIVE... All done and the AGSP is now working again... I hope this works for you too...
What did you buy today?.........
sramirez2008 replied to evilevoix's topic in Show Us Your Collection!
A new book. It arrived a couple of days ago. I've read through a fair bit of it and like it. IMO, the author does a good job at presenting each "curious" game machine. -
Hi All, I have completed the MPEB TI99 /4A Music Card V4.0, while I am waiting for another 3D printer to arrive, I will optimise and tidy this board and all the other boards that will be made. Regards Arto.
- 160 replies
You'll notice ANTIC and GTIA have similar packaging but the print is the right way up there. I've seen several VLSIs with the printing 'upside down', and it can definitely throw you when you're not paying attention. ANTIC was dead. I gather that by the time the owner replaced that IC, he'd already had POKEY out of the socket and inadvertently put it in backwards, and thus replacing ANTIC did not appear to fix the machine. I found the installed DRAMs and everything else on the machine to be absolutely fine, although the original ANTIC is stone dead. So: it was a bad ANTIC all along. Here are the photos for closure (I hope @spacedmonkeys doesn't mind):
Jag stopped working today (power led lights but screen is blank)
cubanismo replied to john_q_atari's topic in Atari Jaguar
Agreed. Use the credit card + old T-Shirt method from the sticky thread on the subject -
I really don't understand people with tabs I rarely have more than two open tabs per browser window and at most 3 browsers open one on each monitor. https://www.tomshardware.com/software/mozilla-firefox/firefox-user-loses-7470-opened-tabs-saved-over-two-years-after-they-cant-restore-browsing-session
I am very glad that the POKEY survived being reversed in the socket. Have you seen many of that type with the upside down print? I do now remember viewing the pictures earlier, and noticing the scratch on POKEY, but not the orientation. Doh! But then I thought that it may have been swapped with or from the 400 since then? I think it helps more if the photos are uploaded to the topic. @spacedmonkeys do we know what the fix was in the end? DRAM or ANTIC or both?
E/A was not designed to be learning one, even the manual states it that prior knowledge is required. TI marketed the mini-memory with its line-by-line assembler as more of a learning tool, there was more tutorials and examples with it plus it was designed as stepping stone up from Basic so you should had a bit of programming mindset already from using Basic language. As for the percentage of people that gave up trying after buying the E/A package most likely a high percentage back in the day.
Pi Pico[W] Peripheral Expansion Box Side Port Device
chue replied to JasonACT's topic in TI-99/4A Development
Indeed, it fails on "B". Testing was done on a single Pico on the silver and black TI. I tried 250 mhz + 1 NOP, 266 mhz + 9 NOPs. -
I imagine that goes more like this. But, being it is Skeletor... I am afraid I have no video reference for that. together we can rule the galaxy.mp4
@HOME AUTOMATION thanks for the tip. I was trying to stay away from org and seg directives, that will be a whole other learning exercise. I have you folks to help me along, I have Classic99 which makes it so much easier to expose the inner working of the 4a then I would with real hardware. I have to wonder, what percent of people purchased the E/A Module with the intent of learning assembly language and just gave up?
HSC - Uninitialized Data / Formatting
RevEng replied to wavemotion's topic in Atari 7800 Programming
This is a 7800basic thing. The hi-score code in 7800basic doesn't call the official hsc routines, because it provides a unified interface and driver supporting both hsc and savekey devices. At first I didn't have hsc init, because I didn't want to accidentally introduce a bug into the init and be the reason some 7800basic game cart got a reputation as an hsc eraser. (the reasoning being, a player would almost certainly have played official release titles before homebrews) hsc init has been added since then, when it became apparent emulated hsc was going to be a pain point, but initially it relied on the mame nvram init values. (0xFF) I added a check for 0x00 fill later, but I just discovered a bug in it that would likely cause the 0x00 init to be skipped. As to what the historically accurate default fill is, it's probably 0x00.- 1 reply
- 2
Hellway 2 Players Edition
Octavio Pinho Bokel replied to Octavio Pinho Bokel's topic in Atari 2600 Programming
The game is very similar to the first. The quick manual page of the QR code has a section regarding the changes for the 2PE. It almost the same game. The game modes part is interactive, you can click the features you want, and it gives you the game you should select. The GitHub page has more in depth information regarding the single player version, that most can be applied to the 2PE. The first game has a beautiful manual, I did not publish it online. But all information can be found online. The manual is a more beautiful and more polished version. @Leonardons was responsible for most of it, and we got a lot of input from Albert from AtariAge, until it was perfect for printing. Everything you need for playing can be found by following the QR code showed at the first screen of the game (url bellow) https://opbokel.github.io/g -
Yes, sorry, busy with a move. 🙂 I’ll reach out by PM.
Season 15 ~ Weeks 14/15/16 ~ HomeBrew Weeks!
UnRedeemed replied to Vocelli's topic in 2600 High Score Club
Indeed, looks like Jason peaked in the mid-1970s in the States, with nearly 1 in 50 babies overall (so around 4% of all males) being given the name. By the mid-1990s it was only about 1/10th as popular. The dominance of Jason contrasts with the current male name leader, Liam, which seems to have maxed out and plateaued at only around 1/4 the incidence of the mighty 1970s Jason. So to wrap up this little excursion, assuming the 1970s are the most represented birth decade on Atariage, that mostly males participate in the HSC, and that most were born in the States (although at least two of the three Jasons at issue were not, interestingly), it appears a Jason juggernaut was relatively more likely to occur than I at first expected. -
Steam Game Code Giveaway - Sharing the love with AA
yoras replied to yoras's topic in Free Games and More
I have a few codes I'm going to give away for anyone who wants them. I figured to make it fun, I'd do them 1 by 1 -
Extra TI books: TI Logo II and Logo Sampler, TE protocol, TI Forth
OLD CS1 replied to OLD CS1's topic in TI-99/4A Computers
I will see about an envelope or box. PM me with your shipping address and I will give you options for mail. - Today
That was amazing. I had no idea that existed! They really streamlined the whole look by adding their beige monitor. Also, the CDC 7600 operator console. Wow, that's a dual-monitor retro battlestation.
I bought another game. It's a cart with the manual. This game is a PAL cart. It will be my first one in the collection. Also, I've played this game before as a ROM and liked it. Now I'll have the physical copy. Once it arrives, I'll show a picture of it.
- 2,546 replies
- carts
- collecting
(and 3 more)
Tagged with:
I believe that.
Admirable! Well said. I expected @Ksarul was going to play a demo.
I have a 990/10a processor card and a couple of 990/5 processor cards, both have at least one serial port which i assume could be used as a console port. But, my (possibly wrong) understanding of the 990 systems is that until you boot from a floppy or hard drive and load appropriate drivers for the hardware, you won't get anything on the console or the 911VDT card. At this point in time i'm trying to prove the 911VDT cards ( i have 2) work by loading some code to configure them through the programmers panel, and also make an interface to use a PS/2 keyboard and a RGBtoHDMI with the 911VDT card instead of the original keyboard and monitor. I do have one 911 keyboard (missing one keycap if anybody has a scrap keyboard) but no 911 monitor. Once i get this working i can download some code to test the TFDC cards i have and figure out why they won't try booting from floppy or Gotek. I have 3 TFDC cards now, 2 do the same thing, just sit there reading the status from the floppy drive but never turn the motor on even though all the signals seem go, and the other one fails the self test. Thank you for the offer, i do have 4 or 5 7 port serial cards from Richard Norman so i assume i could use one of those as a console port if for some reason i couldn't use the one on the processor board. That said, i wouldn't mind adding another different card to my collection, i can do a swap for a 7 port card ? Jim
