Richard H. Posted April 30, 2007 Share Posted April 30, 2007 Looking for a plastic case to house a PCB which has USB-A plug at one end and DB9 (serial port) socket at the other. Nothing as big as a Stelladaptor case because I need it to plug directly into the USB without too much weight hanging off it. Thanks Quote Link to comment Share on other sites More sharing options...
+Stephen Moss Posted May 1, 2007 Share Posted May 1, 2007 I'm not sure how big the Stella adaptor case is but my suggestion would be to use a 9 pin D Gender changer case as not being much bigger than being able to fit two D connectors in back to back they are probably some of the smallest and lightest cases around what will accecpt a D connector and a USB plug. Alternatively albeit a bit wasteful you could buy a USB to serial adaptor, take the case appart (if not moulded) and throw the guts away. Quote Link to comment Share on other sites More sharing options...
Richard H. Posted May 1, 2007 Author Share Posted May 1, 2007 I'm not sure how big the Stella adaptor case is but my suggestion would be to use a 9 pin D Gender changer case as not being much bigger than being able to fit two D connectors in back to back they are probably some of the smallest and lightest cases around what will accecpt a D connector and a USB plug. I know what you mean, but I've never seen one made for DB9 and USB A. Have you ? Alternatively albeit a bit wasteful you could buy a USB to serial adaptor, take the case appart (if not moulded) and throw the guts away. Good idea, but it's going to be too expensive as it's not a one-off project, I'm building quite a lot. Quote Link to comment Share on other sites More sharing options...
+Stephen Moss Posted May 2, 2007 Share Posted May 2, 2007 I'm not sure how big the Stella adaptor case is but my suggestion would be to use a 9 pin D Gender changer case as not being much bigger than being able to fit two D connectors in back to back they are probably some of the smallest and lightest cases around what will accecpt a D connector and a USB plug. I know what you mean, but I've never seen one made for DB9 and USB A. Have you ? They probably exist but I have not seen any to date although until a quick search through the catalogues of our usual suppliers yesterday I have not been looking for them. If I come across any I'll let you know. Quote Link to comment Share on other sites More sharing options...
Richard H. Posted May 2, 2007 Author Share Posted May 2, 2007 If I come across any I'll let you know Thanks ! Quote Link to comment Share on other sites More sharing options...
