Code Snippets & Samples for bB Beginners
Atarius Maximus
I've had a few requests via private mail to help people out who are trying to learn bB, along with requests for code examples. I thought I'd post some very simple, short programs that demonstrate how to do some specific things in bB. I always learn best by looking at sample code... hopefully these will help someone out. I'd be happy to create additional examples if someone wants one.
Here are some links to some good tutorials from other members:
From CurtisP: Programming Tutorial
From SeaGtGruff: Tutorial Session 1 | Tutorial Session 2 | Tutorial Session 3
Other downloads & links you'll want:
Get the latest version of bB here.
Get the latest version of Visual bB here.
Get the latest verison of Stella here.
Read the latest documentation here.
Steve
1_DrawSprite.bas
1_DrawSprite.bin
2_AddPlayfield.bas
2_AddPlayfield.bin
3_MoveASprite.bas
3_MoveAsprite.bin
4_FireAMissile.bas
4_FireAmissile.bin
5_AnimateASprite.bas
5_AnimateASprite.bin
6_AnimateAplayfield.bas
6_AnimateAplayfield.bin
7_3DMovingSprite.bas
7_3DMovingSprite.bin
9_DetectCollisions.bas
9_Detectcollisions.bin
8_FlashColors.bas
8_FlashColors.bin
10_MoveAnAnimatedSprite.bas
10_MoveAnAnimatedSprite.bas.bin
11_AdventureLight.bas
11_AdventureLight.bin
12_SimpleTitlescreenDemo.bas
12_SimpleTitlescreenDemo.bin
13_BankswitchingDemo.bas
13_BankswitchingDemo.bin
14_MoveAnimateAndFire.bas
14_MoveAnimateAndFire.bin
15_MoveSpritewithPlayfieldBoundaries.bas
15_MoveSpritewithPlayfieldBoundaries.bin
16_MoveSpritewithEnemySpriteFollowing.bas
16_MoveSpritewithEnemySpriteFollowing.bin
Edited by Atarius Maximus
  • Like 10
  • Thanks 3
  • 1 month later...
  • 2 months later...
HI,.. sorry for my bad english.
yes, i mean how to move a animated Sprite.
and i also want to know how to programm diferent "layers", like a intro,... main part..., outro... credits....
oh, so many other questions, i will post them little by little if i cant find any conclution.
thanx!!
Your English is fine. I was 98% certain that was what you meant, but my real reason for asking was because I wasn't at home when I was reading the posts, and that meant your question wouldn't show up under "View New Posts" when I did get home later. I wanted to post *something* in the thread so it would show up under "My Posts" when I got home, to remind myself that I intended to reply to you. I could have just posted something like "I'll check on it later," but instead I decided to ask for verification of what you wanted, just to be certain. So don't worry about your English! :)
Michael
Okay, here's a sample that combines "3_MoveASprite.bas" with "5_AnimateASprite.bas." I think perhaps the reason you were having trouble combining them is because they both use variable y, but they use y for two different things. :)
There are two ways this new sample can be improved-- (1) animate the sprite only when it's being moved around with the joystick; and (2) have the sprite face in the opposite direction if it's being moved right-to-left. But those can be for later.
Michael
Thanx, that helps a lot!
what i still did not understand is your reply of the other question with going to other Levels (goto different Playfields if something happenes).
anyway... in next time i´ll try to work with combinations of the samples in this tread. Its my problem that i do not exactly know how to use
lot of different actions in on programm.
i look forward to create new samples with your help, that would be very helpfull for the other new programmers here.
for me it´s the best way to learn, looking at other peoples programs and putting out special events i like to use.
thanx so far,..
Tom
Michael
I've updated the first post with your additions, Michael. I'll keep doing that when new samples are posted.
Cheers! :)
Steve
Cheers! :)
Steve
fine,.. so i can continue with my patchwork programming,.. that helps a lot at the begin,..
thanx tom
Edited by freehabitat
  • 1 month later...
  • 6 months later...
I looked at your animated playfield code. You have this:
 x=10 : rem Counter number - when to switch to frame 2
y=20 : rem Counter number - when to switch to frame 3
z=30 : rem Counter number - when to switch to frame 4
main
COLUPF=28
COLUBK=0
b=b+1
if b>30 then b=0
if b=x then goto frame1
if b=y then goto frame2
if b=z then goto frame3
ETC, ETC
Wouldn't it be better to just to this?
main
COLUPF=28
COLUBK=0
b=b+1
if b>30 then b=0
if b=10 then goto frame1
if b=20 then goto frame2
if b=30 then goto frame3
ETC, ETC
I don't know if it saves you any ROM, but this way you're not wasting variables.
The only reason I can think of for using variables is to make the code more reusable within the program-- for example, if you want to speed up or slow down the animation rate by changing the values in the variables. Otherwise, constants help save RAM (which-- on the Atari 2600-- is more important than saving ROM, since RAM is more precious than ROM).
Michael
Michael
That is exactly why I did it - to allow for changing the animation rate. I suppose it wasn't necessary for the sample program, yuppicide's revision would work fine too.
Steve
One thing we should do with the first post is make everything the same. Am I nitpicking? Unfortunately yes.
Everything code snippet has two files with it. First one being .bas, and second being .bin. Except number 8. It's backwards. First is .bin. Not a big deal, but I couldn't find 8 to load in bB and I swore I downloaded it lol.
Second, number 10 is named .bas.bin when every other one is .bin.
Anyway, nice tutorials. I enjoyed them. I think there should be one for how to insert simple background music and one how to insert a sound effect. I'll be able to manage just fine I am sure, but still would be nice to read a tut. Thanks again for the tutorials!
  • 5 months later...
I added another sample program to the first post. It's a sample program that shows how to make the 'light' sprite around your character to move around an invisible maze, just like the mazes in the original Adventure game.
Thanks,
Steve
  • 1 month later...
  • 2 months later...
  • 5 weeks later...
