Knight Lore
Improvement idea - don't put stuff up as Save State files.
I can't get it to work properly since Save State files just don't work properly between different versions of the emulator.
Tried on 4.0 and the network enabled 4.2 (id's as 4.1).
From what I saw of screenshots, looked good.
Neat Airball like game - though I cant quite figure out how to play? I keep dieing.
You have to find the cauldron room, near the centre of the environment. In the Spectrum version, you had to enter the room as a human, not a werewolf, and an image of an object would appear above the cauldron. You then had to find that object and get it to the cauldron. Get 14 objects to the cauldron in the proper order, and you win.
In the Spectrum version, again, the order of the 14 objects was always the same, but the starting point in the list of 14 objects was random.
I expect that the game logic is similar Spectrum->BBC->Atari.
But, I don't like the title screen...
If favored, I could do a G2F conversion of the (IMHO nicer) Amstrad title screen...
CU
Irgendwer
Come on... this "nicer" screen is done in less than 5 minutes for the ATARI, while the actual screen took several days to finish.
We chose already not to use the worse Amstrad Tilte.
Actually, Chrodegang doesn't like the screen because I made it.
It's up to XXL what he wants, because he is the coder.
Come on... this "nicer" screen is done in less than 5 minutes for the ATARI,...
I like to see THAT! (I've just pressed the button on my stop watch... ;) )
<unfair statement removed>. Please don't take this personal, (I didn't even notice your name in the image) but I thought
also that this conversion could be better.
Upps, I forgot these sensitivities. I shut up (almost).
Of course. I just tried to be supportive.
CU
Irgendwer
Edited by Irgendwer
Thanks - my bigger problem is the few rooms next to the beginning - the chair room with the spikey balls on top, all I can do is push and jump and therefore die. The room to the north where the blocks are moving - when I jump there is a bit of extra movement to stop and I always die on that also.
Any difference between Knight and Wolf or just for final room?
Taking the result into account, this is hard to believe. Please don't take
How a bout a deal? You show us something better that is ...
a) fitting to the A8s restrictions
b) fitting to the style of the A8 version of the game
c) using the limitations of G2F.
Not fitting to the game is:
Colour mode(160 x192)
Huge size
If it is better, well, XXL may use your picture.
I have no problems with it, though I won't be angry (or else ;-) ) . If only the A8 get's the best what's possible.
I disagree. Mixing colour & monochrome modes can lead to very convincing effects which I would use to enhance the image
(e.g. top and bottom part of the border).
Anyhow, here an example which follow your rules. Since I do not like to spend time for superfluous work (I would do the
Amstrad conversion if there would be a chance for deployment), I decided to take the title pic for one of the next games
in XXLs pipeline (please confirm ;) ) - hoping that the time spend was not useless....
CU
Irgendwer
Alien8.zip
Edited by Irgendwer
