eric_ruck Posted August 7, 2002 Share Posted August 7, 2002 I have a question about the 7800 proto cart, the type with the Pokey chip and the eprom socket on it. Is there any reason why this cart wouldn't work with non-Pokey games? Eric Quote Link to comment Share on other sites More sharing options...
CPUWIZ Posted August 7, 2002 Share Posted August 7, 2002 I don't think so, although I haven't played with mine, it's on display. Does yours look like this: Quote Link to comment Share on other sites More sharing options...
+Mitch Posted August 7, 2002 Share Posted August 7, 2002 If ypu have the same board as cpuwiz, it will work as long as the games are 32k or smaller. Mitch http://atari7800.atari.org Quote Link to comment Share on other sites More sharing options...
Tizoc Posted August 7, 2002 Share Posted August 7, 2002 Mitch has got the right answer. The board should work with non-pokey that are 32k or smaller. are you trying to use EPROMs? If your board is exactly like cpuwiz you will need to add a hex inverter, 74LS04, into U2. And I beleive jumper (W3) should be open. I added a switch to mine at W3 so that I could go back and forth between the masked ROM and the EPROM. It's been a while since I fiddled with that cart though. Quote Link to comment Share on other sites More sharing options...
eric_ruck Posted August 8, 2002 Author Share Posted August 8, 2002 Mitch has got the right answer. The board should work with non-pokey that are 32k or smaller. are you trying to use EPROMs? If your board is exactly like cpuwiz you will need to add a hex inverter, 74LS04, into U2. And I beleive jumper (W3) should be open. I added a switch to mine at W3 so that I could go back and forth between the masked ROM and the EPROM. It's been a while since I fiddled with that cart though. My board looks just like the one pictured above. I have a Ball Blazer ROM in it that works great. I have a few mystery EPROMs which don't work, but that could be because there's nothing on them. I don't know. Any ideas? Quote Link to comment Share on other sites More sharing options...
+Mitch Posted August 9, 2002 Share Posted August 9, 2002 I was lucky with mine. It has a ZIF socket at U2, so I can switch between ROM and EPROM games in seconds. Of course the 128k EPROM cart I built myself is even better. Mitch http://atari7800.atari.org Quote Link to comment Share on other sites More sharing options...
Tizoc Posted August 9, 2002 Share Posted August 9, 2002 @Eric I got the same thing from that ebay seller, staceymama?...or something like that. Anyhow, I read the EPROMs with my burner and it's just garbage...maybe at one time it was working game cade, but with the windows open like that, it just woulnn't survive. Iif your trying to use EPROMs make sure you install the Hex inverter at U2. They won't work with out it. Also, if it was used for protoype testing, it semmed strange to me that some of the boards did not already have the Hex inverter installed, or at least the socket to put one in. @Mitch I ended making an adapter board for the supercart board and that is the only board I use now for EPROMs. It sure makes testing some of those 128k ROMs a lot easier. Quote Link to comment Share on other sites More sharing options...
