Almost Rice Posted May 28, 2008 Share Posted May 28, 2008 (edited) I can post a modified instructions of the FAQ on how to make the 2 buttons work. The changes are for the differences in wire colors. Yes please This is based on the 7800 FAQ. I just added the Sega cable information. I did so since the sega cables are more readily available. I used 470 Ohm resistors instead of 620. # Joystick Pinouts 2600/7800 pinouts: _________________ \ o5 o4 o3 o2 o1/ \ o9 o8 o7 o6 / \___________/ Female pin # 2600 control 7800 control Sega Genesis extension cable 1 WHT- Up WHT- Up Brown 2 BLU- Down BLU- Down Red 3 GRN- Left GRN- Left Orange 4 BRN- Right BRN- Right Yellow 5 unused RED- Button (R)ight (-) Green 6 ORG- Button ORG- Both buttons (+) Blue 7 unused (+5v) unused (+5v) Grey 8 BLK- Ground(-) BLK- Ground(-) Black 9 unused YLW- Button (L)eft (-) White 2600 control (button) pin 6 ORG(+) --------------()------------BLK(-) pin 8 Button 7800 control (buttons) /----------YLW(-) pin 9 Button L / /---------()---| YLW splits / \----///-----\ pin 6 ORG(+) -------| ORG splits 620 ohm |---BLK(-) pin 8 \ /----///-----/ \---------()---| 620 ohm Button R \RED splits \----------RED(-) pin 5 7800 control (buttons) with SEGA wires /----------White(-) pin 9 Button L / /---------()---| Black splits / \----///-----\ pin 6 BLUE (+) -------| BLUE splits 620 ohm |---Black(-) pin 8 \ /----///-----/ \---------()---| 620 ohm Button R \Brown splits \----------Green(-) pin 5 Edited June 23, 2008 by Almost Rice Quote Link to comment Share on other sites More sharing options...
mimo Posted May 28, 2008 Share Posted May 28, 2008 thanks for the pin out.Any reason for using lower value resistors? Quote Link to comment Share on other sites More sharing options...
Prodos8 Posted May 28, 2008 Share Posted May 28, 2008 thanks for the pin out.Any reason for using lower value resistors? Probably 'cause that's all he had. The circuit seems to be quite tolerant within reason. Quote Link to comment Share on other sites More sharing options...
