27ace27 Posted June 21, 2008 Share Posted June 21, 2008 is this possible? what is required? any info appreciated! Quote Link to comment Share on other sites More sharing options...
+bf2k+ Posted June 21, 2008 Share Posted June 21, 2008 is this possible? what is required? any info appreciated! well.... you're probably going to need 48k and a program that runs on a 400 / 800. I ran AMIS on an 800 with 48k for a few years before switching to XLs. Quote Link to comment Share on other sites More sharing options...
machf Posted June 21, 2008 Share Posted June 21, 2008 Those were the days... one issue of Informática Creativa had an article on BBS's running on 8-bits, and how they had started and changed along the years... that was around 1989. I'll take another look at that article. Quote Link to comment Share on other sites More sharing options...
27ace27 Posted June 21, 2008 Author Share Posted June 21, 2008 Those were the days... one issue of Informática Creativa had an article on BBS's running on 8-bits, and how they had started and changed along the years... that was around 1989. I'll take another look at that article. thanks, that would help! Quote Link to comment Share on other sites More sharing options...
machf Posted June 21, 2008 Share Posted June 21, 2008 Not much luck... the artcle basically describes how they started a BBS with a 130XE and an XM-301 modem, apparently with 2 1050s with US Doublers, running FOREM, then progressing through a Hayes modem and an SX-212, switching to a custom FOREM/AMIS hybrid and later BBCS 2 Construction Set, and finally in the beginning of 1989 (the issue is from April) ending up with a Supra Mode 2400, a 130XE expanded to 320KB, an XF-551, a 256KB MIO and a Seagate half-height 20MB HDD running X-Press Pro. Not quite the info you were looking for, I'm afraid... Quote Link to comment Share on other sites More sharing options...
27ace27 Posted June 23, 2008 Author Share Posted June 23, 2008 Not much luck... the artcle basically describes how they started a BBS with a 130XE and an XM-301 modem, apparently with 2 1050s with US Doublers, running FOREM, then progressing through a Hayes modem and an SX-212, switching to a custom FOREM/AMIS hybrid and later BBCS 2 Construction Set, and finally in the beginning of 1989 (the issue is from April) ending up with a Supra Mode 2400, a 130XE expanded to 320KB, an XF-551, a 256KB MIO and a Seagate half-height 20MB HDD running X-Press Pro. Not quite the info you were looking for, I'm afraid... wow.... my head hurts after reading that, I guess I have some research to do Quote Link to comment Share on other sites More sharing options...
