MrAtari2600 Posted November 13, 2008 Share Posted November 13, 2008 I think its a fire hazard... Its something i've never seen before!!!! please help Alright i just pickedup an 1040 ST for free i was very excited BUT i think i know why it was free I flick the switch on hoping to hear a buzz or something and yup a buzz then a screech high pitched noises, the power light flickered a bit mostly staying off. then a wierd smell emitted as i was trying to look inside to see if something was loose/ I turned it off and unplugged immediately My only thing i can say is The power supply on it has an issue. Anyone ever seen a 1040 ST do something like this? If you have reply. I have most tools available from soldering to screwdrivers to mailing the item Thanks guys! Matty Quote Link to comment Share on other sites More sharing options...
+poobah Posted November 13, 2008 Share Posted November 13, 2008 I think its a fire hazard... Its something i've never seen before!!!! please help Alright i just pickedup an 1040 ST for free i was very excited BUT i think i know why it was free I flick the switch on hoping to hear a buzz or something and yup a buzz then a screech high pitched noises, the power light flickered a bit mostly staying off. then a wierd smell emitted as i was trying to look inside to see if something was loose/ I turned it off and unplugged immediately My only thing i can say is The power supply on it has an issue. Anyone ever seen a 1040 ST do something like this? If you have reply. I have most tools available from soldering to screwdrivers to mailing the item Thanks guys! Matty Pretty sure you need a new power supply Quote Link to comment Share on other sites More sharing options...
MrAtari2600 Posted November 13, 2008 Author Share Posted November 13, 2008 (edited) Is it common to come across 1040ST's With power supply issues? To add on: Where is a Used/ refurbished Or even new power supply available Edited November 13, 2008 by MrAtari2600 Quote Link to comment Share on other sites More sharing options...
Rybags Posted November 13, 2008 Share Posted November 13, 2008 I initially bought a 520ST-FM 20 years ago, new. Got a day or two use out of it, then... It did almost the exact same thing - power supply want zap, smell emitted, machine then totally did not work. I'd guess both were the PSU killing itself. I took the machine back and paid the extra bucks and traded up to the 1040. Quote Link to comment Share on other sites More sharing options...
MrAtari2600 Posted November 13, 2008 Author Share Posted November 13, 2008 ok THANK YOU FOR ANSWERING!!!! it is a problem thats occured before phew! alright so if someone has a broken 1040ST Thats UNREPAIRABLE I also need to buy 3 keys from someone the 0 key on the numeric the . key beside that and whatever is to the left of the backspace. But heck thanks for answering Im on the search thanks to google for a power supply! Quote Link to comment Share on other sites More sharing options...
Atari_Only Posted November 14, 2008 Share Posted November 14, 2008 Have you opened the ST? If your handy with a soldering iron you maybe able to repair the powersupply. It sounds like the capacitors dried up. If you open the case and remove the power supply, you may find the capacitors have leaked or blown apart. Replacements can be found at Radio Shack. Post a pick of the powersupply if you can.. AO Quote Link to comment Share on other sites More sharing options...
MrAtari2600 Posted November 14, 2008 Author Share Posted November 14, 2008 i took it apart I will post pictures after school Quote Link to comment Share on other sites More sharing options...
MrAtari2600 Posted December 3, 2008 Author Share Posted December 3, 2008 Camera has been dead sorry on no response for a while Quote Link to comment Share on other sites More sharing options...
frogstar_robot Posted December 5, 2008 Share Posted December 5, 2008 Camera has been dead sorry on no response for a while That large black cap looks bulged on top. There is also a large power semiconductor to the right you might want to look at. Quote Link to comment Share on other sites More sharing options...
MrAtari2600 Posted December 5, 2008 Author Share Posted December 5, 2008 Hey !!! thanks for your response the large black cap ( the one on far left fat on bottom) looks like a buldge but it isn't Also If you look above the yellow tape to left there is black o.o is that bad? i think something went there. im kind of a newbie like in most things so this is different, Quote Link to comment Share on other sites More sharing options...
Noelio Posted December 6, 2008 Share Posted December 6, 2008 That resistor at R8 is toast. Quote Link to comment Share on other sites More sharing options...
MrAtari2600 Posted December 6, 2008 Author Share Posted December 6, 2008 (edited) I can pretty much agree that was my first guess YAY step in right direction! now to get all information I can My question is this small resistor could set this entire thing off as it has so far? Where can i find a replacement resistor. I can solder it but im worried about getting wrong size etc. Edited December 6, 2008 by MrAtari2600 Quote Link to comment Share on other sites More sharing options...
TwiliteZoner Posted December 6, 2008 Share Posted December 6, 2008 Camera has been dead sorry on no response for a while I noticed in the picture that the machine is still plugged in. When you start working on this, you really need to remove that power cord. Quote Link to comment Share on other sites More sharing options...
+poobah Posted December 6, 2008 Share Posted December 6, 2008 I dont have this style of 1040 power supply handy, its hard to tell from the picture, but it looks like there used to be a cap to the right of R8. Quote Link to comment Share on other sites More sharing options...
Noelio Posted December 6, 2008 Share Posted December 6, 2008 R8 could be blown as a result of something else or vice versa. I think it might be a symptom not a cause. I'd consider a new power supply just to be safe. Quote Link to comment Share on other sites More sharing options...
MrAtari2600 Posted December 7, 2008 Author Share Posted December 7, 2008 I was looking again and Read your guys responses, The cord was not hooked up sorry aha, it was just plugged in on that end the other end was out of the wall the second i had the problem R8 IS FOR SURE blown up as well as another two R102 and R 101 have black spots resembling like R 8 So im guessing theres something a tad bit bigger, better safe then sorry! Thanks for your guys help i appreciate it endlessly! If somebody has a 1040ST P/S for sale or able to sell or redo mine PLEASE contact me via this forum & Or PM Im pretty sure my basic knowledge wouldn't span far. I need to start reading books again to get bit smarter heh. Thanks again everyone and have a great day Quote Link to comment Share on other sites More sharing options...
+Stephen Moss Posted December 8, 2008 Share Posted December 8, 2008 R8 IS FOR SURE blown upas well as another two R102 and R 101 have black spots resembling like R 8 So im guessing theres something a tad bit bigger, I assume that you have removed these and measured their resistance in comarison to the indicated value and are not just assming that as in the photo R8 looks OK although the board underneath it is cooked it may have been due to a previous fault that has since been repaired. The resistors look like standard metal file 0.6W, body size is about 8-10mm x 2-3mm. I don't have any circuit diagrams to hand but IIRC it is switch mode power supply so the capacitor and chopper transistor have probably died as one dieing usually kills the other if you can find a circuit diagram online any good TV repair shop should be able to fix it if you can not find a replacement or repair it yourself. Quote Link to comment Share on other sites More sharing options...
