rcamp48 Posted May 29, 2022 Share Posted May 29, 2022 Just now, IndusGT said: So glad to see this is not forgotten. I just found all of the source code in the program, they use multi-nodes as multiple R: devices, all of the .MOD files are Basic XE files, I will post the video that I posted in a new thread here, plus a few files ..... Emulating this will be tough on the Fujinet as the program opens multi channels to many modems, I assume a Multi IO device of some sort. And all of the .MOD files are really Basic XE module files , there is a MAINPRM.MOD file , I will upload the unmodified ascii version of it , you will see what I mean: every .MOD file refers to multi R: devices, it could be done with modems and port numbers? Puff BBS Listings.mp4 mainprm.bas Quote Link to comment Share on other sites More sharing options...
AtariGeezer Posted May 29, 2022 Share Posted May 29, 2022 (edited) @rcamp48 Russ, you should try this Puff BBS version that I patched 4 years ago... I think you still need the dongle for it, not sure if I modified the MOE to skip the "CKECK TRIGGER" routine or not? Edited May 29, 2022 by AtariGeezer Quote Link to comment Share on other sites More sharing options...
BillC Posted May 29, 2022 Share Posted May 29, 2022 1 hour ago, rcamp48 said: Emulating this will be tough on the Fujinet as the program opens multi channels to many modems, I assume a Multi IO device of some sort. As this BBS software is from CSS/Bob Puff I think it more probable that the device was a Black Box rather than an MIO, it has all the capabilities except for RAMdisk. There was also a floppy board upgrade that allowed connecting up to 4 disk drives. Use of Multiplexers was also likely, with each multiplexer node being used for different R: ports. Quote Link to comment Share on other sites More sharing options...
+DjayBee Posted May 29, 2022 Share Posted May 29, 2022 35 minutes ago, AtariGeezer said: I think you still need the dongle for it If someone tells me in which file(s) to look for, I can take a crack at it (pun intended). Quote Link to comment Share on other sites More sharing options...
AtariGeezer Posted May 29, 2022 Share Posted May 29, 2022 (edited) 16 minutes ago, DjayBee said: If someone tells me in which file(s) to look for, I can take a crack at it (pun intended). These are some Dis6502(older version) wrk files that I was going through back then. Fakemoe.wrk Puff.wrk Waitml.wrk WAITML.OBJ PUFBBS.COM FAKEMOE.COM puff.equ Puffbbs.arc.exe Puffbbs.arc.wrk Edited May 29, 2022 by AtariGeezer 1 Quote Link to comment Share on other sites More sharing options...
+bf2k+ Posted May 29, 2022 Share Posted May 29, 2022 9 hours ago, rcamp48 said: if there was a way to write Spartados 3.3 Pro to the 16 meg file without ruining the contents, I would be all for it, then we could run the autobat file. COPY X33A.DOS Dx: BOOT Dx:X33A.DOS Quote Link to comment Share on other sites More sharing options...
Mathy Posted May 29, 2022 Share Posted May 29, 2022 Hello guys Bob Puff's/CSS's BBS used the multiplexer! Absolutely, 100% sure, no guess! Sincerely Mathy (who logged into the CSS BBS "more than ones" way back when) 1 Quote Link to comment Share on other sites More sharing options...
rcamp48 Posted May 29, 2022 Share Posted May 29, 2022 9 hours ago, BillC said: As this BBS software is from CSS/Bob Puff I think it more probable that the device was a Black Box rather than an MIO, it has all the capabilities except for RAMdisk. There was also a floppy board upgrade that allowed connecting up to 4 disk drives. Use of Multiplexers was also likely, with each multiplexer node being used for different R: ports. Is there any possibility of getting a Multiplexor these days? I mean this must be a rare item. Quote Link to comment Share on other sites More sharing options...
BillC Posted May 29, 2022 Share Posted May 29, 2022 Just now, rcamp48 said: Is there any possibility of getting a Multiplexor these days? I mean this must be a rare item. @Stephen J. Cardenacquired the rights to the multiplexer from Bob Puff, his website lists it as SOLD OUT! http://www.realdos.net/mux.html Quote Link to comment Share on other sites More sharing options...
rcamp48 Posted May 29, 2022 Share Posted May 29, 2022 6 minutes ago, BillC said: @Stephen J. Cardenacquired the rights to the multiplexer from Bob Puff, his website lists it as SOLD OUT! http://www.realdos.net/mux.html He also mentions that if there is enough interest in the Multiplexor he will make a second run, with Puff BBS being a real possibility of being restored I would be interested in a multiplxor. Russ Quote Link to comment Share on other sites More sharing options...
rcamp48 Posted May 29, 2022 Share Posted May 29, 2022 5 hours ago, bf2k+ said: COPY X33A.DOS Dx: BOOT Dx:X33A.DOS Thanks, I will do this later on this afternoon, and I have created a Mega directory that contains everything Puff BBS related all in one place, if there is any interest in this I will post the link here..... Russ Quote Link to comment Share on other sites More sharing options...
rcamp48 Posted May 29, 2022 Share Posted May 29, 2022 I now have a bootable disk atr for Puff BBS if that helps anyone , will work on it more this afternoon, was able to configure Altira with an MIO but not a black box , I am missing the firmware for the black box, once I figure out how to configure and access an emulated black box I can set it up on Altirra. Here is the new bootable Puff BBS atr : PuffBBS Bootable Disk.atr 2 Quote Link to comment Share on other sites More sharing options...
IndusGT Posted May 29, 2022 Author Share Posted May 29, 2022 1 hour ago, rcamp48 said: I now have a bootable disk atr for Puff BBS if that helps anyone , will work on it more this afternoon, was able to configure Altira with an MIO but not a black box , I am missing the firmware for the black box, once I figure out how to configure and access an emulated black box I can set it up on Altirra. Here is the new bootable Puff BBS atr : PuffBBS Bootable Disk.atr 15.87 MB · 1 download Mathy's page has a bunch of roms for the black box, attached is the most recent one he says should work in an emulator, hope that helps bbrom216.rom 2 Quote Link to comment Share on other sites More sharing options...
oo7 Posted June 2, 2022 Share Posted June 2, 2022 You know off topic but on topic in the 90s i had a blackbox, it died. (Also i was a kid younger atarian) I got ahold of bob puff sent it to him to have it repaired. He sent me a new latest revision black box and didnt charge me. real nice guy. saw his name and other than memory of using bob term i remember this. I thought it was awesome then and i still think it was awesome of him today! 5 Quote Link to comment Share on other sites More sharing options...
rcamp48 Posted August 6, 2022 Share Posted August 6, 2022 Bump ***** Has anyone got this to work on Altirra ????? I am going to try tonight or this morning as it will be , I have the rom for the black box and have an idea how to configure it...... maybe by tomorrow I will have something.... Russ Quote Link to comment Share on other sites More sharing options...
rcamp48 Posted August 24, 2022 Share Posted August 24, 2022 I have got this semi working with Altirra , the Black Box has been completely emulated. Quote Link to comment Share on other sites More sharing options...
