ClassicGMR Posted February 24, 2009 Share Posted February 24, 2009 (edited) I picked up a ColecoVision cheap from eBay and it works perfectly but the controllers are flaky. - One works ok but it is hard to make it go up. The right trigger won't fire but the left trigger works fine. - The second controller goes in all directions easily and works great except neither triggers fire. I am hoping someone can supply a good, tested set fairly cheap. However if you are able to repair controllers I can send these to you for evaluation. Thanks! Edited February 24, 2009 by ClassicGMR Quote Link to comment Share on other sites More sharing options...
