fibrewire Posted May 1, 2011 Share Posted May 1, 2011 Not mine. You might want these too: 1984 Corvus Service Manual for H-Series Hard Drives Item: eBay Auction -- Item Number: 200557892682 1983 Corvus Hard Drive General Tech Info Manual Item: eBay Auction -- Item Number: 200557892100 I've had my eye on them for months now. But at those prices, I'd rather just use the PDFs I posted earlier in this thread. Someday though I'll get them - I don't think there is a demand for Corvus stuff Quote Link to comment Share on other sites More sharing options...
fibrewire Posted May 12, 2011 Share Posted May 12, 2011 Do you have image files of those available? I would like to try to see if it is possible to add Corvus support to the Atari800 emulator. As soon as I get a SIO2PC from someone, I'll post disk images of all the Corvus disks. Quote Link to comment Share on other sites More sharing options...
fibrewire Posted May 13, 2011 Share Posted May 13, 2011 Corvus Systems Disk Drive - OEM Replacement Power Supply This is the exact same power supply used inside the hard drive. Same manufacturer, same rating, new part. Power-One CP510-A International Series (Several models available) Verify that the PSU covers 100V - 240V AC input with manual switching & fused connection - also 5V & 12V DC output with surge capability. eBay Auction -- Item Number: 120712017375 Quote Link to comment Share on other sites More sharing options...
fibrewire Posted May 13, 2011 Share Posted May 13, 2011 Corvus Systems Disk Drive - OEM Replacement Case Fan This is the exact same case fan used inside the hard drive. Same manufacturer, same rating, new part. Rotron Biscuit Model BT2AI (Several models available) Verify that the fan operates in the 100-130 Volt range, also verify the bottom right rounded corner has a tab with 2 prongs on it. eBay Auction -- Item Number: 180660908007 Quote Link to comment Share on other sites More sharing options...
fibrewire Posted May 13, 2011 Share Posted May 13, 2011 Corvus Systems Disk Drive - OEM Replacement Hard Disk This is the exact same hard disk used inside the hard drive. Same manufacturer, same rating, new part. International Memories Inc. Model No. 5012H (Several models available) Verify that your Corvus system is NOT an extremely early 'Revision C' version because the 'Rev C' use a non-standard single cable that carries both control and data signals instead of the normal MFM setup using 34-pin control and 20-pin data. If you do have a 'Rev C' drive, good luck finding a replacement! eBay Auction -- Item Number: 310025250775 Quote Link to comment Share on other sites More sharing options...
fibrewire Posted June 28, 2011 Share Posted June 28, 2011 Not mine. You might want these too: 1984 Corvus Service Manual for H-Series Hard Drives Item: eBay Auction -- Item Number: 200557892682 1983 Corvus Hard Drive General Tech Info Manual Item: eBay Auction -- Item Number: 200557892100 I bought them Quote Link to comment Share on other sites More sharing options...
