+Zeptari Posted September 23, 2009 Share Posted September 23, 2009 Quick question..... how much hard drive space dose disk 2 take up? Can i install disk 2 to my hard drive then insert disk 1, and leave it in. and then access all of halo:odst and the multiplayer maps all at once? i looked all over the internet and didn't find any info... -rick Quote Link to comment Share on other sites More sharing options...
+Zeptari Posted September 23, 2009 Share Posted September 23, 2009 nevermind..... i found it, from joystick.com: Should I install either game disc on my hard drive? While both game discs can be installed on an Xbox 360 hard drive, only Disc One was optimized for installation (a mere 3.5 GB). (Note: Disc Two should not be installed, as doing so will hinder online performance.) There's no clear benefit to installing Disc One aside from slightly reduced load times. For example, you can not run the Disc One content off of your hard drive using Disc Two in the system tray, which would eliminate the need for disc swapping. I think the setup stinks!!! I was hoping on installing one of the disks and leaving the other disk in the tray. like it's explained above.... Quote Link to comment Share on other sites More sharing options...
