+Larry Posted December 31, 2009 Share Posted December 31, 2009 (edited) In another thread, "support for APE time downloader." was mentioned. I vaguely remember something called "APETIME." But I don't think (as a MyDos user) that I ever knew anything about it. I've looked through the Win APE GUI, but see nothing there about "Time." I also looked through the APE for Dos manual and found APETIME.COM mentioned implying that it is a utility for Sparta 3.2G. But when I looked on my my 3.2G distribution disk, I found no such utility. What I'm hoping is that APETIME.COM is a utility for APE that takes the time/date from the PC and makes it available to the Atari -- via SIO download to set the time/date in Sparta (SDX). Searching through the SDX manual, I find no reference to APETIME. Can anyone shed any light on this? Can it be used with SDX (and registered WinAPE)? Thanks, Larry Edited December 31, 2009 by Larry Quote Link to comment Share on other sites More sharing options...
+bf2k+ Posted December 31, 2009 Share Posted December 31, 2009 In another thread, "support for APE time downloader." was mentioned. I vaguely remember something called "APETIME." But I don't think (as a MyDos user) that I ever knew anything about it. I've looked through the Win APE GUI, but see nothing there about "Time." I also looked through the APE for Dos manual and found APETIME.COM mentioned implying that it is a utility for Sparta 3.2G. But when I looked on my my 3.2G distribution disk, I found no such utility. What I'm hoping is that APETIME.COM is a utility for APE that takes the time/date from the PC and makes it available to the Atari -- via SIO download to set the time/date in Sparta (SDX). Searching through the SDX manual, I find no reference to APETIME. Can anyone shed any light on this? Can it be used with SDX (and registered WinAPE)? Thanks, Larry That's exactly what it is - I use it on both SDX and SD3. It should be on your APE CD or maybe Steve has it on his site. It is one of Steve's programs. If you don't have it, PM me. Quote Link to comment Share on other sites More sharing options...
+Larry Posted December 31, 2009 Author Share Posted December 31, 2009 Thanks! That's exactly what it is - I use it on both SDX and SD3. It should be on your APE CD or maybe Steve has it on his site. It is one of Steve's programs. If you don't have it, PM me. Quote Link to comment Share on other sites More sharing options...
cas Posted January 9, 2010 Share Posted January 9, 2010 The SIO2USB has a similar protocol to read the date and time from the device and set the SpartaDOS date/time. If anyone is interested, here is the code: 01000 .LI OFF 01010 ********************** 01020 ** ** 01030 ** SPARTA DOS TIME ** 01040 ** UTILITY FOR ** 01050 ** SIO2USB ** 01060 ** (C) 2008 ABBUC ** 01070 ** LICENSE: GPLv3 ** 01080 ** ** 01090 ** P: C. Strotmann ** 01100 ** H: T. Grasel ** 01110 ** H. Reminder ** 01120 ** E. Puetz ** 01130 ** ** 01140 ** VERSION 1.00 ** 01150 ** ** 01160 ********************** 01170 .LI OFF 01180 ; 01190 DOSVEC = $0A 01200 ZPF0 = $F0 01210 ZPF1 = ZPF0+1 01220 INITAD = $2E2 01230 DDEVIC = $300 01240 HATABS = $31A 01250 SDBASE = $700 01260 SDKRNL = $703 01270 SDDEV = $761 01280 SDDATE = $77B 01290 SDTIME = SDDATE+3 01300 PORTB = $D301 01310 EDITRV = $E400 01320 SIOV = $E459 01330 VSETTD = $FFC3 01340 ------------------------------ 01350 .OR $5000 01360 .OF D:S2UTIME.COM 01370 ------------------------------ 01380 RETURN RTS 01390 ------------------------------ 01400 START 01410 JSR COUTINIT 01420 JSR BANNER 01430 JSR GETTIME 01440 BMI SIOERROR 01450 JSR TESTDATA 01460 JSR DETECTDOS 01470 JMP EXIT 01480 ------------------------------ 01490 ERRORMSG 01500 JSR PRINT 01510 .HX FD ; Beep 01520 .AS "Error: " 01530 .HX EA 01540 RTS 01550 ------------------------------ 01560 SIOERROR 01570 JSR ERRORMSG 01580 JSR PRINT 01590 .AS "during SIO Communication" 01600 .HX EA 01610 JMP EEXIT 01620 ------------------------------ 01630 DATAERROR 01640 JSR ERRORMSG 01650 JSR PRINT 01660 .AS "wrong or incomplete data recieved" 01670 .HX EA 01680 JMP EEXIT 01690 ------------------------------ 01700 EEXIT 01710 JSR PRINT 01720 .HX 9B 01730 .AS "Date/Time not set!" 01740 .HX 9BEA 01750 JMP TODOS 01760 ------------------------------ 01770 BANNER 01780 JSR PRINT 01790 .AS "SIO2USB DATE/TIME UTILITY v1.0" 01800 .HX 9B 01810 .AS "(C) 2008 ABBUC/RAF" 01820 .HX 9BEA 01830 RTS 01840 ------------------------------ 01850 DETECTDOS 01860 LDY #0 01870 LDA SDBASE,Y 01880 CMP #'S 01890 BNE ISREAL 01900 INY 01910 INY 01920 INY 01930 LDA SDBASE,Y 01940 CMP #'B 01950 BEQ BEWEDOS 01960 ; IS ORIGINAL SPARTADOS 01970 JSR PRINT 01980 .AS "Sparta DOS" 01990 .HX EA 02000 JSR DETECTED 02010 JMP SETTIME 02020 BEWEDOS 02030 JSR PRINT 02040 .AS "BW-DOS" 02050 .HX EA 02060 JSR DETECTED 02070 JSR PRINT 02080 .HX 9BEA 02090 JMP SETTIMEBW 02100 ISREAL 02110 CMP #'R 02120 BNE NOSPARTA 02130 JSR PRINT 02140 .AS "REALDOS" 02150 .HX EA 02160 JSR DETECTED 02170 JMP SETTIME 02180 NOSPARTA 02190 JSR PRINT 02200 .AS "No SPARTA compatible DOS" 02210 .HX EA 02220 JSR DETECTED 02230 LDA #$9B 02240 JSR COUT 02250 JMP EEXIT 02260 ------------------------------ 02270 DETECTED 02280 JSR PRINT 02290 .AS " detected" 02300 .HX EA 02310 RTS 02320 ------------------------------ 02330 COUTINIT 02340 LDY #$1E 02350 .1 LDA HATABS,Y 02360 CMP #'E 02370 BEQ .3 02380 DEY 02390 DEY 02400 DEY 02410 BPL .1 02420 JMP .2 02430 .3 LDA HATABS+1,Y 02440 STA ZPF0 02450 LDA HATABS+2,Y 02460 STA ZPF1 02470 LDY #7 02480 LDA (ZPF0),Y 02490 STA COUT2+1 02500 DEY 02510 LDA (ZPF0),Y 02520 STA COUT1+1 02530 .2 RTS 02540 ------------------------------ 02550 COUT 02560 TAX 02570 COUT2 LDA #$F2 02580 PHA 02590 COUT1 LDA #$AF 02600 PHA 02610 TXA 02620 RTS 02630 ------------------------------ 02640 PRINT 02650 PLA 02660 STA ZPF0 02670 PLA 02680 STA ZPF1 02690 .1 INC ZPF0 02700 BNE .2 02710 INC ZPF1 02720 .2 LDX #0 02730 LDA (ZPF0,X) 02740 CMP #$EA 02750 BEQ .3 02760 JSR COUT 02770 JMP .1 02780 .3 JMP (ZPF0) 02790 ------------------------------ 02800 ISXL 02810 LDY #$1B 02820 LDA (DOSVEC),Y 02830 CMP #$FF 02840 BEQ .1 02850 JSR PRINT 02860 .AS " under ROM (XL/XE)" 02870 .HX 9BEA 02880 CLC 02890 RTS 02900 .1 JSR PRINT 02910 .AS " in main RAM" 02920 .HX 9BEA 02930 SEC 02940 RTS 02950 ------------------------------ 02960 GETTIME 02970 LDX #$0B 02980 .1 LDA READRTC,X 02990 STA DDEVIC,X 03000 DEX 03010 BPL .1 03020 JMP SIOV 03030 ------------------------------ 03040 TESTDATA 03050 LDA BUF 03060 CMP #6 03070 BNE .3 03080 LDA BUF+7 03090 CMP #$FF 03100 BEQ .2 03110 .3 JMP DATAERROR 03120 ; CONVERT BCD -> DEC 03130 .2 LDX #5 03140 .1 LDA BUF+1,X 03150 AND #$F0 03160 LSR 03170 LSR 03180 STA ZPF0 03190 LSR 03200 ADC ZPF0 03210 SBC BUF+1,X 03220 EOR #$FF 03230 STA BUF+1,X 03240 DEX 03250 BPL .1 03260 ; 03270 LDX #2 03280 LDY #$0F 03290 .4 LDA BUF+4,X 03300 STA (DOSVEC),Y 03310 DEY 03320 DEX 03330 BPL .4 03340 ; 03350 LDY #$10 03360 LDA BUF+3 03370 STA (DOSVEC),Y 03380 INY 03390 LDA BUF+2 03400 STA (DOSVEC),Y 03410 INY 03420 LDA BUF+1 03430 STA (DOSVEC),Y 03440 RTS 03450 ------------------------------ 03460 SETTIME 03470 JSR ISXL 03480 LDA PORTB 03490 PHA 03500 AND #$FE 03510 STA PORTB 03520 JSR VSETTD 03530 PLA 03540 STA PORTB 03550 RTS 03560 ------------------------------ 03570 SETTIMEBW 03580 JMP ($708) 03590 ; FALLTHROUGH 03600 ------------------------------ 03610 EXIT 03620 JSR PRINT 03630 .AS "Date/Time set" 03640 .HX 9BEA 03650 ; FALLTHROUGH 03660 ------------------------------ 03670 TODOS 03680 JMP (DOSVEC) 03690 ------------------------------ 03700 READRTC 03710 .HX 71000240 03720 .DA BUF 03730 .HX 07008000 03740 ------------------------------ 03750 BUF .HX 00000000 03760 .HX 00000000 03770 ------------------------------ 03780 .OR INITAD 03790 .DA START 03800 ------------------------------ Quote Link to comment Share on other sites More sharing options...
cas Posted January 9, 2010 Share Posted January 9, 2010 Here is the SIO information for APETIME SIO Command: 45 93 EE A0 Pufferlength: 6 Bytes Result in Buffer: DDMMYYHHMMSS APETIME for Sparta DOS is attached. apetime.com.zip 1 Quote Link to comment Share on other sites More sharing options...
+Larry Posted January 9, 2010 Author Share Posted January 9, 2010 Thanks, Carsten! Nice to see how it works. -Larry Here is the SIO information for APETIME SIO Command: 45 93 EE A0 Pufferlength: 6 Bytes Result in Buffer: DDMMYYHHMMSS APETIME for Sparta DOS is attached. 1 Quote Link to comment Share on other sites More sharing options...
