A78 header changes
GroovyBee
On 4/6/2023 at 4:20 PM, SainT said:
devices with 1MB of RAM (7800GD, DF, etc)
Just to clarify that the DragonFly cart can support a full 1MB ROM + RAM image and runs the original BadApple demo OK.
Practically speaking, anyone creating a 1MB + RAM image probably doesn't need every single bank and can leave the last switchable bank empty so that it runs on the GD.
Is the DF 1mb + extra ram? I had assumed (possibly incorrectly?) that it was just 1mb and it had used a page from the 1mb rom area for the ram at 4000. I just wanted to standardise which page would be left for ram use rather than leave it floating.
A couple more requests for header flag additions :
TV type details:
bit 2 = 0:single region, 1:multi-region
For physical hardware the user can be warned if the incorrect region of ROM is trying to be run with the current header, but for more recent multi-region ROMs there will always be one (usually PAL) region which will get an incorrect warning. Having a multi region flag will be useful to remove this warning. The PAL/NTSC flag could then be used as a preferred region for emulators.
Controller type byte details:
12 = Mega7800
For the 7800GD I can use this to switch to an alternate break method and allow homebrew to use the majority of the megadrive pad buttons for their own purposes. I will reserve the mode button in combination with other buttons to activate GD related features.
  • Like 4
  • 1 month later...
I'm adding the ADPCM streamed audio functionality I developed for Rikki and Vikki as a stand-alone audio feature. To enable it use bit 5 of the audio mapper field. It adds a command register at $420 to allow you to control the playback, pause and volume of ADPCM encoded audio tracks. It currently only cohabits with the TIA for audio mixing, but there's no reason not to allow all other combinations of POKEY, YM, TIA, etc... other than I'm running very very low on FPGA space. :)
I have a 7800GD / Mega7800 features sample ROM with source which will be added to GitHub as a demonstration of how to use everything in your own games and it should all be integrated into 7800basic in due course. :)
I've updated the header detail post to include this information:
@RevEng if you wouldn't mind doing the honors on the 7800header code to add the extra feature set bit when you get a chance, please! :) The only limit is this feature doesn't cohabit with the Souper Mapper. It basically implements the same functionality but at a different address space to allow more modular use.
  • Like 4
I've added the adpcm@420 flag to 7800header, and added a corresponding comment to the a78_asm_header file.
  • 1 month later...
10 minutes ago, Eagle said:
Hmm 🤔
$460 is the base address. Same as all the other listed devices?
Actually I’m not sure where that quote is from now! I thought it was edited from my header post, now I’m not so sure… 😆
Never mind, I see it’s from the 7800 header asm, I see your point! 😆
Edited by SainT
  • 1 month later...
Slowly I need to book some space for SN and SN2 cart before we move further.
Also we need bit for our SN cart family :D
This is already implemented in our dev MiSTer core
Thanks
SN Cart2 Registers
POINTER_BASE 	equ	   $400
MEM0DATA		equ 	   POINTER_BASE			;Memory data in/out
MEM1DATA		equ 	   POINTER_BASE + $01	;Memory data in/out
MEM2DATA		equ 	   POINTER_BASE + $02	;Memory data in/out
MEM3DATA		equ 	   POINTER_BASE + $03	;Memory data in/out
MEM1ADR0		equ	   POINTER_BASE + $04	;Memory address 0
MEM1ADR1		equ	   POINTER_BASE + $05	;Memory address 1
MEM1ADR2		equ	   POINTER_BASE + $06	;Memory address 2
MEM1ADR3		equ	   POINTER_BASE + $07	;Memory address 3
MEM2ADR0		equ	   POINTER_BASE + $08	;Memory address 0
MEM2ADR1		equ	   POINTER_BASE + $09	;Memory address 1
MEM2ADR2		equ	   POINTER_BASE + $0A	;Memory address 2
MEM2ADR3		equ	   POINTER_BASE + $0B	;Memory address 3
MEM3ADR0		equ	   POINTER_BASE + $0C	;Memory address 0
MEM3ADR1		equ	   POINTER_BASE + $0D	;Memory address 1
MEM3ADR2		equ	   POINTER_BASE + $0E	;Memory address 2
MEM3ADR3		equ	   POINTER_BASE + $0F	;Memory address 3
MEM0ADR0		equ	   POINTER_BASE + $10	;Memory address 0
MEM0ADR1		equ	   POINTER_BASE + $11	;Memory address 1
MEM0ADR2		equ	   POINTER_BASE + $12	;Memory address 2
MEM0ADR3		equ	   POINTER_BASE + $13	;Memory address 3
MEM0INC			equ 	   POINTER_BASE + $14	;Memory address increment
MEM1INC			equ 	   POINTER_BASE + $15	;Memory address increment
MEM2INC			equ 	   POINTER_BASE + $16	;Memory address increment
MEM3INC			equ 	   POINTER_BASE + $17	;Memory address increment
MEM0DEC			equ 	   POINTER_BASE + $18	;Memory address decrement
MEM1DEC			equ 	   POINTER_BASE + $19	;Memory address decrement
MEM2DEC			equ 	   POINTER_BASE + $1A	;Memory address decrement
MEM3DEC			equ 	   POINTER_BASE + $1B	;Memory address decrement
SN76489 	equ $43F
SN76489dual 	equ $43E
; FPGA VGM player for YM2151, YM2612, SN76489
VGMREG	equ $462; --  register number VGMPlayer
VGMDAT	equ $463; --  read/write register VGMPlayer
;VGMREG
;$00		- vgm_control - bit7 = on/off play, bit6 = on/off loop
;$01 - $04 - 32bit vgm_play_address (to vgmdat)
;$05 - $08 - 32bit vgm_loop_address (to vgmdat)
YM2612BASE equ	$464		;($464-$467)
MemReg 		equ $FFFF	;bit 0 - lower/upper 16KB ram, bit 1 - mirror ram A8, bit 2 - mirror ram A9, bit 3 - reserved, bit 4 - mirror A8/A9 only for lower 8KB ram
;************* 4KB banks* ***********************
$8000 -> write 0-255 (select 4KB bank from 0-255)
$9000 -> write 0-255 (select 4KB bank from 0-255)
$A000 -> write 0-255 (select 4KB bank from 0-255)
$B000 -> write 0-255 (select 4KB bank from 0-255)
$C000 -> write 0-255 (select 4KB bank from 0-255)
$D000 -> write 0-255 (select 4KB bank from 0-255)
$E000 -> write 0-255 (select 4KB bank from 0-255)
$Fxxx - it's fix
Edited by Eagle
The standard we've hashed out in the past was to officially allocate mappers when there is either a released game, or a prerelease game with final hardware prototyped and release is imminent.
For dev purposes you can just self-assign a mapper index in the v4 header. (N.B. We don't have any v3 header bits left.)
... and I thought 16 bits would be plenty. :)
