jschultzpedersen Posted February 16 Share Posted February 16 Hi I downloaded the newest version of RBX2034 from your mail of Feb. 15th. I have a problem with the COPY command. It produces a SYNTAX error as you can see from the included screen dump. Am I using the command as it is supposed to be used? Or is this a bug. regards Jesper Quote Link to comment Share on other sites More sharing options...
+Torrax Posted February 16 Share Posted February 16 COPY <start line> - <end line>, <new start line>, <increment> COPY 10-20,50,10 Quote Link to comment Share on other sites More sharing options...
Asmusr Posted February 16 Share Posted February 16 1 hour ago, Torrax said: COPY <start line> - <end line>, <new start line>, <increment> COPY 10-20,50,10 It still doesn't work in RXB 2024. Quote Link to comment Share on other sites More sharing options...
+Torrax Posted February 16 Share Posted February 16 I was hoping RXB used the same syntax as SXB (Super Extended Basic). Guess not! Quote Link to comment Share on other sites More sharing options...
Asmusr Posted February 16 Share Posted February 16 6 minutes ago, Torrax said: I was hoping RXB used the same syntax as SXB (Super Extended Basic). Guess not! I tested that it worked in RXB 2020, but it didn't work in RXB 2024. So you're right, it should work like you describe it. Quote Link to comment Share on other sites More sharing options...
+Torrax Posted February 16 Share Posted February 16 It doesn't work in RXB 2023 either. Something got broken in his updates. Quote Link to comment Share on other sites More sharing options...
RXB Posted February 18 Share Posted February 18 On 2/15/2024 at 11:02 PM, jschultzpedersen said: Hi I downloaded the newest version of RBX2034 from your mail of Feb. 15th. I have a problem with the COPY command. It produces a SYNTAX error as you can see from the included screen dump. Am I using the command as it is supposed to be used? Or is this a bug. regards Jesper OMG yea you are right the missing code * * Code for new commands DEL, COPY, and MOVE * * NOTICE !!!!! * RAM BANK 2 CHANGED AS FOLLOWS----- * 7D1B changed from >08 to >0B * 7D35 changed from >08 to >0C I have the old code of >0008 at both locations when it should be >000B at >701B and >000C at >7D35 Quote Link to comment Share on other sites More sharing options...
RXB Posted February 18 Share Posted February 18 On 2/16/2024 at 11:56 AM, Torrax said: COPY <start line> - <end line>, <new start line>, <increment> COPY 10-20,50,10 Yea need to fix this as I used old back up code from Original XB Quote Link to comment Share on other sites More sharing options...
RXB Posted February 18 Share Posted February 18 On 2/16/2024 at 1:45 PM, Torrax said: I was hoping RXB used the same syntax as SXB (Super Extended Basic). Guess not! Yea need to fix this as I used old back up code from Original XB Quote Link to comment Share on other sites More sharing options...
JasonACT Posted February 18 Share Posted February 18 (edited) 25 minutes ago, RXB said: I have the old code of >0008 at both locations when it should be >000B at >7D1B and >000C at >7D35 I hex-edited my download ....... and ....... it works Edited February 18 by JasonACT 1 Quote Link to comment Share on other sites More sharing options...
RXB Posted February 18 Share Posted February 18 48 minutes ago, JasonACT said: I hex-edited my download ....... and ....... it works FIXED AND UPDATED RXB2024A RXB 2024A.zip Quote Link to comment Share on other sites More sharing options...
RXB Posted February 18 Share Posted February 18 FIXED AND UPDATED RXB2024A RXB 2024A.zip 3 Quote Link to comment Share on other sites More sharing options...
Gary from OPA Posted February 19 Share Posted February 19 On 2/18/2024 at 1:59 AM, RXB said: FIXED AND UPDATED RXB2024A RXB 2024A.zip 41.65 MB · 8 downloads since i got my pgram card working, i want to load this in as module on it. trying to figure out what files i need to load it, i see the classic99 and finalgrom 99 folder, but the other folders are not clear, which one is like g/k format or is there one? 2 Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted February 19 Share Posted February 19 The Classic99 file contains 5 GROMs in the "G" file and 3 ROMS in the "C" file. Whatever else you have to add (headers, extra dummy ROM, etc.) depend on the requirements of your device. 1 Quote Link to comment Share on other sites More sharing options...
Gary from OPA Posted February 20 Share Posted February 20 1 hour ago, atrax27407 said: The Classic99 file contains 5 GROMs in the "G" file and 3 ROMS in the "C" file. Whatever else you have to add (headers, extra dummy ROM, etc.) depend on the requirements of your device. Yeah seems I going to have to code up a converter or a new loader program. Everything these days online is in classic99 or finalgrom99 format nothing left in the old g/k format which makes trying to use old tech my pgram or my g/k harder. Quote Link to comment Share on other sites More sharing options...
RickyDean Posted February 20 Share Posted February 20 (edited) Here are some module disks that are probably csave files, they may contain some GK usable files? On 2/19/2024 at 8:02 PM, Gary from OPA said: Yeah seems I going to have to code up a converter or a new loader program. Everything these days online is in classic99 or finalgrom99 format nothing left in the old g/k format which makes trying to use old tech my pgram or my g/k harder. I see that I forgot to leave something here: MODULE01.zip Edited February 21 by RickyDean Quote Link to comment Share on other sites More sharing options...
jschultzpedersen Posted February 21 Share Posted February 21 (edited) Hi I ran into another possible bug in the 2024A version using the current version of Classic99. The CALL SCREEN works for me with the standard single numeric parameter. But the extended versions do not. See included Screen dump. Never mind the extra space. It happens without the space too. regards Jesper Edited February 21 by jschultzpedersen An extra space in the dump. Quote Link to comment Share on other sites More sharing options...
Gary from OPA Posted February 21 Share Posted February 21 On 2/19/2024 at 8:14 PM, RickyDean said: Here are some module disks that are probably csave files, they may contain some GK usable files? I see that I forgot to leave something here: MODULE01.zip 2.6 MB · 1 download thanks i will check it out later on. -- today, been a early spring cleaning for me, since the weather warmed up, i got the office windows open and washing the hardwood floors. 1 Quote Link to comment Share on other sites More sharing options...
jschultzpedersen Posted February 22 Share Posted February 22 Hi Another small issue with RXB 2024A. The command CALL CHARSET(ALL) works all the way to character 159. But it does not reset character 30 though it says so at page C3 in the docs. Quote Link to comment Share on other sites More sharing options...
RXB Posted February 23 Share Posted February 23 On 2/15/2024 at 11:02 PM, jschultzpedersen said: Hi I downloaded the newest version of RBX2034 from your mail of Feb. 15th. I have a problem with the COPY command. It produces a SYNTAX error as you can see from the included screen dump. Am I using the command as it is supposed to be used? Or is this a bug. regards Jesper Looks like you are using RXB2024 instead of the new updated RXB2024A Quote Link to comment Share on other sites More sharing options...
RXB Posted February 23 Share Posted February 23 On 2/21/2024 at 12:39 PM, jschultzpedersen said: Hi I ran into another possible bug in the 2024A version using the current version of Classic99. The CALL SCREEN works for me with the standard single numeric parameter. But the extended versions do not. See included Screen dump. Never mind the extra space. It happens without the space too. regards Jesper Dang you are right I used a older version of CALL SCREEN so looks like another release is needed! 1 Quote Link to comment Share on other sites More sharing options...
RXB Posted February 23 Share Posted February 23 22 hours ago, jschultzpedersen said: Hi Another small issue with RXB 2024A. The command CALL CHARSET(ALL) works all the way to character 159. But it does not reset character 30 though it says so at page C3 in the docs. Dang you are right I used a older version of CALL SCREEN so looks like another release is needed! Make a note of this too. 1 Quote Link to comment Share on other sites More sharing options...
RXB Posted February 23 Share Posted February 23 I was told that RXB 2024A has a problem with CALL CHARSET(ALL) and CALL SCREEN("ON") and CALL SCREEN("OFF") So I fixed these in RXB 2024B Now I have noticed a ERROR in RXB 2020 and 2021 and 2022 that no one ever noticed so thanks for anyone that is debugging RXB for me. (Atrax27407 I always give credit where credit is due, again thanks) RXB 2024B.zip 5 Quote Link to comment Share on other sites More sharing options...
jschultzpedersen Posted February 24 Share Posted February 24 Hi I have a suggestion for a change to RXB2024B. I have worked my way through most of the manual by now and not encountered more issues. But I noticed that while it is possible to change screen mode by manipulating the VDP write registers from basic with the POKER(7,244,1,240) command, it is not supported by commands like VPUT - where you cannot go beyond 32 horizontally when placing the string on the display, and by HCHAR or VCHAR - which do not allow more than 768 repeats and folds back to the top to stay within the range of addresses used by GRAPHICS mode 1 for the display, if you start somewhere down the display. If the limit was raised for these commands sufficiently to support the TEXT mode - probably with a test to see if the range is compatible with the current mode, the TEXT mode could be made more useful to a basic user. The same might be done for CALL CLEAR, which only clears the first 768 addresses in VDP. Of course there might be a problem, if someone started moving the start address of the display away from address 0. POKER can do all sort of things to the VDP setup, I suppose. But then they are on their own! 1 Quote Link to comment Share on other sites More sharing options...
RXB Posted February 27 Share Posted February 27 Ran some more timing tests: 90 ! ROUTINE SET UP SPRITES TEST SO NOT PART OF TIMING ROUTINE 100 CALL CLEAR 110 OPEN #1:"CLOCK" 120 INPUT #1:A$,B$,C$ 130 FOR C=1 TO 10000 140 ! ROUTINE INSERTED HERE TO TEST 150 NEXT C 160 INPUT #1:D$,E$,F$ 170 PRINT A$,D$:B$,E$,C$,F$ 180 END XB XB3 XBGEM MyarcXB2 RXB command ------------------------------------------------------------------------- 11:5 9:10 3:11 5:6 3:21 CALL CHAR(65,"FFFFFFFF") 2:57:15 34:18 5:33 6:19 4:42 CALL CHAR(65,Z$) ! LENGTH 64 11:32 7:19 4:1 5:14 4:5 CALL CHARPAT(65,Z$) 32:44 33:6 1:11:47 5:1 4:8 CALL CHARSET 3:49 3:29 3:43 8:48 3:41 CALL CLEAR 6:25 6:25 6:24 7:22 6:19 CALL COINC(#1,20,20,8,Z) 3:0 3:0 3:0 4:3 3:4 CALL COINC(ALL,Z) 4:33 4:15 4:15 5:4 4:24 CALL COLOR(1,2,8) 3:9 3:9 3:9 4:6 2:36 CALL DELSPRITE(#1) 6:22 6:23 6:22 4:18 5:33 CALL DELSPRITE(ALL) 6:5 6:6 6:6 6:0 6:1 CALL DISTANCE(#1,20,20,Z) 6:6 3:7 4:10 5:9 4:2 CALL GCHAR(1,1,Z) 4:11 3:1 4:5 5:5 4:17 CALL HCHAR(1,1,65) 4:37:35 4:39:17 9:31 14:12 7:33 CALL HCHAR(1,1,65,768) 5:0 3:2 5:6 6:43 5:7 CALL JOYST(1,X,Y) 4:37 3:25 4:38 5:16 5:2 CALL KEY(1,K,S) 4:4 4:4 4:4 5:13 4:17 CALL LOCATE(#1,20,20) 2:17 2:11 2:14 3:45 2:14 CALL MAGNIFY(1) 4:44 4:44 4:44 6:42 4:41 CALL MOTION(#1,20,20) 3:8 3:17 3:17 5:27 3:4 CALL PATTERN(#1,66) 5:22 5:22 5:31 5:25 5:9 CALL POSITION(#1,X,Y) 3:44 2:11 2:6 4:3 2:17 CALL SCREEN(5) 5:9 5:8 5:9 6:30 5:7 CALL SPRITE(#1,65,2,10,10) 3:55 3.0 4:5 5:5 4:17 CALL VCHAR(1,1,65) 4:30:22 4:30:41 18:29 18:11 21:3 CALL VCHAR(1,1,65,768) 10:2 8:13 10:1 6:18 10:3 DISPLAY AT(9,9):C 21:10 13:41 11:49 11:29 12:13 DISPLAY AT(9,9):RND 8:22 6:43 8:22 6:17 8:21 DISPLAY AT(9,9):"TEST" 12:13 5:3 7:16 3:8 3:9 A=RND ****************************************************************************** * RXB COMMANDS DISPLAY DISPLAY DISPLAY DISPLAY 5:6 CALL HPUT(11,11,C) DISPLAY DISPLAY DISPLAY DISPLAY 7:12 CALL HPUT(11,11,RND) DISPLAY DISPLAY DISPLAY DISPLAY 4:29 CALL HPUT(11,11,"TEST") 14:17 10:10 15:42 16:16 11:50 CALL JOYLOCATE(1,X,Y,8,8,#1,RW,CL,K) GOTO 15:53 10:20 15:3 16:1 10:2 CALL JOYMOTION(1,X,Y,#1,9,9,K) GOTO 7:7 5:11 7:7 11:3 9:33 CALL ONKEY("ABC",1,K,S) GOTO 1,2,3 N/A N/A N/A N/A 7:26 CALL COLLIDE(#1,20,20,8,X,Y) N/A N/A 10:31 N/A 11:39 CALL MOVES("RR",1024,8192,12288) ****************************************************************************** 80 ! JOYLOCATE FOR OTHERS 90 CALL SPRITE(#1,65,2,20,20) :: XL,YL=20 100 CALL CLEAR 110 OPEN #1:"CLOCK" 120 INPUT #1:A$,B$,C$ 130 FOR C=1 TO 10000 140 CALL JOYST(1,X,Y) :: CALL LOCATE(#1,X+XL,Y+YL) :: CALL KEY(1,K,S) :: IF K=18 THEN 150 150 NEXT C 160 INPUT #1:D$,E$,F$ 170 PRINT A$,D$:B$,E$,C$,F$ 180 END ***************************************************************************** 80 ! JOYMOTION FOR OTHERS 90 CALL SPRITE(#1,65,2,20,20) :: XL,YL=20 100 CALL CLEAR 110 OPEN #1:"CLOCK" 120 INPUT #1:A$,B$,C$ 130 FOR C=1 TO 10000 140 CALL JOYST(1,X,Y) :: CALL MOTION(#1,X*9,Y*9) :: CALL KEY(1,K,S) :: IF K=18 THEN 150 150 NEXT C 160 INPUT #1:D$,E$,F$ 170 PRINT A$,D$:B$,E$,C$,F$ 180 END **************************************************************************** 80 ! ONKEY FOR OTHERS 90 CALL SPRITE(#1,65,2,20,20) :: XL,YL=20 100 CALL CLEAR 110 OPEN #1:"CLOCK" 120 INPUT #1:A$,B$,C$ 130 FOR C=1 TO 10000 140 CALL KEY(1,K,S) :: IF K=65 THEN 150 ELSE IF K=66 THEN 150 ELSE IF K=67 THEN 150 ELSE 150 150 NEXT C 160 INPUT #1:D$,E$,F$ 170 PRINT A$,D$:B$,E$,C$,F$ 180 END **************************************************************************** 1 Quote Link to comment Share on other sites More sharing options...
