UNIXcoffee928 Posted July 10, 2010 Share Posted July 10, 2010 I recently acquired a lot of (2) Wico & (5) Atari CX22 trackballs. I'd like to use the CX22s as input devices on my 800, for controlling sound variables, and for experiments with sound & timing, which should be pretty cool, since the 800 has four joystick ports... I kinda wonder if anybody has ever plugged four trackballs into an 800... since its a little odd to have more than one or two. I am aware that the Wico trackballs only work in "Joystick Mode". The Atari CX22s work in either "Joystick Mode" or "Trackball Mode". I'd like to experiment with "Trackball Mode", and could use some code examples, and technical info, to get started. I've searched though the forum, but mostly only found 5200 trackball programming info. Also, does anyone know if Missile Command's (Ctrl-T) Trackball Mode supports (2) trackballs? I'm busy soaking the bearings in some WD-40, right now. Once they're cleaned up, I'll apply a treatment of a heavier bearing oil, wipe 'em down, then get them all back together. Thanks, in advance! Quote Link to comment Share on other sites More sharing options...
Rybags Posted July 10, 2010 Share Posted July 10, 2010 They should be the same as using an Atari ST mouse... I'm sure I've played Missile Command using one. If not, it would be a different combination of bits for each axis (like the Amiga) but I'm fairly sure they retained the same combinations between the trackball and ST mouse. There's a few examples around - someone devised a nice efficient algorithm that can easily adapt between ST and Amiga mouse, IIRC it even worked OK at 50 or 60 samples per second. If you're not happy with only VBlank sampling, then you just add a DLI or 2 or 3 at relevant timing intervals to improve the precision. Quote Link to comment Share on other sites More sharing options...
a8isa1 Posted July 10, 2010 Share Posted July 10, 2010 I recently acquired a lot of (2) Wico & (5) Atari CX22 trackballs. I'd like to use the CX22s as input devices on my 800, for controlling sound variables, and for experiments with sound & timing, which should be pretty cool, since the 800 has four joystick ports... I kinda wonder if anybody has ever plugged four trackballs into an 800... since its a little odd to have more than one or two. I am aware that the Wico trackballs only work in "Joystick Mode". The Atari CX22s work in either "Joystick Mode" or "Trackball Mode". I'd like to experiment with "Trackball Mode", and could use some code examples, and technical info, to get started. I've searched though the forum, but mostly only found 5200 trackball programming info. Also, does anyone know if Missile Command's (Ctrl-T) Trackball Mode supports (2) trackballs? I'm busy soaking the bearings in some WD-40, right now. Once they're cleaned up, I'll apply a treatment of a heavier bearing oil, wipe 'em down, then get them all back together. Thanks, in advance! This should be more than enough to get you started. http://www.atariarchives.org/cfn/05/07/0037.php In a somewhat related area I've always wondered if the guts of a Kensington Expert Mouse could be converted to be an Atari trackball. Anyone have a schematic for the CX22? - Steve Sheppard Quote Link to comment Share on other sites More sharing options...
Rybags Posted July 10, 2010 Share Posted July 10, 2010 Article and driver can be found on Mathy's site http://www.mathyvannisselroy.nl/special%20stuff.htm No idea if it's the one I was thinking of earlier. Checked some of the other links from earlier threads here but they were no good. I'm sure the efficient one I mentioned was only a few dozen lines of code with some tables buried in it. Quote Link to comment Share on other sites More sharing options...
Mathy Posted July 10, 2010 Share Posted July 10, 2010 Hello Rybags Sounds like that's the one on my site. It's written by John Maris of Pokey Magazin and ANG software fame. sincerely Mathy Quote Link to comment Share on other sites More sharing options...
Rybags Posted July 10, 2010 Share Posted July 10, 2010 I think heaven was asking about this a couple of years ago... he's probably got the one I was talking about. Quote Link to comment Share on other sites More sharing options...
atariksi Posted July 10, 2010 Share Posted July 10, 2010 I've searched though the forum, but mostly only found 5200 trackball programming info. Where's that link to A5200 trackball programming? Perhaps, you didn't mis-spell it when you searched. You need to mis-spell trackball as Trak-Ball. Quote Link to comment Share on other sites More sharing options...
+CharlieChaplin Posted July 10, 2010 Share Posted July 10, 2010 Well, here are some drivers and test programs (no games this time!) for the Atari trackball. Not sure if they are of any use for you, but maybe they are... -Andreas Koch. trakball_drivers.zip Quote Link to comment Share on other sites More sharing options...
Mathy Posted July 10, 2010 Share Posted July 10, 2010 Hello guys Look here for Florian Dingler's hardwaretester. It will test the Trakball too. I don't know if it's (Turbo)BASIC or if it's assembler with source code or whatever. sincerely Mathy Quote Link to comment Share on other sites More sharing options...
+CharlieChaplin Posted July 10, 2010 Share Posted July 10, 2010 Hello guys Look here for Florian Dingler's hardwaretester. It will test the Trakball too. I don't know if it's (Turbo)BASIC or if it's assembler with source code or whatever. sincerely Mathy Well, you can find this program (and others) on the attached disk above... -Andreas Koch Quote Link to comment Share on other sites More sharing options...
Mathy Posted July 10, 2010 Share Posted July 10, 2010 Hello Andreas When I read this thread you hadn't entered you message yet. When I posted mine, I saw yours. Since I was to lazy to check if it was in the file you mentioned, I didn't feel like deleting my message. sincerely Mathy Quote Link to comment Share on other sites More sharing options...
atariksi Posted July 11, 2010 Share Posted July 11, 2010 Hello Andreas When I read this thread you hadn't entered you message yet. When I posted mine, I saw yours. Since I was to lazy to check if it was in the file you mentioned, I didn't feel like deleting my message. sincerely Mathy I guess the mouse ARC file is the one for the trackball on your website. My set-up doesn't open those files. Don't see any A5200 trackball programming stuff anywhere. Quote Link to comment Share on other sites More sharing options...
Fox-1 / mnx Posted July 11, 2010 Share Posted July 11, 2010 Anyone have a schematic for the CX22? http://www.atariage.com/2600/archives/schematics/Schematic_2600_CX22_High.html Quote Link to comment Share on other sites More sharing options...
Mathy Posted July 11, 2010 Share Posted July 11, 2010 Hello Atariksi I guess the mouse ARC file is the one for the trackball on your website. My set-up doesn't open those files. Don't see any A5200 trackball programming stuff anywhere. There is no 5200 stuff on my site. We were taking about the XL/XE mouse code, which could serve as a starting point for a TrakBall routine. Check out MOUSE.ARC, MOUSEINT.ARC and STM18BIT.ARC. BTW you can find plug ins for WinZip etc. or even different Unzippers that will UnArc whatever you want to UnArc. sincerely Mathy Quote Link to comment Share on other sites More sharing options...
Roydea6 Posted July 11, 2010 Share Posted July 11, 2010 (edited) Arc2zip command line program will convert ARC files to ZIP files and then can be opened with any unzipper. ARC2ZIP.zip I have been using it a lot since Vista windows. Suxxxks Just drop into your System32 folder or any path folder. Or this one for 64bit windows 7 vista arc.zip Edited July 11, 2010 by rdea6 Quote Link to comment Share on other sites More sharing options...
a8isa1 Posted July 11, 2010 Share Posted July 11, 2010 Anyone have a schematic for the CX22? http://www.atariage...._CX22_High.html Not sure I quite understand it but thanks Fox-1! - Steve Sheppard Quote Link to comment Share on other sites More sharing options...
atariksi Posted July 12, 2010 Share Posted July 12, 2010 Hello Atariksi I guess the mouse ARC file is the one for the trackball on your website. My set-up doesn't open those files. Don't see any A5200 trackball programming stuff anywhere. There is no 5200 stuff on my site. We were taking about the XL/XE mouse code, which could serve as a starting point for a TrakBall routine. Check out MOUSE.ARC, MOUSEINT.ARC and STM18BIT.ARC. BTW you can find plug ins for WinZip etc. or even different Unzippers that will UnArc whatever you want to UnArc. sincerely Mathy Okay, there were two points-- one was that trackball info (for A8) was actually in the MOUSE.ARC since there's nothing about trackball mentioned on that site. And second point is that original poster claimed that A5200 trackball programming was available, but I see the reverse. I don't see any A5200 trackball programming info on any site when I do a search. Quote Link to comment Share on other sites More sharing options...
atariksi Posted July 12, 2010 Share Posted July 12, 2010 I recently acquired a lot of (2) Wico & (5) Atari CX22 trackballs. I'd like to use the CX22s as input devices on my 800, for controlling sound variables, and for experiments with sound & timing, which should be pretty cool, since the 800 has four joystick ports... I kinda wonder if anybody has ever plugged four trackballs into an 800... since its a little odd to have more than one or two. I am aware that the Wico trackballs only work in "Joystick Mode". The Atari CX22s work in either "Joystick Mode" or "Trackball Mode". I'd like to experiment with "Trackball Mode", and could use some code examples, and technical info, to get started. I've searched though the forum, but mostly only found 5200 trackball programming info. Also, does anyone know if Missile Command's (Ctrl-T) Trackball Mode supports (2) trackballs? I'm busy soaking the bearings in some WD-40, right now. Once they're cleaned up, I'll apply a treatment of a heavier bearing oil, wipe 'em down, then get them all back together. Thanks, in advance! This should be more than enough to get you started. http://www.atariarchives.org/cfn/05/07/0037.php In a somewhat related area I've always wondered if the guts of a Kensington Expert Mouse could be converted to be an Atari trackball. Anyone have a schematic for the CX22? - Steve Sheppard That link contains error in the source code VBITBALL.SRC. It seems like they missed a "BNE" instruction. Quote Link to comment Share on other sites More sharing options...
a8isa1 Posted July 12, 2010 Share Posted July 12, 2010 Anyone have a schematic for the CX22? http://www.atariage...._CX22_High.html Not sure I quite understand it but thanks Fox-1! - Steve Sheppard Well I took a simpler approach than attempting to modify a Kensington trackball. Instead I simply replaced the proprietary connector of an old Logitech Bus Mouse with a female DB9 making the Logitech mouse ST compatible. (No I didn't figure out how to do this myself. I found a couple of documents on the internet) - Steve Sheppard Quote Link to comment Share on other sites More sharing options...
Rybags Posted July 12, 2010 Share Posted July 12, 2010 (edited) I would think that the 5200 trackball uses the pot inputs, probably in some sort of "Delta" mode like the analog Commodore mouse. Alternatively, you could probably have some system that uses keypress returns, although doesn't the 5200 only allow something like a 4x3 matrix? I was close: http://www.atarihq.com/danb/52trakball.htm It was designed to appear to the system as a normal 5200 joystick so that games would not have to be specifically written to support the trak-ball. Rolling the ball faster in one direction corresponds to pushing an analog joystick further in the corresponding direction. The board has two circuits that act as tachometers with digital inputs and analog outputs. Edited July 12, 2010 by Rybags Quote Link to comment Share on other sites More sharing options...
tep392 Posted July 12, 2010 Share Posted July 12, 2010 I would think that the 5200 trackball uses the pot inputs, probably in some sort of "Delta" mode like the analog Commodore mouse. Alternatively, you could probably have some system that uses keypress returns, although doesn't the 5200 only allow something like a 4x3 matrix? I was close: http://www.atarihq.com/danb/52trakball.htm It was designed to appear to the system as a normal 5200 joystick so that games would not have to be specifically written to support the trak-ball. Rolling the ball faster in one direction corresponds to pushing an analog joystick further in the corresponding direction. The board has two circuits that act as tachometers with digital inputs and analog outputs. The cx5200 Field Service Manual has a very detailed description of how the trackball works. The only thing special that the program code needs to do is pull one of the connector pins low to perform a calibration for the ball not moving. Quote Link to comment Share on other sites More sharing options...
atariksi Posted July 12, 2010 Share Posted July 12, 2010 I would think that the 5200 trackball uses the pot inputs, probably in some sort of "Delta" mode like the analog Commodore mouse. Alternatively, you could probably have some system that uses keypress returns, although doesn't the 5200 only allow something like a 4x3 matrix? I was close: http://www.atarihq.com/danb/52trakball.htm It was designed to appear to the system as a normal 5200 joystick so that games would not have to be specifically written to support the trak-ball. Rolling the ball faster in one direction corresponds to pushing an analog joystick further in the corresponding direction. The board has two circuits that act as tachometers with digital inputs and analog outputs. The cx5200 Field Service Manual has a very detailed description of how the trackball works. The only thing special that the program code needs to do is pull one of the connector pins low to perform a calibration for the ball not moving. I haven't seen code-- just schematics and engineering articles. If I connect Atari 5200 trackball to Atari 800, and do: 1 ? PADDLE(0),PADDLE(1):GOTO 1 It does not show correct position of where ball is so it seems you need to do something else. Quote Link to comment Share on other sites More sharing options...
tep392 Posted July 12, 2010 Share Posted July 12, 2010 I would think that the 5200 trackball uses the pot inputs, probably in some sort of "Delta" mode like the analog Commodore mouse. Alternatively, you could probably have some system that uses keypress returns, although doesn't the 5200 only allow something like a 4x3 matrix? I was close: http://www.atarihq.com/danb/52trakball.htm It was designed to appear to the system as a normal 5200 joystick so that games would not have to be specifically written to support the trak-ball. Rolling the ball faster in one direction corresponds to pushing an analog joystick further in the corresponding direction. The board has two circuits that act as tachometers with digital inputs and analog outputs. The cx5200 Field Service Manual has a very detailed description of how the trackball works. The only thing special that the program code needs to do is pull one of the connector pins low to perform a calibration for the ball not moving. I haven't seen code-- just schematics and engineering articles. If I connect Atari 5200 trackball to Atari 800, and do: 1 ? PADDLE(0),PADDLE(1):GOTO 1 It does not show correct position of where ball is so it seems you need to do something else. You should be able to read ball speed, not position. There is a signal line, don't remember the pin number, that you need to pull high so the track ball is not in calibration mode. I know it works because I once built a cx22 - 5200 trackball adapter on a bread board and it worked with my 800xl with the paddle inputs. I built it based on the schematic from the field manual. Quote Link to comment Share on other sites More sharing options...
UNIXcoffee928 Posted July 13, 2010 Author Share Posted July 13, 2010 With regard to the 5200 trackball references, I believe that i did searches for: trackball track-ball track ball trakball trak-ball trak ball In the "Advanced" section of the forum search feature (to the right of the Search entry field, at the top of this page.). Then I went through all of the pages listed, incrementally. Quote Link to comment Share on other sites More sharing options...
UNIXcoffee928 Posted July 13, 2010 Author Share Posted July 13, 2010 Just an update. WD-40 alone lets the rollers spin faster, but MUCH noisier, and has a horrible feel. Additionally, as a skater, I will tell you that WD-40 is OK as a quick fix, but will wear out bearings. I like to clean bearings in an old glass coffee jar, using WD-40, though. Swish them in circles like a mini centrifuge for a while, then let them sit hours or days, swishing once in a while. to get all the crud out. I found that WD-40 cleaning, then soaking overnight in a "3-in-1" oil treatment works great on the trackball rollers. They roll a bit slower, but feel waaay better, very precise, like a "Brand New" feel. Just be sure to wipe off the excess oil from the exterior of the bearings before you reassemble. I have had excellent luck with skateboard bearings by cleaning with WD-40, as described above, then putting the bearings into a ziplock filled a third of the way with Castrol 20W50 motor oil, and letting them sit overnight. Powell makes the best bearing grease, for their Swiss bearings, so if you have a budget, get that. I've been having a fun time learning to play "Defender" with the trackball. It has got to be one of the most difficult shoot-em-up games ever made. Frustrating, but very fun & addictive. Quote Link to comment Share on other sites More sharing options...
