Ze_ro Posted September 15, 2010 Share Posted September 15, 2010 Important Note: This weeks competition is over and no futher scores will be accepted. That nasty old troll, Ollie Ogre, is at it again. He is chasing poor Daisy Damsel all across the neighborhood! So what are you waiting for, hero? Get out there and stop him! You have the blueprint (plans) for the only contraption that can knock him off. All you need now are the parts with which you build it and they're hidden in the houses of the neighborhood. What you don't need are the bombs you may pick up and encounters with fiendish Fuzzy Wuzzy! But if you complete your contraption in time you'll be able to stop Ollie and save Daisy! So get a move on already! Daisy's counting on you! Game Information Game Name: Blueprint Released By: CBS Electronics, 1983 Left Difficulty: N/A Right Difficulty: N/A Game Mode: Default Post your scores right here in this thread, and I will add them to the list. Remember to play the game with the recommended game mode and difficulty settings as shown above so that your scores will be consistent with everyone elses. The deadline for posting scores is Wednesday September 22nd at 1:00 AM (Central Time, UTC-6). Challenges Design a Contraption - Design a contraption that could be used to save your girl from monsters (draw something, make something out of Lego, write a story about how it works, anything) and you'll get 3 bonus points! The crazier and more Rube-Goldbergian the better!Scrabbler15 [+3] JacobZu7zu7 [+3] Miss 2600 [+3] toymailman [+3] Current High Scores 20,000 (Scrabbler15) [+11]20,000 (toymailman) [+11] 12,000 (JacobZu7zu7) [+10] 11,775 (Deteacher) [+9] 6750 (roadrunner) [+8] 3275 (keilbaca) [+7] 2850 (oyamafamily) [+6] 2775 (ClassicGMR) [+5] 2625 (Miss 2600) [+4] 275 (doctorclu) [+3] Best Tips JacobZu7zu7 [+2] TwinGalaxies Top 3 (Game 1, Difficulty B)264,825 (Scott Stilphen) 198,050 (Mike K Morrow) 115,200 (Rodrigo Lopes) (Emulator) Current Standings toymailman [71] Scrabber15 [62] Jifremok [54] JacobZu7zu7 [49] Deteacher [46] oyamafamily [43] zylon [43] roadrunner [24] ClassicGMR [19] LarcenTyler [17] HatefulGravey [17] pis [14] Chuck D. Head [14] Pioneer4x4 [12] keilbaca [10] Zoyx [8] MrJimbo [8] satan165 [7] Miss 2600 [6] Mister VCS [5] 4Ks [4] SeaGtGruff [4] ed1475 [2] pacmanplayer [2] Austin [1] rmaerz [1] littleman jack [1] MIKE5200 [1] Scoring Points in Blueprint Attach a Part - 100 points Defuse a Bomb - 25 points Knocking off OllieLevel 1 - 200 points Level 2 - 400 points Level 3 - 600 points Level 4 - 800 points Level 5 and up - 1000 points Note: You are awarded bonus points for using less power on your shots Hints and Tips The Manual As always, you really should read the manual. In case you don't have the manual, AtariAge has a typed copy and a scanned copy available online. Here are the hints it provides: Save your speed supply for times when you'll really need it like maneuvering through the houses on the upper blocks of the neighborhood or when you unexpectedly pick up a bomb with a short fuse. Once you pick up a part, you'll be able to avoid Fuzzy Wuzzy by ducking into any nearby house. As long as you have the part you won't be able to pick up anything else. Blueprint is, most of all, a memory game. Younger players (as well as absent-minded ones) might find it easier to play as a team. One member moves through the houses while the other member keeps track of where they've already been. JacobZu7zu7 The Neighborhoods First round, [3] pieces of the contraption are hidden, you should be able to memorize where the parts are being dropped off since there's only 3. Basically just run to each of those houses and complete contraption and the level. Second round, [5] hidden parts now... and this round is tricky.. pay CLOSE attention to what areas the pieces are hidden, you don't have to be exact, just be sure what part of the neighborhood has the 5 pieces, and try to memorize the where the last piece is as you don't want to forget suddenly after doing well finding the others parts easily. By recalling where the last piece is it helps you finish up the level smoothly. Third Round +, From now on, there are [8] missing pieces/parts of the contraption...the best way I done these levels so far, is by memorizing where the first 2 or 3 missing parts are, and also, the last 2 parts. also I try memorizing which houses have no parts at all, which is only 2 houses! so I avoid them and start my search, quickly tracking down the first few parts, and maybe making a few guesses in mid-game. A few errors seem inevitable, but with some luck or if an easy pattern develops for you, you can do well and finish without losing a life! IT'S PROBABLY MORE IMPORTANT TO REMEMBER WHICH 'CORRECT' HOUSES YOU HAVE ALREADY BEEN TO AND FINISHED SEARCHING, THEN IT IS TO MEMORIZE THE HOUSES THAT HAVE PIECES IN THEM! BY KNOWING WHERE YOU HAVE BEEN HELPS QUITE A BIT IN THE LATER STAGE OF THE GAME, AND IT WILL PREVENT YOU FROM GOING TO THE SAME PLACES OVER AND OVER AND HOPEFULLY NOT LOSE CRITICAL TIME IN SAVING DAISY. THE TOP HOUSES ARE TOUGHEST TO RUN BACK DOWN, AND DEFUSE A BOMB!SO TRY TO BE AWARE HOW MANY PIECES ARE HIDDEN UP THERE... MISTAKES MADE AT THE TOP HOUSES, SEEM TO BE THE MOST COSTLY OR TIME CONSUMING. Beginner tips, Practice , practice, practice... focus, focus, and relax! Read the whole manual. It gives you the idea of how to play and what to do. Pieces of the Contraption need to be completed in sequence from bottom to top. This is the only way, to advance you to shooting down Ollie. Ollie is chasing Daisy, and THAT Troll needs to be SHOT before you can advance to the next level... you have a Contraption to fire at him to save Daisy, you ONLY can save Daisy when all pieces of your Contraption are collected and placed in the "correct" order!Best and fastest use of the Contraption is by,... pulling the joystick up/away from you till you see the meter read (I) straight up (right top corner)...this means the weapon will fire directly upwards, and also seems the fastest... this aim works best for me, in shooting down Ollie. To hit Olle "most times" accurately, wait till Daisy is about to run across the screen, she will be near the edge of the left side, (with your contraption aimed UP) hit the fire button at the moment Daisy is about to cross the screen at the left, this should hit Ollie on his return to the middle... although Time differences in how fast or slow you completed the Contraption effects how accurate your timing is in hitting Ollie. YEAH, so make adjustments to this, you can move the Contraption left and right, but I found this no real help...as I memorized my aim and shot "straight down the middle", and I recommend that area to hit Ollie. Bombs, these need to be disposed at the BOMB PIT, the right corner of the screen, it's a red circle, put the Bomb in that red circle... moving diagonal to the bomb pit ACTUALLY SAVES TIME! So if the color of the bomb turns red, you should cut an angle holding the joystick down/right. Hit the pit right in the middle...till you hear the fuse go out! If you complete a level very quickly, you can dump off 3-5 bombs for about 50 to 200 points extra on your score. Only do this if you have good consistent aim against Ollie. Button pressing Hold the button down when you search the houses!! You will move at a much faster pace... though when the color reads RED, you have run outta' gas, and need to find the next part for you to become a quick mover again... and when you do... hold that button down! Fuzzy Wuzzy, one way you can escape him besides running away is, by hiding in one of the houses till he is gone, try to run to a save house with no bombs if you can, also use caution when you are near him, try to stop and check his movement before going on your way, he can double back and hit you sometimes. Scrabbler15 First, I numbered the houses in my mind like this - _1_2_3_ _4_5_6_ __8_9__ 7_____10 As the pieces are going in the houses, I count out loud each of the first five houses. I keep repeating the order of the first five houses while I watch where the other three pieces are going. I can usually get the last three pieces right without using the numbers. I found that if I count higher than five numbers, it's too many for me to remember to keep the order right. After I get the last three done, I call out the five numbers, e.g. One Three Six Seven Ten. Whatever the last number called out is where I go next. In the example, that would be Ten. Then I call out the four that are left and go to the last one, which now is Seven, and so on. A big advantage in getting the order right is that every piece placed adds to the 'green speed' time. So most of the round can be played at top speed. It also means getting to Ollie quicker, which brings me to the way I take the shot. I never add power to the gun. I take the shot at lowest power when Ollie passes under the left edge of the scoreboard at the top of the screen. Ollie will lap the screen twice and then run into the bullet. It also means maximum bonus points for the hit. --Zero Quote Link to comment Share on other sites More sharing options...
Miss 2600 Posted September 15, 2010 Share Posted September 15, 2010 I have Blue Print but I have never played it before. I don't think I've ever popped it in the console, so this one ought to be interesting for me. Quote Link to comment Share on other sites More sharing options...
keilbaca Posted September 15, 2010 Share Posted September 15, 2010 I have Blue Print but I have never played it before. I don't think I've ever popped it in the console, so this one ought to be interesting for me. Same here, I've never played it before. I'm looking forward to it. Quote Link to comment Share on other sites More sharing options...
Scrabbler15 Posted September 15, 2010 Share Posted September 15, 2010 Interesting game. 6550 Quote Link to comment Share on other sites More sharing options...
JacobZu7zu7 Posted September 16, 2010 Share Posted September 16, 2010 (edited) I know this game pretty well, played it quite a few times, 10 years ago. 6,875 NEW PERSONAL BEST, 8,625 I would have gotten more score, but ran into the red fuzzy wuzzy trying to defuse a bomb. Edited September 16, 2010 by JacobZu7zu7 Quote Link to comment Share on other sites More sharing options...
JacobZu7zu7 Posted September 16, 2010 Share Posted September 16, 2010 I have Blue Print but I have never played it before. I don't think I've ever popped it in the console, so this one ought to be interesting for me. Same here, I've never played it before. I'm looking forward to it. Wow, never played you two? It's not very rare, I think it's been released on Commodore as well as Colecovision. I thought about this game Blueprint yesterday, knowing that the 2600 HSC never played this one yet. I almost suggested it to Zero. :!: Hope you guys enjoy it, it's pretty fun... though difficult! as it's a mostly a memory game. I have 2 other common games in my head, which haven't been played here so far, they are OINK!, and STAR VOYAGER. Zero do you have a list of games that have, or haven't been played yet? Quote Link to comment Share on other sites More sharing options...
oyamafamily Posted September 16, 2010 Share Posted September 16, 2010 (edited) 2,850 for PARTICIPATION POINTS!! (I've never played Blueprint) :D Edited September 16, 2010 by oyamafamily Quote Link to comment Share on other sites More sharing options...
toymailman Posted September 16, 2010 Share Posted September 16, 2010 Zero do you have a list of games that have, or haven't been played yet? I have one that I will post later. I last updated it about Season 7 week 40-something. I'll bring it up to date and attach it. Quote Link to comment Share on other sites More sharing options...
ClassicGMR Posted September 16, 2010 Share Posted September 16, 2010 2,775 Wow... I forgot how much fun this game is. It's been a while since I loaded it up. Quote Link to comment Share on other sites More sharing options...
toymailman Posted September 16, 2010 Share Posted September 16, 2010 Here is the list I have put together to track the "HSC Unplayed Games". Note that some are not possible in the HSC as they are two-player only, or some other factor to disqualify them. I have also attached my Excel file that I periodically update to capture what has been played. HSC_GamesPlayed.xls Unplayed Games as of Season 8 - Week 6: Crypts of Chaos - 20th Century Fox M*A*S*H - 20th Century Fox Mega Force - 20th Century Fox Revenge of the Beefsteak Tomatoes - 20th Century Fox The Earth Dies Screaming - 20th Century Fox Worm War I - 20th Century Fox Pete Rose Baseball - Absolute Entertainment Title Match Pro Wrestling - Absolute Entertainment Tomcat: The F-14 Fighter Simulator - Absolute Entertainment Barnstorming - Activision Bridge - Activision Checkers - Activision Laser Blast - Activision Oink! - Activision Pitfall II: Lost Caverns - Activision Private Eye - Activision Sky Jinks - Activision Space Shuttle: A Journey into Space - Activision Tennis - Activision Tax Avoiders - American Videogame Mogul Maniac - Amiga Off Your Rocker - Amiga Surf's Up - Amiga Gauntlet - Answer Software Malagai - Answer Software Final Approach - Apollo Guardian - Apollo Racquetball - Apollo Shark Attack - Apollo Skeet Shoot - Apollo Space Cavern - Apollo Wabbit - Apollo 3-D Tic-Tac-Toe - Atari Air-Sea Battle - Atari Alpha Beam with Ernie - Atari Asterix - Atari Atari Video Cube - Atari Backgammon - Atari Basic Math - Atari Basic Programming - Atari Big Bird's Egg Catch - Atari Blackjack - Atari Brain Games - Atari Breakout - Atari Casino - Atari Championship Soccer - Atari Codebreaker - Atari Combat - Atari Concentration, A Game of - Atari Cookie Monster Munch - Atari Dark Chambers - Atari Demons to Diamonds - Atari Desert Falcon - Atari Double Dunk - Atari Flag Capture - Atari Football - Atari Hangman - Atari Haunted House - Atari Home Run - Atari Hunt & Score - Atari Math Gran Prix - Atari Maze Craze - Atari Miniature Golf - Atari Motorodeo - Atari Night Driver - Atari Off the Wall - Atari Oscar's Trash Race - Atari Outlaw - Atari Pele's Soccer - Atari Raiders of the Lost Ark - Atari RealSports Baseball - Atari RealSports Boxing - Atari RealSports Football - Atari RealSports Soccer - Atari RealSports Tennis - Atari RealSports Volleyball - Atari Rubik's Cube - Atari Secret Quest - Atari Sentinel - Atari Slot Machine - Atari Slot Racers - Atari Sorcerer's Apprentice - Atari Space War - Atari Sprintmaster - Atari Star Raiders - Atari Star Ship - Atari Street Racer - Atari Super Baseball - Atari Super Football - Atari Swordquest: Earthworld - Atari Swordquest: Fireworld - Atari Swordquest: Waterworld - Atari Track & Field - Atari Video Checkers - Atari Video Chess - Atari Video Olympics - Atari Warlords - Atari Xenophobe - Atari London Blitz - Avalon Hill Out of Control - Avalon Hill Assault - Bomb Great Escape - Bomb Wall Defender - Bomb Z-Tack - Bomb Berenstain Bears (Kid Vid) - Coleco Donkey Kong Junior - Coleco Smurfs Save the Day (Kid Vid) - Coleco Smurfs: Rescue in Gargamel's Castle - Coleco Cakewalk - CommaVid Cosmic Swarm - CommaVid Magicard - CommaVid Mines of Minos - CommaVid Room of Doom - CommaVid Stronghold - CommaVid Video Life - CommaVid Airlock - Data Age Bermuda Triangle - Data Age Bugs - Data Age SSSnake - Data Age Warplock - Data Age Tooth Protectors - DSD/Camelot California Games - Epyx Summer Games - Epyx Winter Games - Epyx Video Jogger - Exus Video Reflex - Exus Cruise Missile - Froggo Games Karate - Froggo Games Sea Hunt - Froggo Games Spiderdroid - Froggo Games Task Force - Froggo Games Atlantis II - Imagic Fire Fighter - Imagic Riddle of the Sphinx - Imagic Shootin' Gallery - Imagic Star Voyager - Imagic Trick Shot - Imagic Marine Wars - Konami Pooyan - Konami Spider Maze - K-Tel Vision Vulture Attack - K-Tel Vision Survival Run - Milton Bradley Armor Ambush - M-Network / Telegames Glacier Patrol - M-Network / Telegames International Soccer - M-Network / Telegames Night Stalker - M-Network / Telegames Quest for Quintana Roo - M-Network / Telegames Space Attack - M-Network / Telegames Star Strike - M-Network / Telegames Super Challenge Baseball - M-Network / Telegames Super Challenge Football - M-Network / Telegames Bachelor Party - Mystique Beat 'Em & Eat 'Em - Mystique Custer's Revenge - Mystique Fire Fly - Mythicon Sorcerer - Mythicon Star Fox - Mythicon Dice Puzzle - Panda Exocet - Panda Harbor Escape - Panda Sea Hawk - Panda Stuntman - Panda Tank Brigade - Panda Scuba Diver - Panda / Sancho James Bond 007 - Parker Brothers Mr. Do!'s Castle - Parker Brothers Sky Skipper - Parker Brothers Star Wars: Jedi Arena - Parker Brothers Strawberry Shortcake Musical Matchups - Parker Brothers Bachelor Party/Gigolo - Playaround Beat 'Em & Eat 'Em/Lady in Wading - Playaround Burning Desire/Bachelorette Party - Playaround General Retreat/Westward Ho - Playaround Jungle Fever/Knight on the Town - Playaround Philly Flasher/Cathouse Blues - Playaround Seamonster - Puzzy Space Tunnel - Puzzy Steeplechase - Sears Stellar Track - Sears Submarine Commander - Sears Sub Scan - Sega Up 'n Down - Sega Glib - Selchow & Richter/QDI Eli's Ladder - Simage Music Machine - Sparrow Bumper Bash - Spectravision China Syndrome - Spectravision Gas Hog - Spectravision Mangia - Spectravision Master Builder - Spectravision Tapeworm - Spectravision Dragonstomper - Starpath Escape from the Mindmaster - Starpath Frogger, The Official - Starpath Killer Satellites - Starpath Party Mix - Starpath Suicide Mission - Starpath Survival Island - Starpath Sword of Saros - Starpath Coconuts - Telesys Cosmic Creeps - Telesys Stargunner - Telesys King Kong - Tigervision Miner 2049er Vol. II - Tigervision River Patrol - Tigervision Springer - Tigervision Threshold - Tigervision BMX Airmaster - TNT Games Condor Attack - Ultravision Karate - Ultravision X-Man - Universal Gamex Entombed - VidTec / US Games M.A.D. - VidTec / US Games Picnic - VidTec / US Games Piece o' Cake - VidTec / US Games Raft Rider - VidTec / US Games Sneak 'N Peek - VidTec / US Games Towering Inferno - VidTec / US Games Word Zapper - VidTec / US Games Artillery Duel - Xonox Ghost Manor - Xonox Motocross Racer - Xonox Spike's Peak - Xonox Tomarc the Barbarian - Xonox Challenge - Zellers Inca Gold - Zellers Radar - Zellers Cosmic Corridor - Zimag Dishaster - Zimag I Want My Mommy - Zimag 1 Quote Link to comment Share on other sites More sharing options...
JacobZu7zu7 Posted September 16, 2010 Share Posted September 16, 2010 Nice list Toymailman, Worm War I hasn't been played yet?!! That game would work out great in the HSC. Quote Link to comment Share on other sites More sharing options...
Mister VCS Posted September 16, 2010 Share Posted September 16, 2010 (edited) Here is the list I have put together to track the "HSC Unplayed Games". Note that some are not possible in the HSC as they are two-player only, or some other factor to disqualify them. I have also attached my Excel file that I periodically update to capture what has been played. HSC_GamesPlayed.xls Unplayed Games as of Season 8 - Week 6: Mister VCS favorites: Tomcat: The F-14 Fighter Simulator - Absolute Entertainment Pitfall II: Lost Caverns - Activision Space Shuttle: A Journey into Space - Activision Asterix - Atari Demons to Diamonds - Atari Desert Falcon - Atari Night Driver - Atari Off the Wall - Atari RealSports Boxing - Atari Sorcerer's Apprentice - Atari Star Raiders - Atari Track & Field - Atari Xenophobe - Atari Donkey Kong Junior - Coleco Smurfs: Rescue in Gargamel's Castle - Coleco California Games - Epyx Summer Games - Epyx Winter Games - Epyx Star Voyager - Imagic Trick Shot - Imagic Pooyan - Konami Star Wars: Jedi Arena - Parker Brothers Gas Hog - Spectravision Mangia - Spectravision Frogger, The Official - Starpath not unplayed: season 1 week 22 Threshold - Tigervision not unplayed: season 4 week 68 BMX Airmaster - TNT Games Ghost Manor - Xonox Spike's Peak - Xonox Nice list! Thank you, toymailman! Edited September 16, 2010 by Mister VCS Quote Link to comment Share on other sites More sharing options...
oyamafamily Posted September 16, 2010 Share Posted September 16, 2010 (edited) OYAMAFAMILY'S FAVORITE GAMES - TOP 3 (in response to James Randall, the Toymailman): Dark Chambers - Atari Worm War 1 - 20th Century Fox Video Games Xenophobe - Atari Edited September 16, 2010 by oyamafamily Quote Link to comment Share on other sites More sharing options...
Zoyx Posted September 16, 2010 Share Posted September 16, 2010 Missing Decathlon... good game, but would have set some kind of rules about what is allowable for controllers. Define what is cheating or not. I would like to see Breakout, Killer Satellites, Suicide Mission, Pitfall 2 & Tapeworm. Quote Link to comment Share on other sites More sharing options...
oyamafamily Posted September 17, 2010 Share Posted September 17, 2010 SPECIAL NOTES FOR BLUEPRINT (The scores showed below DON'T COUNT!!!): 1) The score rolls over at 20,000 points, because the scoreboard has 4 and 1/2 digits. So, the maximum score is 19,995 points. 2) You earn a special bonus life at 20,000 points! 3) The hidden password is showed on screenshots attached below. Score: 18,800 (Note that there's 1 life remaining) Score: 20,300 (2 lives remaining, and "0300" displayed) Quote Link to comment Share on other sites More sharing options...
Zoyx Posted September 17, 2010 Share Posted September 17, 2010 An idea for another HSC - lifetime high score threads for individual games. - New sub-forum for this HSC - Start a new thread on a regular basis for a game with rules and settings. - Different moderator for each game. - High scores are ranked in the original post of the thread - Scores are time stamped. They are taken off the chart after 6 months or a year, forcing players to repost a score to get back in the rankings. Good idea? Too much work? Just plain silly? Quote Link to comment Share on other sites More sharing options...
roadrunner Posted September 17, 2010 Share Posted September 17, 2010 (edited) cool blueprint Edited September 22, 2010 by roadrunner Quote Link to comment Share on other sites More sharing options...
roadrunner Posted September 17, 2010 Share Posted September 17, 2010 OYAMAFAMILY'S FAVORITE GAMES - TOP 3 (in response to James Randall, the Toymailman): Dark Chambers - Atari Worm War 1 - 20th Century Fox Video Games Xenophobe - Atari Do we really want to spend a whole hour playing Dark Chambers? I rolled the score on that game once. I think it rolls at 99,900 Quote Link to comment Share on other sites More sharing options...
roadrunner Posted September 17, 2010 Share Posted September 17, 2010 (edited) 6,750 Blueprint was also released for the Atari 5200 Edited September 17, 2010 by roadrunner Quote Link to comment Share on other sites More sharing options...
JacobZu7zu7 Posted September 17, 2010 Share Posted September 17, 2010 SPECIAL NOTES FOR BLUEPRINT (The scores showed below DON'T COUNT!!!): 1) The score rolls over at 20,000 points, because the scoreboard has 4 and 1/2 digits. So, the maximum score is 19,995 points. 2) You earn a special bonus life at 20,000 points! 3) The hidden password is showed on screenshots attached below. Score: 18,800 (Note that there's 1 life remaining) Score: 20,300 (2 lives remaining, and "0300" displayed) WOW, just yesterday was you're first time playing this game. Great score. Don't jump the gun, roadrunner. It does say above the scores he posted, they (don't count) which probably means it's from a site... or a hacked game, and not a HSC entry, just some special notes, but it's some good info. PS, Those twin galaxie scores over 100ks... are "SICK!!!" I got 10,700 today. That might be my final score. Quote Link to comment Share on other sites More sharing options...
toymailman Posted September 17, 2010 Share Posted September 17, 2010 Good catches on the games list guys, thanks! I have plans to add homebrews to it eventually as well; maybe in a few weeks. Quote Link to comment Share on other sites More sharing options...
roadrunner Posted September 17, 2010 Share Posted September 17, 2010 (edited) Somehow i miss read that post. Edited September 22, 2010 by roadrunner Quote Link to comment Share on other sites More sharing options...
JacobZu7zu7 Posted September 17, 2010 Share Posted September 17, 2010 Somehow i miss read that post. LOL! remove the Dunce cap... it's happened to the best of us. I notice the deadline is Sept 8. Which was last wednesday lol. so that will be corrected by Zero to be, Sept. 22nd. I played Blueprint again today, tied exactly my '10,700' score, on the same round 'n same amount of pieces found. Quote Link to comment Share on other sites More sharing options...
JacobZu7zu7 Posted September 17, 2010 Share Posted September 17, 2010 OYAMAFAMILY'S FAVORITE GAMES - TOP 3 (in response to James Randall, the Toymailman): Dark Chambers - Atari Worm War 1 - 20th Century Fox Video Games Xenophobe - Atari Do we really want to spend a whole hour playing Dark Chambers? I rolled the score on that game once. I think it rolls at 99,900 Yeah lol... THAT game just goes on and on... and ON.... Rolling would be contagious! Quote Link to comment Share on other sites More sharing options...
keilbaca Posted September 17, 2010 Share Posted September 17, 2010 My two cents on the game. I don't like it. Just something about it, I dunno if its the limited run, or how fast it is for the boogey monster to get the girl, or something, but it just doesn't feel right. I got 2850 before I shut the game off. I'll give it a try this weekend, but eh. Not a big fan of the game. Quote Link to comment Share on other sites More sharing options...
