+therealbountybob Posted November 6, 2010 Share Posted November 6, 2010 From this forum I have the Atari User Magazines' Game disks as Spartados 3.2g images (180K) I want to get these onto my 1050 as enhanced density (130K) via APE. I have no clue how to use Spartados apart from the dir command :!: I need to be able to format 130K images and transfer files - to create two disks for each one before disk copying down to the 1050. How do I do this Quote Link to comment Share on other sites More sharing options...
olavese@online.no Posted November 6, 2010 Share Posted November 6, 2010 Should be a XINIT program, if I recall correctly to format the disks and you can COPY D1:*.* D2:*.* I believe. Not used Spartados in a long time, so I might be off. Think there was a copy utility too, try typing MENU maybe??? Quote Link to comment Share on other sites More sharing options...
+bf2k+ Posted November 6, 2010 Share Posted November 6, 2010 Should be a XINIT program, if I recall correctly to format the disks and you can COPY D1:*.* D2:*.* I believe. Not used Spartados in a long time, so I might be off. Think there was a copy utility too, try typing MENU maybe??? Correct... XINIT.COM to format and use the copy command provided above. I would not mess with menu as some versions of it did not work correctly. Quote Link to comment Share on other sites More sharing options...
+therealbountybob Posted November 7, 2010 Author Share Posted November 7, 2010 Tried xinit.com using altirra (disks mounted as r/w!) but get this: Think have tried options 1 & 5 with additional option 3 for 1050 double density - am not sure which I should use, but both give the error Tried X32G and X32F options from 3.2g disk. I tried to use an existing DOS2.5 1050 / 130K ATR as the destination disk image. I'm not attached to Spartados so if Spartados disks are DOS2.5 (or Mydos) compatible then can I transfer the files using a DOS boot disk Quote Link to comment Share on other sites More sharing options...
spookt Posted November 7, 2010 Share Posted November 7, 2010 (edited) Hmm, I just tried in Altirra and Atari800MacX. In Atari800MacX I create a new blank medium density 130Kb atr and mount it in drive 2. I can the format this with xinit from Sparta 3.2g without problems. In altirra I create a new medium density image, save it but it will not format with xinit. I can format it as a DOS 2 volume when booted from a DOS 2.5 disk but Sparta 2.3g returns error 8B which I think is device did not respond? Strange. SpartaDOS disks are not DOS 2 compatible although Sparta can read and write to DOS 2.x volumes. Edited November 7, 2010 by spookt Quote Link to comment Share on other sites More sharing options...
Roydea6 Posted November 7, 2010 Share Posted November 7, 2010 Tried xinit.com using altirra (disks mounted as r/w!) but get this: Think have tried options 1 & 5 with additional option 3 for 1050 double density - am not sure which I should use, but both give the error Tried X32G and X32F options from 3.2g disk. I tried to use an existing DOS2.5 1050 / 130K ATR as the destination disk image. I'm not attached to Spartados so if Spartados disks are DOS2.5 (or Mydos) compatible then can I transfer the files using a DOS boot disk Option 5 in the example is for Double Sided 40 tracks. The 1050 does not support is mode.. SpartaDOS can write to a DOS 2.X and MYDOS disk. So you would need to have a blank formated DOS disk in #2 and boot with Sparta disk and copy files from #1 to #2 Quote Link to comment Share on other sites More sharing options...
+therealbountybob Posted November 9, 2010 Author Share Posted November 9, 2010 Tried using Altirra and Atari800win+4.0 managed to get the latter to format but both kept saying file exists when copying so I gave up and copied down Spartados 3.2G to a real floppy. Have then managed to format a real disk and transfer the files using APE. Spartados question: when at the D1: prompt can you return to BASIC I've worked out ERASE, DIR and COPY. If I type BASIC it says Parameter Error Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted November 9, 2010 Share Posted November 9, 2010 Spartados question: when at the D1: prompt can you return to BASIC I've worked out ERASE, DIR and COPY. If I type BASIC it says Parameter Error I may be wrong, but I think: BASIC ON and BASIC OFF toggle internal BASIC. When BASIC is ON, the CAR command then runs it. Quote Link to comment Share on other sites More sharing options...
+bf2k+ Posted November 9, 2010 Share Posted November 9, 2010 I may be wrong, but I think: BASIC ON and BASIC OFF toggle internal BASIC. When BASIC is ON, the CAR command then runs it. Nope you are NOT wrong! Those are the correct commands for 3.x Quote Link to comment Share on other sites More sharing options...
sloopy Posted November 9, 2010 Share Posted November 9, 2010 SpartaDOS manual http://www.bombjack.org/commodore/misc/atari/ sloopy. Quote Link to comment Share on other sites More sharing options...
