+5-11under Posted November 29, 2010 Share Posted November 29, 2010 Hi there, I was doing some ColecoVision work today, and needed a Super Action Controller. I noticed there was a removable platic cover over the grip handle, to make the handle fatter. I found it worked quite well, making the switches closer to the end of the fingers. I didn't look through all my Super Action Controllers, but I think this is the only one I have that has this. Is this an aftermarket add-on, or were they included with each Super Action Controller... and usually lost? Here's a picture: http://gaming.wikia.com/wiki/ColecoVision_Super_Action_Controller Thanks, 5-11under Quote Link to comment Share on other sites More sharing options...
NIAD Posted November 29, 2010 Share Posted November 29, 2010 (edited) Hi there, I was doing some ColecoVision work today, and needed a Super Action Controller. I noticed there was a removable platic cover over the grip handle, to make the handle fatter. I found it worked quite well, making the switches closer to the end of the fingers. I didn't look through all my Super Action Controllers, but I think this is the only one I have that has this. Is this an aftermarket add-on, or were they included with each Super Action Controller... and usually lost? Here's a picture: http://gaming.wikia.com/wiki/ColecoVision_Super_Action_Controller Thanks, 5-11under Two were included with the purchase of the Super Action Controllers and Super Action Baseball. They were included for people with larger hands to do just what you stated... align your fingertips more properly with the fire buttons. These are NOT an aftermarket add-on. BTW, have you ever had any luck repairing the two-directional Speed Roller? Got two that only register movement to the left, even when spinning the wheel to the right. I've never had any luck repairing these except when the defect was something minor like dirty contacts or a loose fire-button wire from being handled too roughly. Another problem that develops over time is the ball-knob becomes free wheeling (spins on the shaft)... the ball-knob is still secured to the shaft. Edited November 29, 2010 by NIAD Quote Link to comment Share on other sites More sharing options...
+5-11under Posted November 30, 2010 Author Share Posted November 30, 2010 Thanks for the info on the SAC. I hadn't seen these grips before today. For the speed roller, I'm thinking that maybe one of the two reed relays isn't working anymore. For the ball-knob, there's a orange cap on the top of the knob. Underneath it is the end of a bolt, and some sort of compression nut. Probably some of the orange plastic has been worn off through spinning, or the nut has become loose over time. Quote Link to comment Share on other sites More sharing options...
Murph74 Posted November 30, 2010 Share Posted November 30, 2010 Yep, the handgrips were there to snap on for adults was always our conclusion. With the grips, the controller was too big for my then-9 year old hands. Today, probably couldn't use the controller without them! Quote Link to comment Share on other sites More sharing options...
fiddlepaddle Posted December 5, 2010 Share Posted December 5, 2010 I bought my SACs new, and they came with those things. I was an adult at the time, but my hands must be medium size, because I don't mind using it either way (on or off). The only thing is sometimes with them on, they come off while I'm using the controller messing up my game. Quote Link to comment Share on other sites More sharing options...
