S1500 Posted January 23, 2011 Share Posted January 23, 2011 So the second CV I bought came with an Atari expansion module doesn't work. Typically I get a black screen, or just a slightly scrambled red screen. I did do cleaning on it before hooking it all up, to no avail. Tried multiple games, no luck. Any advice on getting this thing to work? I'm gonna try hooking up my other atari expansion module(one I know works) to see if it's possibly the port on CV 2. Quote Link to comment Share on other sites More sharing options...
SlowCoder Posted January 23, 2011 Share Posted January 23, 2011 And what hapebs when you plug the expansion into your 1st CV? Quote Link to comment Share on other sites More sharing options...
fiddlepaddle Posted January 24, 2011 Share Posted January 24, 2011 I've had one (Atari compatible plug-in) for a long time (30 years?), and occasionally when I pull it out to play, I have to plug it in several times before it works, usually cleaning the contacts more than once. Eventually, it has always worked; kind of temperamental, though. Last time was about 4 or 5 years ago. Quote Link to comment Share on other sites More sharing options...
SlowCoder Posted January 25, 2011 Share Posted January 25, 2011 I've had one (Atari compatible plug-in) for a long time (30 years?), and occasionally when I pull it out to play, I have to plug it in several times before it works, usually cleaning the contacts more than once. Eventually, it has always worked; kind of temperamental, though. Last time was about 4 or 5 years ago. Yep, I think that is going to happen over time. That is, unless you put some sort of corrosion preventer on it. Quote Link to comment Share on other sites More sharing options...
