Mirage Posted February 18, 2011 Share Posted February 18, 2011 To save opening up another c64 thread Can you interchange the sid chip from the old style c64 into the 2 later versions of the c64 (the c64c mobo version or the c64 based on the 64 games system mobo) And visa versa And i guess the same applies to the vic2 chip On the SID, no. They are not compatible due to different voltages. You can modify one to use the other, but it's not a direct swap. I'm not sure about the VIC2, I've never tried swapping them, since I have a good supply of any version I wouldn't need to. Quote Link to comment Share on other sites More sharing options...
Mayhem Posted February 18, 2011 Share Posted February 18, 2011 The VIC chips are fine, but as stated, you can't on the SIDs due to a difference in voltage. Quote Link to comment Share on other sites More sharing options...
R.Cade Posted February 18, 2011 Share Posted February 18, 2011 (edited) The VIC-II has a different reference voltage pin (13) requirement also- it's 12V on the old and 9V on the new. Putting an newer chip in the older board could damage it over time. I'm not sure if the opposite is true- it may cause problems long term pulling more current from the 9V line. Edited February 18, 2011 by R.Cade Quote Link to comment Share on other sites More sharing options...
Mayhem Posted February 18, 2011 Share Posted February 18, 2011 Oh, the voltage also applies to the VIC-II as well? But to my knowledge, there isn't a different product number of the VIC-II between old and new C64s (unlike the SID 6581 and 8580), just the one used inside the C128... so how does that work then? The later revisions are meant just for the C64C? Or is the C128 VIC-II inside the C64C as well? Quote Link to comment Share on other sites More sharing options...
