olavese@online.no Posted March 6, 2011 Share Posted March 6, 2011 Someone was having problems with ICE-T and I was wondering if I done settings wrong. How can I use the Telnet with my 130XE, MIO (I think I have to un-assign the MIO R: port) and a APE USB adapter, running APE v.3.0.6 on Windows 7. Is it only possible on the SIO2PC adapters (serial ones)? Quote Link to comment Share on other sites More sharing options...
w1k Posted March 6, 2011 Share Posted March 6, 2011 hm, i using telnet on atari 800xe (320kb ram) using APE, sio2pc and ICE-T http://www.podstromami.com/icet.zip attach atr image and boot atari.. must working Quote Link to comment Share on other sites More sharing options...
olavese@online.no Posted March 6, 2011 Author Share Posted March 6, 2011 hm, i using telnet on atari 800xe (320kb ram) using APE, sio2pc and ICE-T http://www.podstromami.com/icet.zip attach atr image and boot atari.. must working I was referring to you :-) I don't think it's the ICE-T that's the problem, I think it's something to do with APE on the PC side and it is a SIO2USB adapter. Says RS232 Driver disabled (USB only mode enabled) Quote Link to comment Share on other sites More sharing options...
+Stephen Posted March 6, 2011 Share Posted March 6, 2011 hm, i using telnet on atari 800xe (320kb ram) using APE, sio2pc and ICE-T http://www.podstromami.com/icet.zip attach atr image and boot atari.. must working I was referring to you :-) I don't think it's the ICE-T that's the problem, I think it's something to do with APE on the PC side and it is a SIO2USB adapter. Says RS232 Driver disabled (USB only mode enabled) That's the message that comes up when loading with the USB mode enabled. I am running Windows 7 64-bit, and using APE 3.0.4 with the USB SIO2PC adapter. In APE, go to the R: configuration and set the Modem Mode to "Server - inbound/outbound AT modem simulator". Windows 7 will most likely prompt you to allow this program to communicate (set a firewall exception). Allow this. That was all I had to do to get it setup and working. Any program that uses the standard 850 R: driver will work with the APE R: device. Quote Link to comment Share on other sites More sharing options...
olavese@online.no Posted March 6, 2011 Author Share Posted March 6, 2011 I've tried setting that, but it's not giving me the APE screen (not sure what it suppose to look like) only get a black screen where I can type and no effect on anything I do type. ICE-T is set to 19200 baud with XON/XOFF ... APE is still saying RS232 disabled (Maybe I try my SIO2PC adapter tomorrow ... I not really need to go online with the Atari, just want to because it's possible :-) Quote Link to comment Share on other sites More sharing options...
+bf2k+ Posted March 7, 2011 Share Posted March 7, 2011 Someone was having problems with ICE-T and I was wondering if I done settings wrong. How can I use the Telnet with my 130XE, MIO (I think I have to un-assign the MIO R: port) and a APE USB adapter, running APE v.3.0.6 on Windows 7. Is it only possible on the SIO2PC adapters (serial ones)? I use the APE USB device and it works fine. Yes make sure you unassign the MIO R: port. Quote Link to comment Share on other sites More sharing options...
