MADS Knowledge-Base
  • 2 weeks later...
  • 2 weeks later...
MADS version 1.9.6 Build 89
Can't compile
.echo ""
I'm attempting to print a blank line in the compilation output and receive a string error.
Workaround: .echo " "
this is empty string, xasm report ERROR: Unexpected end of line, mads report ERROR: String error, maybe better "Empty string"
Can't compile....
.ifdef VALUE1
... code ...
#while .byte TEMP1>#0
... code ...
#end
... code ...
.endif
In my full code I get....
DECOMPRESS_TILES.asm (104) ERROR: Unreferenced directive .END
yes, its bug
put #WHILE block into .MACRO block, and this working
or use directive .ENDW (.WEND) (end while) instead #END
Edited by tebe
mads 1.9.7 build 10
Tebe, thank you! This no longer creates a compiler error for me.
I have another problem. I am unable to give an example at the moment, my code is too large and needs simplifying a lot for an example. Are there any limitations to how far away in the executable a procedure (.proc) can be from the call to the proc? Do they also need to be in the same segment?
Is it possible that it won't create an error? It would be nice if it printed a newline character (\n). If I print " ", then it would actually print " \n". So if I print "", could it then print "\n"?
Edited by snicklin
OK, I've simplified the code (a bit!), this is all within MAIN:
Example 1: Faulty Code:
JMP GOT_PAST
icl 'lib/memory/CLEAR_1K.asm'
icl 'lib/memory/CLEAR_PAGE.asm'
icl 'lib/keyboard/get_key.asm'
GOT_PAST:
JMP MAIN_GAME_ROUTINES
.ifdef GAME_MAIN_GAME_EXISTS
icl 'lib/gameStructure/prepare_main_game.asm'
icl 'lib/gameStructure/start_main_game.asm'
icl 'lib/gameStructure/end_main_game.asm'
MAIN_GAME_ROUTINES:
procPREPARE_MAIN_GAME
procSTART_MAIN_GAME
procEND_MAIN_GAME
.endif
This code will produce:
procClear_Page .proc ( .byte bytePageNo )
CLEAR_PAGE.asm (10) ERROR: Label PROCCLEAR_PAGE declared twice (BANK=0)
.proc Get_Key ()
get_key.asm (1) ERROR: Label GET_KEY declared twice (BANK=0)
procPMG_Init ; Initialise PMG graphics for ingame usage
prepare_main_game.asm (30) ERROR: Undeclared macro PROCPMG_INIT (BANK=0)
JSR DECOMPRESS_TILES
start_main_game.asm (25) ERROR: Undeclared label DECOMPRESS_TILES (BANK=0)
Example 2: Example moves the jump to within the ifdef GAME_MAIN_GAME_EXISTS
JMP GOT_PAST
GOT_PAST:
MAIN_GAME_ROUTINES:
procSTART_MAIN_GAME
procEND_MAIN_GAME
.endif
With this, there is no problem, it compiles as it should. So the problem seems to be if you are using ifdef. Is this a valid bug?
Please note that GAME_MAIN_GAME_EXISTS is true.
Edited by snicklin
  • 4 weeks later...
Version 1.9.6_b7: Feature request
.opt f+
org bank2+$fe4
>Bank2-End.asm (21) ERROR: Can't fill from higher to lower memory location
Could you please add the 2 address values (current PC and resulting ORG) that don't match and maybe also the number of bytes exceeding the ORG value?
+1. I run into this a lot when working in my OS kernel around places that need to match absolute addresses, and the error message doesn't tell you how many bytes you need to trim to fit. Instead, I have to manually check and report overflows:
.if *>$f3f6-8
.error 'ROM overflow into Screen Handler region: ',*,' > $F3EE.'
.endif
org $f3f6-8
  • 4 weeks later...
don't know if it's off-topic
but
how can i get this (atari roots chapter 13) running on mads?
10 ;
20 ;HELLO SCREEN
30 ;
40 *=$3000
50 JMP INIT
60 ;
70 SDMCTL=$022F
80 ;
90 SDLSTL=$0230
0100 SDLSTH=$0231
0110 ;
0120 COLOR0=$02C4; OS COLOR REGISTERS
0130 COLOR1=$02C5
0140 COLOR2=$02C6
0150 COLOR3=$02C7
0160 COLOR4=$02C8
0170 ;
0180 ;DISPLAY LIST DATA
0190 ;
0200 START
0210 ;
0220 LINE1 .SBYTE " PRESENTING "
0230 LINE2 .SBYTE " the big program "
0240 LINE3 .SBYTE " By (your name) "
0250 ;
0260 LINE4 .SBYTE " PLEASE STAND BY "
0270 ;
0280 ;DISPLAY LIST
0290 ;
0300 HLIST
0310 .BYTE $70,$70,$70; 3 BLANK LINES
0320 .BYTE $70, $70, $70, $70,$70; MORE BLANK LINES
0330 .BYTE $46; LSM, ANTIC MODE 6 (BASIC MODE 2)
0340 .WORD LINE1; (TEXT LINE: "PRESENTING...")
0350 .BYTE $70,$70,$70,$70,$47; LMS, ANTIC MODE 7
0360 .WORD LINE2; (TEXT LINE: "THE BIG PROGRAM")
0370 .BYTE $70,$42; (LMS, ANTIC MODE 2 [GR.0])
0380 .WORD LINE3;(TEXT LINE: "By [Your Name]")
0390 .BYTE $70,$70,$70,$70,$46;LMS, ANTIC MODE 6
0400 .WORD LINE4; (TEXT LINE: "PLEASE STAND BY")
0410 .BYTE $70,$70,$70,$70,$70; 5 BLANK LINES
0420 .BYTE $41; JVB INSTRUCTION
0430 .WORD HLIST; TO JUMP BACK TO START OF LIST
0440 ;
0450 ;RUN PROGRAM
0460 ;
0470 INIT NOP; SWITCHING COLOR REGISTERS FOR NICELY COLORED DISPLAY
0480 LDA COLOR3
0490 STA COLOR1
0500 LDA COLOR4
0510 STA COLOR2
0520 ; NOW WE'LL RUN THE PROGRAM
0530 LDA #0
0540 STA SDMCTL; TURN ANTIC OFF FOR A MOMENT ...
0550 LDA #HLIST&; WHILE WE STORE OUR NEW LIST'S ADDRESS
0560 STA SDLSTL; IN THE OS DISPLAY POINTER.
0570 LDA # HLIST/256; NOW FOR THE HIGH BYTE.
0580 STA SDLSTH; NOW ANTIC WILL KNOW OUR NEW ADDRESS
0590 LDA #$22
0600 STA SDMCTL; ... SO WE'LL TURN ANTIC BACK ON NOW
0610 ;
0620 FINI
0630 RTS
;HELLO SCREEN
SDMCTL=$022F
SDLSTL=$0230
SDLSTH=$0231
COLOR0=$02C4                ; OS COLOR REGISTERS
COLOR1=$02C5
COLOR2=$02C6
COLOR3=$02C7
COLOR4=$02C8
   org $3000
; Screen data
LINE1    dta d '	  PRESENTING    '
LINE2    dta d '   the big program  '
LINE3    dta d '			   By (your name)		 '
LINE4    dta d '   PLEASE STAND BY   '
; Display list
HLIST    dta $70,$70,$70            ; 3 BLANK LINES
   dta $70,$70,$70,$70,$70        ; MORE BLANK LINES
   dta $46                ; LSM, ANTIC MODE 6 (BASIC MODE 2)
   .word LINE1            ; (TEXT LINE: "PRESENTING...")
   dta $70,$70,$70,$70,$47        ; LMS, ANTIC MODE 7
   .word LINE2            ; (TEXT LINE: "THE BIG PROGRAM")
   dta $70,$42            ; (LMS, ANTIC MODE 2 [GR.0])
   .word LINE3            ; (TEXT LINE: "By [Your Name]")
   dta $70,$70,$70,$70,$46        ; LMS, ANTIC MODE 6
   .word LINE4            ; (TEXT LINE: "PLEASE STAND BY")
   dta $70,$70,$70,$70,$70        ; 5 BLANK LINES
   dta $41                ; JVB INSTRUCTION
   .word HLIST            ; TO JUMP BACK TO START OF LIST
; Run program
init    NOP                ; SWITCHING COLOR REGISTERS FOR NICELY COLORED DISPLAY
   LDA COLOR3
   STA COLOR1
   LDA COLOR4
   STA COLOR2
   LDA #0
   STA SDMCTL            ; TURN ANTIC OFF FOR A MOMENT ...
   LDA #<HLIST            ; WHILE WE STORE OUR NEW LIST'S ADDRESS
   STA SDLSTL            ; IN THE OS DISPLAY POINTER.
   LDA #>HLIST            ; NOW FOR THE HIGH BYTE.
   STA SDLSTH            ; NOW ANTIC WILL KNOW OUR NEW ADDRESS
   LDA #$22
   STA SDMCTL            ; ... SO WE'LL TURN ANTIC BACK ON NOW
finish    jmp finish            ; endless loop
   run init
example.xex
other ways to format your tables...
; display list
hlist    dta $70,$70,$70,$70,$70,$70,$70,$70,$46,a(line1),$70,$70,$70,$70,$47,a(line2),$70,$42,a(line3),$70,$70,$70,$70,$46,a(line4)
   dta $70,$70,$70,$70,$70,$41,a(hlist)
or..
; display list
hlist    dta $70,$70,$70,$70,$70,$70,$70,$70,$46,<line1,>line1,$70,$70,$70,$70,$47,<line2,>line2,$70,$42,<line3,>line3,$70,$70,$70,$70,$46,<line4,>line4
   dta $70,$70,$70,$70,$70,$41,<hlist,>hlist
; display list
or..
; display list
great !!
now how can i "connect" resulting .XEX with the other generated by rastaconverter (intro screen) ?
By a programmer spoiled by mads:
; Display list values
DL_LMS_MASK = %01000000
DL_JVB = 65
DL_BLANK_8 = 112
; Basic graphic modes
GM_CHAR_G0 = 2 ; 2 colors, 40x24, 960b, 40xline, 8 scanlines
GM_CHAR_G1 = 6 ; 4 colors, 20x24, 480b, 40xline, 8 scanlines
GM_CHAR_G2 = 7 ; 4 colors, 20x12, 240b, 20xline, 16 scanlines
; display list
hlist
:8 .byte DL_BLANK_8
.byte GM_CHAR_G1+DL_LMS_MASK
.word line1
:4 .byte DL_BLANK_8
.byte GM_CHAR_G2+DL_LMS_MASK
.word line2
.byte DL_BLANK_8
.byte GM_CHAR_G0+DL_LMS_MASK
.word line3
:4 .byte DL_BLANK_8
.word line4
.byte DL_JVB
.word hlist
And could be better with macros x)
yea :) repeat is certainly very handy, I use it a lot too.
I usually prefer to construct my dl manually with addition .. like this from my boulderdash loader..
antic	 :9 .byte $70
.byte $80
.byte $40+$0d+$80,a(scr)
.byte $40+$0d+$80,a(scr+40)
.byte $40+$0d+$80,a(scr+80)
.byte $40+$0d+$80,a(scr+120)
.byte $40+$0d+$80,a(scr+160)
.byte $40+$0d+$80,a(scr+200)
.byte $40+$0d+$80,a(scr+240)
.byte $40+$0d+$80,a(scr+280)
.byte $40+$0d+$80,a(scr+320)
.byte $40+$0d+$80,a(scr+360)
.byte $40+$0d+$80,a(scr+400)
.byte $40+$0d+$80,a(scr+440)
.byte $40+$0d+$80,a(scr+480)
.byte $40+$0d+$80,a(scr+520)
.byte $40+$0d+$80,a(scr+560)
.byte $40+$0d+$80,a(scr+600)
.byte $40+$0d+$80,a(scr+640)
.byte $40+$0d+$80,a(scr+680)
.byte $40+$0d+$80,a(scr+720)
.byte $40+$0d+$80,a(scr+760)
.byte $40+$0d+$80,a(scr+800)
.byte $40+$0d+$80,a(scr+840)
.byte $40+$0d+$80,a(scr+880)
.byte $40+$0d+$80,a(scr+920)
.byte $f0
.byte $c4,a(scr2)
.byte $4
.byte $f0
.byte $2
.byte $41,a(antic)
@ Aking. I should've mentioned also that you can still use ".byte" too with MADS :)
I most often use specific hexadecimal tables via .he with MADS which negates the requirement to include the $.
I find the source is then much neater and easier to view when I'm working.
.he 00 00 19 1A 1B 1C
Edited by Tezz
;HELLO SCREEN
    run init
Seems that this was questioned more than one time here...
Sow now we have 2 options for beginners here within this forum now :)
And I see, I forgot to run init in my version - tough altirra runs it fine :o
The upper xex together with the upper 'the big program'.
Simply add this code right at the top of Tezz's version:
    opt h-
    ins 'AtariForce.xex'
    opt h+
    ini $5800    ;## ini address found in xex file ##
And dont forget to have this file also within the right folder ;)
