MADS Knowledge-Base
Just stumbled across this one:
mva #0 Ds1[0].ReturnCode
This puts $00 into the proper element of struct Ds1.
mva #0 Ds1 [0].ReturnCode
However, the second example (note space between struct name and array index) always stores $00 in the first byte of the struct.
fixed
MADS 1.9.8 build 5
The following code crashes.
65 92E2 A5 8E C9 B7 B0 03 + #if .byte PLAYER0X > #GAME_RIGHT_BORDER
66 92F0 A5 C8 C9 03 D0 05 #if .byte ROOM_X = #WORLD_WIDTH-1
67 92F6 C6 8E DEC PLAYER0X
68 92F8 4C 05 93 #else
69 92FB E6 C8 INC ROOM_X
70 92FD A9 01 85 A0 MVA #1 SCREEN_COMPLETE
71 9301 A9 40 LDA #GAME_LEFT_BORDER
72 9303 85 8E STA PLAYER0X
73 9305 #end
74 ;#else ; Leave this else in, even if it does nothing as the game crashes without it
75 9305 #end
for me, works OK
try this
mads_198b44.zip
Edited by tebe
2 questions
1) sin generator... how can I build sintables with more than 1 period?
2) XASM related...
what does the "+" after the JSR do? I know the post inc/decrement (inserting inx,dex f.e.) but this? can not find in any docu what the +,- after standard commands do (and I have not checked the disassebling).
There seems to be an issue with low/high address byte relocations in .RELOC blocks. MADS supports split address relocations, but this doesn't seem to work for the following common case:
.reloc .word
 foo:
    ldx    #<foo
    ldy    #>foo
For this, MADS hardcodes $00 and $01 without relocations. It works if I use zero-page addressing instead of immediate, or if I replace the sequence with MWA.
  • 3 weeks later...
Hello tebe,
First thanks for mads. It is a powerful tool and it has proved very useful for me.
I have a small feature request: could you please increase the pass_max value (to 32 for example) in the next release? I have had some complex sources which required more passes than the standard 16 and that causes some very strange errors.
greetings,
tzeb
don't use # if you want low, high
   ldx <foo
   ldy >foo
Really? This is very non-standard and ambiguous, surely. LDX <$680 should load the content of $80. Not that such an operation is much practical use, but still...
And it would be nice if the date could either be in byte values or as a string. The string would need to be locali(s/z)ed though.
Yes indeed. The reason I wanted this was simply to populate six bytes in an executable with the date and time of compilation.
That would be very useful. In my case, I'd like to have a string which I can load into the screen memory so that it can be seen (though I could use the byte values, I work in automation and like things done for me). It would be a lazy build/release information system.
Other ideas:
compiler_version()
compilation_directory()
Edited by snicklin
How about some way to reference the compile date/time in the source? i.e.:
.byte _SYS_DAY,_SYS_MONTH,_SYS_YEAR
I had something like this in the assembler I wrote years ago and it was pretty handy.
time+date needs SYSUTILS, mads is minimalistic, uses only SYSTEM
for time and date i use BUILD http://www.madteam.atari8.info/uzytki/build.7z
i use it with Pang, Mads
BAT file
mads.exe %1 -tpli:"d:\!atari\macro\"
@echo off
if exist %~n1.inf build %~n1.obx
INF file, from Pang
BUILD
#73
3.5
153
string "BUILD" is marker in executable file, it's begining of memory space for change with BUILD
#73 is code for EOL (end of line)
string "3.5" is actual version
"153" is build number, increases with every start of the BUILD program
Hello tebe,
greetings,
tzeb
change this
  pass_max = 16;        // maksymalna mozliwa liczba przebiegow asemblacji
compile with FPC
// Free Pascal Compiler http://www.freepascal.org/
// Compile: fpc -Mdelphi -vh -O3 mads.pas
but 32 passes is strange
example, how hang mads (16 passes, 32 passes, 1000000000000000000000000000000 passes)
    org $2000
    ift label<$2080
    mwa #$4080 $80
    els
    mva #$40 $80
    eif
    :123 brk
label
WARNING: Infinite loop by label LABEL
Hi,
@tzeb
regarding the 32 passes I also think restructuring the program would be a better idea, also in terms of compilation speed/time.
@teba
Build is nice for it's purpose but as for the Date/Time functions build does not address what I mean.
I'd really like to have the data & time values and also build.exe will not help the MacOX/Linux guys.
I'm not so deep into Pascal: What's the deal with SYSUTIL? Size of resulting .EXE?
Would love that too! Good idead might be date()/time() functions similar to SIN().
SIN is pseudo code. like ORG, OPT, IFT etc. (3 chars)
for TIME/DATE pseudo code TIM or directive .TIME
TIM(format)
format: y-ear, m-onth, d-ay, t-ime
dta tim(y) ; 2014
dta tim(m:d) ; 1:11
dta tim(y-mmm-ddd) ; 2014-001-011
or directive: .YEAR, .MONTH, .DAY, .HOUR, .MINUTE, .SECOND
.echo .year,'/',.month,'/',.day
dta a(.year)
with PRINTF
jsr printf
dta c'date: %-%-%, time: %:%:%',$9b,0
dta a(.year)
dta a(.month)
dta a(.day)
dta a(.hour)
dta a(.minute)
dta a(.second)
which version is better :) ?
Hello,
@tebe
Thanks for your reaction concerning my pass_max question. I did figure out how to change it, but I must not forget to patch MADS each time a new version is being released.
Perhaps you could consider increasing it in the released code? The number 32 is just an example. The maximum number of passes I have encountered is 18. (I do not know what is supposed to be a 'normal' number of passes?)
@JAC!
I really don't know how to restructure the program to reduce the number of passes. I use a few .REPT, lots of .LOCAL and lots and lots of @ labels. And the program source is large (>200KB, but the largest part is DTA digital data)
