MADS Knowledge-Base
oops, thanks pps I'd forgotten about listing the example with the rc pic for aking, I've had my head in fixing Druid for NTSC this evening.
so... I assume you wanted the text intro before the raster converter picture which can be done like so ..
; Hello screen
sdmctl    = $022F
sdlstl    = $0230
sdlsth    = $0231
skctl    = $D20F
color0    = $02C4                ; OS color REGISTERS
color1    = $02C5
color2    = $02C6
color3    = $02C7
color4    = $02C8
    org $1800
; Screen data
line1    dta d '      PRESENTING    '
line2    dta d '   the big program  '
line3    dta d '               By (your name)         '
line4    dta d '   PLEASE STAND BY   '
; Display list
dlist    dta $70,$70,$70,$70,$70,$70,$70,$70,$46,a(line1),$70,$70,$70,$70,$47,a(line2),$70,$42,a(line3),$70,$70,$70,$70,$46,a(line4)
    dta $70,$70,$70,$70,$70,$41,a(dlist)
init    nop                ; Switching color registers for nicely colored display
    lda color3
    sta color1
    lda color4
    sta color2
    mva #0 sdmctl            ; Turn Antic off for a moment ...
    mwa #dlist sdlstl        ; ... while we store our new display list's address in the os display pointer
    mva #$22 sdmctl            ; ... so we'll turn antic back on now
_kbd    lda skctl            ; wait for key bounce loop
    and #4
    bne _kbd
    jmp $5800            ; execute the included raster converter image
    org $2000
    opt h-                ; include the binary file with opt h- to remove the file header
    ins 'AtariForce.xex'
    opt h+
    ini init
example.xex
Edited by Tezz
; Hello screen
sdmctl    = $022F
sdlstl    = $0230
sdlsth    = $0231
skctl    = $D20F
color1    = $02C5
color2    = $02C6
color3    = $02C7
color4    = $02C8
    org $1800
; Screen data
; Display list
    lda color3
    sta color1
    lda color4
    sta color2
    and #4
    bne _kbd
    org $2000
    opt h+
    ini init
got some errors :?
but pps 's rutine assembled both programs without problems
  • 4 weeks later...
I just tried the cool feature .segment, but it didn´t work as expected (Message: "Value out of Range" for each .endseg)
Until I used the newest version :) So everything is just fine!
BTW: I saw the size of the mads.exe in the three last versions and it was 214016 bytes each. Why is it exactly 209 KB?
Now I ran into a problem with mads: One file of my source code doesn´t compile any more after upgrading to a new version (see above: upgrade needed for .segment)
I striped the problem down to this:
SHEARED_SCROLL = 0
	org $2400
main:
	jmp main
.if SHEARED_SCROLL
ScrollLineOffsetFractAdd_
	.rept 85
	dta <(((#*25*256)/1000 + 64)*2/1)
	.endr
ScrollLineOffsetFixAdd_
	.rept 85
	dta >(((#*25*256)/1000 + 64)*2/1)
	.endr
.else
	.rept 85
	dta <(80)
	.endr
	.rept 85
	dta >(80)
	.endr
.endif
; ----- start address ------------------------------------------
	run main
The MADS console output is
0,stop
with output files of 0-size length
Interesting. If you strip it right down to this, it still doesn't compile:
flag = 0
	org $2400
	.if flag
		.rept 85
			.byte 0
		.endr
	.else
		.byte 1
	.endif
Doesn't seem to like REPT in the positive clause of an IF condition. I also noticed empty IF/ELSE clauses cause an error.
Edited by flashjazzcat
Latest MADS ends with rather ambiguous "0,stop" message and produces no object file when compiling the Ultimate 1MB PBI ROM. Absolutely no clue given to what's causing the problem. Is there a debug mode so I can at least find the offending line of source code?
Last one which works (fortunately) is the MADS build in post #93. The one a couple of posts later has a gloss saying that "REPT" has been rewritten, etc... maybe something got screwed up there, but it's hard to know what. Will have to stick with the post #93 version for now.
Regression with .fl in 1.9.7 build 53: it is no longer able to encode numbers smaller than 1e-10.
    opt    h-
    org    $2000
    .fl    1e-20
    :10 dta 0
    .fl    1e-15
    :10 dta 0
    .fl    1e-12
    :10 dta 0
    .fl    1e-11
    :10 dta 0
    .fl    1e-10
    :10 dta 0
    .fl    1e-9
    :10 dta 0
    .fl    1e-5
    :10 dta 0
1.9.7 build 10:
00000000: 36 01 00 00 00 00
00000010: 38 10 00 00 00 00
00000020: 3A 01 00 00 00 00
00000030: 3A 10 00 00 00 00
00000040: 3B 01 00 00 00 00
00000050: 3B 10 00 00 00 00
00000060: 3D 10 00 00 00 00
1.9.7 build 53:
00000000: 00 00 00 00 00 00
00000010: 00 00 00 00 00 00
00000020: 00 00 00 00 00 00
00000030: 00 00 00 00 00 00
  • 2 weeks later...
  • 4 weeks later...
Just stumbled across this one:
mva #0 Ds1[0].ReturnCode
This puts $00 into the proper element of struct Ds1.
mva #0 Ds1 [0].ReturnCode
However, the second example (note space between struct name and array index) always stores $00 in the first byte of the struct. Edited by flashjazzcat
Using Mads 1.9.8 B5
If I do this,
.var .byte count=0
LDA enemyData[count].defaultY
If I compile the above, I get "ERROR: Constant expression violates subrange bounds"
If however, I use
LDA enemyData[0].defaultY or LDA enemyData[1].defaultY
then it compiles and works.
What I do not understand is that previously I have declared
enemyData dta enemyDataStruct [2]
As count=0, it isn't out of bounds... but it reports that it is.
I guess the problem is due to the compiler knowing that 'count' could be set to a value greater than/equal to 2.
How can I refer to a structure which is indexed by a variable?? I don't want to have to write code for each and every enemy, I will have many enemies in my game, which is better represented as an array.
There are 2 standard approaches for this "object based" access:
Assume objects have 4 attribute "a","b","c","d" of size 1 byte each.
Approach 1: Column based
NUMBER_OF_ENEMIES = 10
.local enemies
a .ds NUMBER_OF_ENEMIES
b .ds NUMBER_OF_ENEMIES
c .ds NUMBER_OF_ENEMIES
d .ds NUMBER_OF_ENEMIES
.endl
ldx #enemy_id
lda enemies.a,x
lda enemies.b,x
Approach 2: Row based
lda #enemy_id
asl
asl
tax
lda enemies.a,x
lda enemies.b,x
.local enemies
a = enemies+0
b = enemies+1
c = enemies+2
d = enemies+3
.ds NUMBER_OF_ENEMIES*4
.endl
the 2nd approach can also be written as structs probably, I'm simply more accustomed to this notation.
  • 2 weeks later...
MADS 1.9.8 build 5
The following code crashes.
65 92E2 A5 8E C9 B7 B0 03 + #if .byte PLAYER0X > #GAME_RIGHT_BORDER
66 92F0 A5 C8 C9 03 D0 05 #if .byte ROOM_X = #WORLD_WIDTH-1
67 92F6 C6 8E DEC PLAYER0X
68 92F8 4C 05 93 #else
69 92FB E6 C8 INC ROOM_X
70 92FD A9 01 85 A0 MVA #1 SCREEN_COMPLETE
71 9301 A9 40 LDA #GAME_LEFT_BORDER
72 9303 85 8E STA PLAYER0X
73 9305 #end
74 ;#else ; Leave this else in, even if it does nothing as the game crashes without it
75 9305 #end
The next block of code is the same as the above block of code,except an 'else' has been added. This works fine.
65 92E2 A5 8E C9 B7 90 1A + #if .byte PLAYER0X > #GAME_RIGHT_BORDER
66 92EA A5 C8 C9 03 D0 05 #if .byte ROOM_X = #WORLD_WIDTH-1
67 92F0 C6 8E DEC PLAYER0X
68 92F2 4C FF 92 #else
69 92F5 E6 C8 INC ROOM_X
70 92F7 A9 01 85 A0 MVA #1 SCREEN_COMPLETE
71 92FB A9 40 LDA #GAME_LEFT_BORDER
72 92FD 85 8E STA PLAYER0X
73 92FF #end
74 92FF 4C 02 93 #else ; Leave this else in, even if it does nothing as the game crashes without it
75 9302 #end
Edited by snicklin
Oops, spoke too soon on the .FL fix -- it is losing significant digits between 10^-3 and 10^-9 (MADS 1.9.8 build 5):
    48 20F0 3E 12 34 56 79 00           .fl     1.23456789e-3
    49 20F6 00 00 00 00 00 00 +         :10 dta 0
    50
    51 2100 3E 01 23 45 68 00           .fl     1.23456789e-4
    52 2106 00 00 00 00 00 00 +         :10 dta 0
    53
    54 2110 3D 12 34 57 00 00           .fl     1.23456789e-5
    55 2116 00 00 00 00 00 00 +         :10 dta 0
    56
    57 2120 3D 01 23 46 00 00           .fl     1.23456789e-6
    58 2126 00 00 00 00 00 00 +         :10 dta 0
    59
    60 2130 3C 12 35 00 00 00           .fl     1.23456789e-7
    61 2136 00 00 00 00 00 00 +         :10 dta 0
    62
    63 2140 3C 01 23 00 00 00           .fl     1.23456789e-8
    64 2146 00 00 00 00 00 00 +         :10 dta 0
    65
    66 2150 3B 12 00 00 00 00           .fl     1.23456789e-9
    67 2156 00 00 00 00 00 00 +         :10 dta 0
    68
    69 2160 3B 01 00 00 00 00           .fl     1.23456789e-10
    70 2166 00 00 00 00 00 00 +         :10 dta 0
    71
    72 2170 3A 12 34 56 78 90           .fl     1.23456789e-11
    73 2176 00 00 00 00 00 00 +         :10 dta 0
    74
    75 2180 3A 01 23 45 67 89           .fl     1.23456789e-12
    76 2186 00 00 00 00 00 00 +         :10 dta 0
