svenski Posted April 11, 2011 Share Posted April 11, 2011 Well I apologise for you finding it hilarious. From now on it shall be known as "the thingy that connects your Atari via the SIO port to your computer via a USB port" along with links for definitions of SIO and USB and "thingy". Quote Link to comment Share on other sites More sharing options...
+Philsan Posted April 11, 2011 Share Posted April 11, 2011 I simply write "SIO2PC (usb version)". As you know SIO2USB is a completely different device and, as pointed out by Ken, Steve doesn't call his device SIO2USB. EDIT I was forced to write this because I don't want Ken's 1200XL fighters over Switzerland. Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted April 11, 2011 Share Posted April 11, 2011 I was forced to write this because I don't want Ken 1200XL fighters over Switzerland. Quote Link to comment Share on other sites More sharing options...
svenski Posted April 11, 2011 Share Posted April 11, 2011 Send the fighters, send the fighters. I'm sure I have a model Spitfire somewhere. Quote Link to comment Share on other sites More sharing options...
MEtalGuy66 Posted April 11, 2011 Share Posted April 11, 2011 Naah. Like I said. I find it hilarious.. Doesnt bother me a bit.. Just confuses people who don't know, who may have otherwise benefitted from your information.. But hey, as far as the magazine goes, as long as they are willing to continue to pay for something that confuses them, I guess you have nothing to worry about. Do you actualy charge for advertising in that thing? If so, I hope they are very understanding too when you refer to their products by the wrong name.. And then try to make light of the whole situation like it doesnt matter, when someone corrects you in the interest of potential customers being able to actually recognize their products. Quote Link to comment Share on other sites More sharing options...
Marius Posted April 11, 2011 Share Posted April 11, 2011 I'll second that. If you've tried that many computers and the MyIDE still doesn't work, I've found throwing it in the bin to be an excellent hardware solution. I love the old IDE-only cart I use, but the new Flash+IDE one I bought just doesn't work, and I am NOT prepared to start Phi2 modding my already Phi2 modded machines to try and tune them up to an interface which still might not work properly. I've experimented with driver error correction, and this device is so way off in never-never land that the driver can barely even detect the drive, let alone read anything meaningful from it. If you have to resort to "magic" fixes like putting the shielding back on... well, as MG says - if you're into that kind of thing. Hey FlashJazzcat, Did you replace the 74F245 with a 74HCT245 or 74LS245? That is one improvement that worked for me. Did you know that you rather easy can 'downgrade' (I think it is an upgrade) your flash based myide to an "old fashioned" one? There are two options: Option one: remove only the flashrom on the myide. Sijmen told me: this will make the Flash Based MyIDE interface into a non-flash-based MyIDE (not tested) Option two: remove both the gal AND the flashrom, and install the missing TTL IC's in the right place. In my version of the MyIDE there is place on the board to install the original TTL IC's. I'm not sure whether this is possible with the newer ones. I prefer the non-flash versions too. I need compatibility and with the Flash OS I have too many programs that don't work. Greetz M. Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted April 11, 2011 Share Posted April 11, 2011 (edited) Yeah - I actually socketed 74LS245 and tried an HCT245 in there instead. It didn't make any difference. I understand the LS is the best one anyway, and that's what was soldered onto the board in the first place. My reason for purchasing the Flash cart was to get around the rather thorny problem of using a cart-based application as well as an external MyIDE and internal SDX. I already have the latter two elements working quite nicely, but it would have been nice to flash Mac/65 or Action! to the Flash cart and run it with the IDE hooked up via CAR at the SDX prompt. My intention was also to test developmental versions of the GUI using the MyIDE/Flash cart. So really, removing the Flash component makes the interface doubly useless. Although, having said that, I guess the case is marginally better looking than that of the older cart. Another obstacle in the way of solution 2 is that this particular board revision isn't designed to take the TTL ICs. It's GAL or nothing. In any case, my tests so far have been conducted with the same set-up as most of the rest of the driver-testing contingent: MyIDE-driver-eqipped SDX build flashed to the cart. I invariably get "HDD not found" on every machine, so at least it's consistent. I start to realize now why Sijmen's sector I/O routine grew into something so ponderous and exhaustive. Edited April 11, 2011 by flashjazzcat Quote Link to comment Share on other sites More sharing options...
19Echo Posted April 12, 2011 Author Share Posted April 12, 2011 so would this work? eBay Auction -- Item Number: 150483353152 Quote Link to comment Share on other sites More sharing options...
jvas Posted December 22, 2014 Share Posted December 22, 2014 I also get this "No Atari Folder" error message. Which file should be used to re-program the Atmega32? I have a Ver2 PCB. Thanks for your help in advance! Quote Link to comment Share on other sites More sharing options...
jvas Posted January 6, 2015 Share Posted January 6, 2015 (edited) AVR studio requires .elf or .hex file. Where to download them? Is it possible to somehow convert the .bin file? Please help! The current content of the ATMEGA is attached. The fuse bits are checked and OK. test.rar Edited January 6, 2015 by jvas Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted January 6, 2015 Share Posted January 6, 2015 Try this: http://www.ht-lab.com/freeutils/bin2hex/bin2hex.html Quote Link to comment Share on other sites More sharing options...
jvas Posted January 6, 2015 Share Posted January 6, 2015 (edited) It did the trick: http://srecord.sourceforge.net Edited January 6, 2015 by jvas Quote Link to comment Share on other sites More sharing options...
