Avram Posted April 18, 2011 Share Posted April 18, 2011 What's the best way to synchronize the position of a player with characters on an antic 4 screen? By keeping track with counters or by performing math to convert the player position to 0-23 and 0-39? I've attempted to use the counter method in the code below (it gets a little messed up when you move left and I haven't solved that issue yet). What I'm attempting to do is have the robot character (to be redrawn and made 22 pixels high, instead of the current 16) move around the screen and for the code to translate the robot's position to a position on the screen. To have some visual proof that it's working the code plots an "A" when you press trigger. But is this the fastest way? Is there a better way of doing it? And I should explain that eventually the robot will move left and right, fall of platforms, and engage with items on screen, but for now I'm only attempting to link player and character movement up. Thanks. *=$4000 p1 = $d0 p2 = $d2 xpos = 1536 ypos = 1537 joystick = 1538 p0hpos = 1539 p0vpos = 1540 smlframe = 1541 frame = 1542 playcount = 1543 xpm2scn = 1544 ypm2scn = 1545 xpm = 1546 ypm = 1547 begin lda #<scr ; start by calculating look-up tables sta p1 ; at the same time, we will clear the lda #>scr ; screen sta p1+1 ldx #0 c0 lda #0 ; draw a character ldy #39 ; clear a single line c1 ;sta (p1),y ; WRITES OVER SCREEN dey bpl c1 lda p1+1 ; store address into look-up table sta schi,x lda p1 sta sclo,x clc ; update zero page to next line adc #40 ; 40 bytes per line sta p1 bcc c2 inc p1+1 c2 inx ; for all 24 lines... cpx #24 bne c0 lda #4 ; set some colors sta 708 ; make ANTIC4 slightly more readable lda #6 sta 709 lda #8 sta 710 lda #<DLIST ; finally, point ANTIC to new display sta 560 lda #>DLIST sta 561 ; Main loop pmmover lda #$80 ; reserve 8 pages sta 54279 ; ... and in PMBASE lda #32 ; sta 623 lda #62 ; turn on DMACTL. 46 is single-resolution sta 559 lda #3 ; turn on GRACTL sta 53277 lda #16 ; single resolution players sta 54272 lda #104 ; sta 704 ; color players lda #28 sta 705 lda #0 sta 710 ; set up pm-to-screen lda #0 sta smlframe lda #48+4 ; starting position of pm. +4 is one character width sta p0hpos lda #32+4 ; adding one char? sta p0vpos routine lda $14 ; slow things down delay cmp $14 ; " beq delay ; " lda p0hpos ; store horizontal pos sta 53248 sta 53249 lda #18 ;size of player sta playcount ldx frame ; begin height count ldy p0vpos drawloop lda shape,x ; read shape data sta $8400,y ; draw player lda shape2,x ; read shape data sta $8500,y ; draw player inx iny dec playcount lda playcount bne drawloop ; ...and repeat sty xpos stx ypos lda 644 ;trigger (0) pressed? cmp #0 bne stickread ldx ypm ; xpm ;get pm-to-screen coordinates ldy xpm ;y carries horizontal lda #33 ; get ready to print "A" jsr jplotchar stickread lda 632 ;joystick cmp #13 bne up inc p0vpos inc ypm2scn lda ypm2scn cmp #8 beq down1 jmp routine down1 lda #0 sta ypm2scn inc ypm jmp routine up lda 632 cmp #14 bne right dec p0vpos dec ypm2scn lda ypm2scn cmp #0 beq up1 jmp routine up1 lda #8 sta ypm2scn clc dec ypm jmp routine right lda 632 cmp #7 bne left clc inc p0hpos inc xpm2scn lda xpm2scn cmp #3 bne right1 lda #0 sta xpm2scn inc xpm right1 inc smlframe lda smlframe cmp #4 beq right2 jmp routine right2 lda #0 ;reset smlframe sta smlframe inc p0hpos clc lda frame adc #18 ; this will become 24 sta frame cmp #54 beq right3 jmp routine right3 lda #18 sta frame jmp routine left lda 632 cmp #11 beq left0 leftexit jmp routine left0 dec p0hpos dec xpm2scn lda xpm2scn cmp #0 bne left1 lda #3 sta xpm2scn dec xpm left1 inc smlframe lda smlframe cmp #4 beq left2 jmp routine left2 lda #0 ;reset smlframe sta smlframe dec p0hpos clc lda frame adc #18 ; this will become 24 sta frame cmp #54 beq left3 jmp routine left3 lda #18 sta frame jmp routine ;plot a character <A> at (Y,X) jplotchar pha lda sclo,x ; set up zero-page address sta p1 lda schi,x sta p1+1 pla sta (p1),y rts *=$8000 shape .byte 0,102,0,126,126,102,0,0,0,255,255,219,255,60,255,24,231,0; rest .byte 0,126,120,126,126,126,0,0,0,255,255,251,255,60,109,255,182,0; frame 1, right .byte 0,0,126,120,126,126,126,0,0,255,255,251,255,60,182,255,109,0; frame 2, right .byte 0,0,0,126,120,126,126,126,0,255,255,253,255,60,219,126,219,0; frame 3, right *=$8100 shape2 .byte 0,0,90,126,0,0,24,24,24,129,129,231,0,0,231,231,231,0; rest .byte 0,0,6,6,0,0,24,24,24,48,96,24,0,0,255,129,255,0; frame 1, right .byte 0,0,0,6,6,0,0,24,24,48,48,60,0,0,255,129,255,0 ;frame 2, right .byte 0,0,0,0,6,6,0,0,24,48,24,14,0,0,255,129,255,0; frame 1, right DLIST .byte 112,112,112 ; blank lines .byte 68,<scr,>scr ; 24 lines of ANTIC 4 .byte 4,4,4,4,4,4,4,4,4,4,4,4,4,4,4 .byte 4,4,4,4,4,4,4 .byte 65,<DLIST,>DLIST ; Jump to top *=$5000 ;scr .ds 40*24 ; 960 bytes for screen scr .sbyte "****************************************" .sbyte "* *" .sbyte "* *" .sbyte "* *" .sbyte "* ===============*" .sbyte "* ===============*" .sbyte "* *" .sbyte "* *" .sbyte "* *" .sbyte "* *" .sbyte "* ================ *" .sbyte "* ================ *" .sbyte "* *" .sbyte "* *" .sbyte "* *" .sbyte "* ========== *" .sbyte "* ========== *" .sbyte "* *" .sbyte "* *" .sbyte "* ========== *" .sbyte "* ========== *" .sbyte "* *" .sbyte "****************************************" sclo .ds 24 schi .ds 24 Quote Link to comment Share on other sites More sharing options...
Eagle Posted April 18, 2011 Share Posted April 18, 2011 My point of view on this. * = $4000 p1 = $d0 p2 = $d2 xpos = 1536 ypos = 1537 joystick = 1538 p0hpos = 1539 p0vpos = 1540 smlframe = 1541 frame = 1542 playcount = 1543 xpm2scn = 1544 ypm2scn = 1545 xpm = 1546 ypm = 1547 begin lda #<scr ; start by calculating look-up tables sta p1 ; at the same time, we will clear the lda #>scr ; screen sta p1+1 ldx #0 c0 lda #0 ; draw a character ldy #39 ; clear a single line c1 ;sta (p1),y ; WRITES OVER SCREEN dey bpl c1 lda p1+1 ; store address into look-up table sta schi,x lda p1 sta sclo,x clc ; update zero page to next line adc #40 ; 40 bytes per line sta p1 bcc c2 inc p1+1 c2 inx ; for all 24 lines... cpx #24 bne c0 lda #4 ; set some colors sta 708 ; make ANTIC4 slightly more readable lda #6 sta 709 lda #8 sta 710 lda #<DLIST ; finally, point ANTIC to new display sta 560 lda #>DLIST sta 561 ; Main loop pmmover lda #$80 ; reserve 8 pages sta 54279 ; ... and in PMBASE lda #32 ; sta 623 lda #62 ; turn on DMACTL. 46 is single-resolution sta 559 lda #3 ; turn on GRACTL sta 53277 lda #16 ; single resolution players sta 54272 lda #104 ; sta 704 ; color players lda #28 sta 705 lda #0 sta 710 ; set up pm-to-screen lda #0 sta smlframe lda #48+4 ; starting position of pm. +4 is one character width sta p0hpos lda #32+4 ; adding one char? sta p0vpos routine lda $14 ; slow things down delay cmp $14 ; " beq delay ; " lda p0hpos ; store horizontal pos sta 53248 sta 53249 lda #18 ;size of player sta playcount ldx frame ; begin height count ldy p0vpos drawloop lda shape,x ; read shape data sta $8400,y ; draw player lda shape2,x ; read shape data sta $8500,y ; draw player inx iny dec playcount lda playcount bne drawloop ; ...and repeat sty xpos stx ypos lda 644 ;trigger (0) pressed? cmp #0 bne stickread jsr set_adress jsr check_walls stickread ldx 632 lda xstick,x clc adc p0hpos sta p0hpos lda ystick,x clc adc p0vpos sta p0vpos lda tabside,x bne nochange ;frame rest = 0 sta frame jmp routine nochange bpl rightmove ;leftmove lda p0hpos lsr a lsr a and #$03 tax lda tabframeright,x sta frame jmp routine rightmove lda p0hpos lsr a lsr a and #$03 tax lda tabframeleft,x sta frame jmp routine xstick .byte 0,0,0,0,0,1,1,1,0,$FF,$FF,$FF,0,0,0,0 ystick .byte 0,0,0,0,0,1,$FF,0,0,1,$FF,0,0,1,$FF,0 tabside .byte 0,0,0,0,0,1,1,1,0,$FF,$FF,$FF,0,0,0,0 tabframeright .byte 18,18,36,54 ;frames for move right tabframeleft .byte 18,18,36,54 ;frames for move left - no frames yet temp .byte 0 check_walls ;p1=robot -lefthigh corner lda #33 ldy #$00 sta (p1),y rts set_adress lda p0hpos sec sbc #48 lsr a lsr a sta temp lda p0vpos sec sbc #32 lsr a lsr a lsr a tax lda sclo,x sta p1 lda schi,x sta p1+1 lda p1 clc adc temp sta p1 bcc skip inc p1+1 skip rts *=$8000 shape .byte 0,102,0,126,126,102,0,0,0,255,255,219,255,60,255,24,231,0; rest .byte 0,126,120,126,126,126,0,0,0,255,255,251,255,60,109,255,182,0; frame 1, right .byte 0,0,126,120,126,126,126,0,0,255,255,251,255,60,182,255,109,0; frame 2, right .byte 0,0,0,126,120,126,126,126,0,255,255,253,255,60,219,126,219,0; frame 3, right *=$8100 shape2 .byte 0,0,90,126,0,0,24,24,24,129,129,231,0,0,231,231,231,0; rest .byte 0,0,6,6,0,0,24,24,24,48,96,24,0,0,255,129,255,0; frame 1, right .byte 0,0,0,6,6,0,0,24,24,48,48,60,0,0,255,129,255,0 ;frame 2, right .byte 0,0,0,0,6,6,0,0,24,48,24,14,0,0,255,129,255,0; frame 1, right DLIST .byte 112,112,112 ; blank lines .byte 68,<scr,>scr ; 24 lines of ANTIC 4 .byte 4,4,4,4,4,4,4,4,4,4,4,4,4,4,4 .byte 4,4,4,4,4,4,4 .byte 65,<DLIST,>DLIST ; Jump to top *=$5000 ;scr .ds 40*24 ; 960 bytes for screen scr .sbyte "****************************************" .sbyte "* *" .sbyte "* *" .sbyte "* *" .sbyte "* ===============*" .sbyte "* ===============*" .sbyte "* *" .sbyte "* *" .sbyte "* *" .sbyte "* *" .sbyte "* ================ *" .sbyte "* ================ *" .sbyte "* *" .sbyte "* *" .sbyte "* *" .sbyte "* ========== *" .sbyte "* ========== *" .sbyte "* *" .sbyte "* *" .sbyte "* ========== *" .sbyte "* ========== *" .sbyte "* *" .sbyte "****************************************" sclo .ds 24 schi .ds 24 Quote Link to comment Share on other sites More sharing options...
Avram Posted April 18, 2011 Author Share Posted April 18, 2011 Wow - thank-you for the rewrite! Looking forward to going over this to learn what I was doing wrong. Thanks again! Quote Link to comment Share on other sites More sharing options...
Eagle Posted April 18, 2011 Share Posted April 18, 2011 Ok extra idea about collision * = $4000 p1 = $d0 p2 = $d2 xpos = 1536 ypos = 1537 joystick = 1538 p0hpos = 1539 p0vpos = 1540 smlframe = 1541 frame = 1542 playcount = 1543 xpm2scn = 1544 ypm2scn = 1545 xpm = 1546 ypm = 1547 begin lda #<scr ; start by calculating look-up tables sta p1 ; at the same time, we will clear the lda #>scr ; screen sta p1+1 ldx #0 c0 lda #0 ; draw a character ldy #39 ; clear a single line c1 ;sta (p1),y ; WRITES OVER SCREEN dey bpl c1 lda p1+1 ; store address into look-up table sta schi,x lda p1 sta sclo,x clc ; update zero page to next line adc #40 ; 40 bytes per line sta p1 bcc c2 inc p1+1 c2 inx ; for all 24 lines... cpx #24 bne c0 lda #4 ; set some colors sta 708 ; make ANTIC4 slightly more readable lda #6 sta 709 lda #8 sta 710 lda #<DLIST ; finally, point ANTIC to new display sta 560 lda #>DLIST sta 561 ; Main loop pmmover lda #$80 ; reserve 8 pages sta 54279 ; ... and in PMBASE lda #32 ; sta 623 lda #62 ; turn on DMACTL. 46 is single-resolution sta 559 lda #3 ; turn on GRACTL sta 53277 lda #16 ; single resolution players sta 54272 lda #104 ; sta 704 ; color players lda #28 sta 705 lda #0 sta 710 ; set up pm-to-screen lda #0 sta smlframe lda #48+8 ; starting position of pm. +4 is one character width sta p0hpos lda #32+8 ; adding one char? sta p0vpos routine lda $14 ; slow things down delay cmp $14 ; " beq delay ; " lda p0hpos ; store horizontal pos sta 53248 sta 53249 lda #18 ;size of player sta playcount ldx frame ; begin height count ldy p0vpos drawloop lda shape,x ; read shape data sta $8400,y ; draw player lda shape2,x ; read shape data sta $8500,y ; draw player inx iny dec playcount lda playcount bne drawloop ; ...and repeat sty xpos stx ypos ; lda 644 ;trigger (0) pressed? ; cmp #0 ; bne stickread jsr set_adress jsr check_walls stickread ldx 632 lda xstick,x clc adc p0hpos sta p0hpos lda ystick,x clc adc p0vpos sta p0vpos lda tabside,x bne nochange ;frame rest = 0 sta frame jmp routine nochange bpl rightmove ;leftmove lda p0hpos lsr a lsr a and #$03 tax lda tabframeright,x sta frame jmp routine rightmove lda p0hpos lsr a lsr a and #$03 tax lda tabframeleft,x sta frame jmp routine xstick .byte 0,0,0,0,0,1,1,1,0,$FF,$FF,$FF,0,0,0,0 ystick .byte 0,0,0,0,0,1,$FF,0,0,1,$FF,0,0,1,$FF,0 tabside .byte 0,0,0,0,0,1,1,1,0,$FF,$FF,$FF,0,0,0,0 tabframeright .byte 18,18,36,54 ;frames for move right tabframeleft .byte 18,18,36,54 ;frames for move left - no frames yet temp .byte 0 check_walls ;p1=robot -lefthigh corner ldy #$00 lda (p1),y beq checkhead2 lda 632 ora #$01 sta 632 jmp checkleft checkhead2 iny lda (p1),y beq checkleft lda 632 ora #$01 sta 632 checkleft ldy #40 lda (p1),y beq checkright lda 632 ora #$04 sta 632 checkright iny iny lda (p1),y beq checkfeet lda 632 ora #$08 sta 632 checkfeet ldy #80 lda (p1),y beq checkfeet2 lda 632 ora #$02 sta 632 checkfeet2 iny lda (p1),y beq checkend lda 632 ora #$02 sta 632 checkend rts rts set_adress lda p0hpos sec sbc #48 lsr a lsr a sta temp lda p0vpos sec sbc #32 lsr a lsr a lsr a tax lda sclo,x sta p1 lda schi,x sta p1+1 lda p1 clc adc temp sta p1 bcc skip inc p1+1 skip rts *=$8000 shape .byte 0,102,0,126,126,102,0,0,0,255,255,219,255,60,255,24,231,0; rest .byte 0,126,120,126,126,126,0,0,0,255,255,251,255,60,109,255,182,0; frame 1, right .byte 0,0,126,120,126,126,126,0,0,255,255,251,255,60,182,255,109,0; frame 2, right .byte 0,0,0,126,120,126,126,126,0,255,255,253,255,60,219,126,219,0; frame 3, right *=$8100 shape2 .byte 0,0,90,126,0,0,24,24,24,129,129,231,0,0,231,231,231,0; rest .byte 0,0,6,6,0,0,24,24,24,48,96,24,0,0,255,129,255,0; frame 1, right .byte 0,0,0,6,6,0,0,24,24,48,48,60,0,0,255,129,255,0 ;frame 2, right .byte 0,0,0,0,6,6,0,0,24,48,24,14,0,0,255,129,255,0; frame 1, right DLIST .byte 112,112,112 ; blank lines .byte 68,<scr,>scr ; 24 lines of ANTIC 4 .byte 4,4,4,4,4,4,4,4,4,4,4,4,4,4,4 .byte 4,4,4,4,4,4,4 .byte 65,<DLIST,>DLIST ; Jump to top *=$5000 ;scr .ds 40*24 ; 960 bytes for screen scr .sbyte "****************************************" .sbyte "* *" .sbyte "* *" .sbyte "* *" .sbyte "* ===============*" .sbyte "* ===============*" .sbyte "* *" .sbyte "* *" .sbyte "* *" .sbyte "* *" .sbyte "* ================ *" .sbyte "* ================ *" .sbyte "* *" .sbyte "* *" .sbyte "* *" .sbyte "* ========== *" .sbyte "* ========== *" .sbyte "* *" .sbyte "* *" .sbyte "* ========== *" .sbyte "* ========== *" .sbyte "* *" .sbyte "****************************************" sclo .ds 24 schi .ds 24 Quote Link to comment Share on other sites More sharing options...
+therealbountybob Posted April 18, 2011 Share Posted April 18, 2011 Can't help with assembler code but for my Turbo BASIC game I went for this formulae: I used it to clear off a square of character graphic when the PMG (Gwobby) touched two playfields Quote Link to comment Share on other sites More sharing options...
Avram Posted April 19, 2011 Author Share Posted April 19, 2011 Thanks the real bb. My first attempt at the code used similar math but I was worried that it would slow things down, even in machine code. Eagle, thank you again! I really need to start working up the graphics now to see how it's going to play. Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted April 19, 2011 Share Posted April 19, 2011 the logic described in the turbo basic screenshot is the right one so... actually you do this lda player_xpos ;shadow register not the hardware register sec sbc #border_value ;depends on your screen layout but for a 40 byte screen it is $30 lsr ;div 2 lsr ;div 2 = div 4 ;now akku contains the collum tay lda player_ypos sec sbc #border lsr ;div 2 lsr ;div 2 lsr ;div 2 = div 8 ;now akku contains the row tax lda screentabl,x ;contains the start adress of each line precalculated in a lookup table sta $b0 lda screentabh,x sta $b1 lda ($b0),y ;read char at player position my 2 cents can not see a faster method for calculating out of player positions Quote Link to comment Share on other sites More sharing options...
Eagle Posted April 19, 2011 Share Posted April 19, 2011 >can not see a faster method for calculating out of player positions There are many. It depends on how quickly you need and how much memory you have. example for every line starts on page ldx player_xpos lda tabx,x sta $B0 ldx player_ypos lda taby,x sta $B1 ldy #$00 lda ($b0),y .... .... Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted April 19, 2011 Share Posted April 19, 2011 Eagle, sure... but Avram is not yet into "hardcode optimisation" mode... he was thinking as far as I understood that the Turbo Basic "formulars" where hard to transfer into ASM. and I doubt that he is yet at the point where he is counting CPU-cycles wasted in lazy code segments... Quote Link to comment Share on other sites More sharing options...
Avram Posted April 19, 2011 Author Share Posted April 19, 2011 Heaven, thanks for your take on the code. And you're correct - optimization is something I'm not capable of at the moment BUT what's good about the code that you, Eagle, Gauntman, Flashjazzcat, Groovybee etc have posted is that I'm forced to attempt to understand the more advanced 6502 coding. I'm learning absolutely loads right now and am still trying to understand the latest piece that Eagle wrote (i.e. why ORA to the joystick location and write it back?). Quote Link to comment Share on other sites More sharing options...
Eagle Posted April 19, 2011 Share Posted April 19, 2011 (edited) ;Tabstick - what you read from 632 ; 0000 ;-- ; 0001 ;-- ; 0010 ;-- ; 0011 ;-- ; 0100 ;-- ; 0101 ;right down ; 0110 ;right up ; 0111 ;right ; 1000 ;---- ; 1001 ;left down ; 1010 ;left up ; 1011 ;left ; 1100 ;--- ; 1101 ;down ; 1110 ;up ; 1111 ;no move ; simply - bit 0 = 0 - up ; bit 1 = 0 - down ; bit 2 = 0 - left ; bit 3 = 0 - right example: I checked head - if char is there then i do ora #%0001 (ora #$01) from table ; 1110 ;up - ora #%0001 = 1111 <- that means stick no move Edited April 19, 2011 by Eagle Quote Link to comment Share on other sites More sharing options...
Avram Posted April 20, 2011 Author Share Posted April 20, 2011 (edited) Okay Eagle - I'll admit I'm stumped (not all that hard to do). 1) I added the reversed frames for the robot so that it can 'walk' left. Besides adding the extra frames just The two things I changed were the heigh of each frame (it's gone from 18 bytes to 25 bytes) and this part here: tabframeright .byte 18,18,36,54 ;frames for move right tabframeleft .byte 18,18,36,54 ;frames for move left - no frames yet I assume that with my larger frames it should read like this: tabframeright .byte 25,25,50,75 ;frames for move right tabframeleft .byte 100,125,150,175 ;frames for move left - no frames yet The frames for the left frame follow immediately after the frames for the right. PLAYER 0 frame 0, rest frame 1, right frame 2, right frame 3, right frame 1, left frame 2, left frame 3, left PLAYER 1 (same structure) I'm not on the computer I was working on but can post the code tomorrow. Right now it gets garbled when moving a different direction. 2) I haven't tackled this but wanted to ask this question. I want the robot to fall off platforms. Is it simply a matter of adding something along the lines of this? checkfeet ldy #80 lda (p1),y beq checkfeet2 is the character a space? If so, then fall is the character a unpainted platform? If so, then paint and decrease unpainted platform counter etc. lda 632 ora #$02 sta 632 checkfeet2 iny lda (p1),y beq checkend is the character a space? If so, then fall is the character a unpainted platform? If so, then paint and decrease unpainted platform counter etc. lda 632 ora #$02 sta 632 Thanks! Edited April 20, 2011 by Avram Quote Link to comment Share on other sites More sharing options...
Eagle Posted April 20, 2011 Share Posted April 20, 2011 Your stick procedure was correct. But too long. I just try show you different point of view. With this stick procedure you will have some problems. Not because of your programming skills. Simply, it is different than others. The procedure for jump, can cause you some problems. But I think you can handle this. * = $4000 p1 = $d0 p2 = $d2 xpos = 1536 ypos = 1537 joystick = 1538 p0hpos = 1539 p0vpos = 1540 smlframe = 1541 frame = 1542 playcount = 1543 xpm2scn = 1544 ypm2scn = 1545 xpm = 1546 ypm = 1547 begin lda #<scr ; start by calculating look-up tables sta p1 ; at the same time, we will clear the lda #>scr ; screen sta p1+1 ldx #0 c0 lda #0 ; draw a character ldy #39 ; clear a single line c1 ;sta (p1),y ; WRITES OVER SCREEN dey bpl c1 lda p1+1 ; store address into look-up table sta schi,x lda p1 sta sclo,x clc ; update zero page to next line adc #40 ; 40 bytes per line sta p1 bcc c2 inc p1+1 c2 inx ; for all 24 lines... cpx #24 bne c0 lda #4 ; set some colors sta 708 ; make ANTIC4 slightly more readable lda #6 sta 709 lda #8 sta 710 lda #<DLIST ; finally, point ANTIC to new display sta 560 lda #>DLIST sta 561 ; Main loop pmmover lda #$80 ; reserve 8 pages sta 54279 ; ... and in PMBASE lda #32 ; sta 623 lda #62 ; turn on DMACTL. 46 is single-resolution sta 559 lda #3 ; turn on GRACTL sta 53277 lda #16 ; single resolution players sta 54272 lda #104 ; sta 704 ; color players lda #28 sta 705 lda #0 sta 710 ; set up pm-to-screen lda #0 sta smlframe lda #48+8 ; starting position of pm. +4 is one character width sta p0hpos lda #32+8 ; adding one char? sta p0vpos routine lda $14 ; slow things down delay cmp $14 ; " beq delay ; " lda p0hpos ; store horizontal pos sta 53248 sta 53249 lda #18 ;size of player sta playcount ldx frame ; begin height count ldy p0vpos drawloop lda shape,x ; read shape data sta $8400,y ; draw player lda shape2,x ; read shape data sta $8500,y ; draw player inx iny dec playcount lda playcount bne drawloop ; ...and repeat sty xpos stx ypos ; lda 644 ;trigger (0) pressed? ; cmp #0 ; bne stickread jsr set_adress jsr check_walls stickread ldx 632 lda xstick,x clc adc p0hpos sta p0hpos lda ystick,x clc adc p0vpos sta p0vpos lda tabside,x bne nochange ;frame rest = 0 sta frame jmp routine nochange bpl rightmove ;leftmove lda p0hpos lsr a lsr a and #$03 tax lda tabframeright,x sta frame jmp routine rightmove lda p0hpos lsr a lsr a and #$03 tax lda tabframeleft,x sta frame jmp routine xstick .byte 0,0,0,0,0,1,1,1,0,$FF,$FF,$FF,0,0,0,0 ystick .byte 0,0,0,0,0,1,$FF,0,0,1,$FF,0,0,1,$FF,0 tabside .byte 0,0,0,0,0,1,1,1,0,$FF,$FF,$FF,0,0,0,0 tabframeright .byte 18,36,54,36 ;frames for move right tabframeleft .byte 18,36,54,36 ;frames for move left - no frames yet temp .byte 0 check_walls ;p1=robot -lefthigh corner ldy #$01 lda (p1),y beq checkleft lda 632 ora #$01 sta 632 checkleft ldy #40 lda (p1),y beq checkright lda 632 ora #$04 sta 632 checkright iny iny lda (p1),y beq checkfeet lda 632 ora #$08 sta 632 checkfeet ldy #81 lda (p1),y beq fall_down lda 632 ora #$02 sta 632 rts fall_down lda 632 ;set stick down and #$0d ;%1101 ora #$01 ;clear stick up - robot fall down sta 632 rts set_adress lda p0hpos sec sbc #48 lsr a lsr a sta temp lda p0vpos sec sbc #32 lsr a lsr a lsr a tax lda sclo,x sta p1 lda schi,x sta p1+1 lda p1 clc adc temp sta p1 bcc skip inc p1+1 skip rts *=$8000 shape .byte 0,102,0,126,126,102,0,0,0,255,255,219,255,60,255,24,231,0; rest .byte 0,126,120,126,126,126,0,0,0,255,255,251,255,60,109,255,182,0; frame 1, right .byte 0,0,126,120,126,126,126,0,0,255,255,251,255,60,182,255,109,0; frame 2, right .byte 0,0,0,126,120,126,126,126,0,255,255,253,255,60,219,126,219,0; frame 3, right *=$8100 shape2 .byte 0,0,90,126,0,0,24,24,24,129,129,231,0,0,231,231,231,0; rest .byte 0,0,6,6,0,0,24,24,24,48,96,24,0,0,255,129,255,0; frame 1, right .byte 0,0,0,6,6,0,0,24,24,48,48,60,0,0,255,129,255,0 ;frame 2, right .byte 0,0,0,0,6,6,0,0,24,48,24,14,0,0,255,129,255,0; frame 1, right DLIST .byte 112,112,112 ; blank lines .byte 68,<scr,>scr ; 24 lines of ANTIC 4 .byte 4,4,4,4,4,4,4,4,4,4,4,4,4,4,4 .byte 4,4,4,4,4,4,4 .byte 65,<DLIST,>DLIST ; Jump to top *=$5000 ;scr .ds 40*24 ; 960 bytes for screen scr .sbyte "****************************************" .sbyte "* *" .sbyte "* *" .sbyte "* *" .sbyte "* ===============*" .sbyte "* ===============*" .sbyte "* *" .sbyte "* *" .sbyte "* *" .sbyte "* *" .sbyte "* ================ *" .sbyte "* ================ *" .sbyte "* *" .sbyte "* *" .sbyte "* *" .sbyte "* ========== *" .sbyte "* ========== *" .sbyte "* *" .sbyte "* *" .sbyte "* ========== *" .sbyte "* ========== *" .sbyte "* *" .sbyte "****************************************" sclo .ds 24 schi .ds 24 Quote Link to comment Share on other sites More sharing options...
Avram Posted April 20, 2011 Author Share Posted April 20, 2011 Excellent! And thank-you for your confidence in me. But really, this is what you're dealing with: Quote Link to comment Share on other sites More sharing options...
Avram Posted April 20, 2011 Author Share Posted April 20, 2011 Okay. Here's the code with the new robot graphics. One of the things I don't understand is the frame code. I've expanded each frame to 25 bytes high but the code reading them incorrectly, as well as leaving a trail. What I am I doing wrong? * = $4000 p1 = $d0 p2 = $d2 xpos = 1536 ypos = 1537 joystick = 1538 p0hpos = 1539 p0vpos = 1540 smlframe = 1541 frame = 1542 playcount = 1543 xpm2scn = 1544 ypm2scn = 1545 xpm = 1546 ypm = 1547 begin lda #<scr ; start by calculating look-up tables sta p1 ; at the same time, we will clear the lda #>scr ; screen sta p1+1 ldx #0 c0 lda #0 ; draw a character ldy #39 ; clear a single line c1 ;sta (p1),y ; WRITES OVER SCREEN dey bpl c1 lda p1+1 ; store address into look-up table sta schi,x lda p1 sta sclo,x clc ; update zero page to next line adc #40 ; 40 bytes per line sta p1 bcc c2 inc p1+1 c2 inx ; for all 24 lines... cpx #24 bne c0 lda #4 ; set some colors sta 708 ; make ANTIC4 slightly more readable lda #6 sta 709 lda #8 sta 710 lda #<DLIST ; finally, point ANTIC to new display sta 560 lda #>DLIST sta 561 ; Main loop pmmover lda #$80 ; reserve 8 pages sta 54279 ; ... and in PMBASE lda #32 ; sta 623 lda #62 ; turn on DMACTL. 46 is single-resolution sta 559 lda #3 ; turn on GRACTL sta 53277 lda #16 ; single resolution players sta 54272 lda #104 ; sta 704 ; color players lda #28 sta 705 lda #0 sta 710 ; set up pm-to-screen lda #0 sta smlframe lda #48+8 ; starting position of pm. +4 is one character width sta p0hpos lda #32+8 ; adding one char? sta p0vpos routine lda $14 ; slow things down delay cmp $14 ; " beq delay ; " lda p0hpos ; store horizontal pos sta 53248 sta 53249 lda #25 ;size of player sta playcount ldx frame ; begin height count ldy p0vpos drawloop lda shape,x ; read shape data sta $8400,y ; draw player lda shape2,x ; read shape data sta $8500,y ; draw player inx iny dec playcount lda playcount bne drawloop ; ...and repeat sty xpos stx ypos jsr set_adress jsr check_walls stickread ldx 632 lda xstick,x clc adc p0hpos sta p0hpos lda ystick,x clc adc p0vpos sta p0vpos lda tabside,x bne nochange ;frame rest = 0 sta frame jmp routine nochange bpl rightmove ;leftmove lda p0hpos lsr a lsr a and #$03 tax lda tabframeright,x sta frame jmp routine rightmove lda p0hpos lsr a lsr a and #$03 tax lda tabframeleft,x sta frame jmp routine xstick .byte 0,0,0,0,0,1,1,1,0,$FF,$FF,$FF,0,0,0,0 ystick .byte 0,0,0,0,0,1,$FF,0,0,1,$FF,0,0,1,$FF,0 tabside .byte 0,0,0,0,0,1,1,1,0,$FF,$FF,$FF,0,0,0,0 tabframeright .byte 25,25,50,75 ;frames for move right tabframeleft .byte 100,100,125,150 ;frames for move left - no frames yet temp .byte 0 check_walls ;p1=robot -lefthigh corner ldy #$01 lda (p1),y beq checkleft lda 632 ora #$01 sta 632 checkleft ldy #40 lda (p1),y beq checkright lda 632 ora #$04 sta 632 checkright iny iny lda (p1),y beq checkfeet lda 632 ora #$08 sta 632 checkfeet ldy #81 lda (p1),y beq fall_down lda 632 ora #$02 sta 632 rts fall_down lda 632 ;set stick down and #$0d ;%1101 ora #$01 ;clear stick up - robot fall down sta 632 rts set_adress lda p0hpos sec sbc #48 lsr a lsr a sta temp lda p0vpos sec sbc #32 lsr a lsr a lsr a tax lda sclo,x sta p1 lda schi,x sta p1+1 lda p1 clc adc temp sta p1 bcc skip inc p1+1 skip rts *=$8000 shape .byte 0,102,126,0,0,24,60,126,60,36,24,0,255,255,231,165,36,60,255,24,24,0,0,0,0; rest. Note, pm is 26 bytes tall .byte 0,6,126,96,96,126,126,126,24,30,0,0,126,126,126,114,126,60,255,0,0,126,126,0,0; frame 1, right .byte 0,0,6,126,96,96,126,126,126,24,30,0,126,126,126,118,126,60,255,0,0,126,126,0,0; frame 2, right .byte 0,0,0,6,126,96,96,126,126,126,24,30,126,126,126,222,126,60,255,0,0,126,126,0; frame 3, right .byte 0,96,126,6,6,126,126,126,24,120,0,0,126,126,126,78,126,60,255,0,0,126,126,126,0,0; frame 1; left .byte 0,0,96,126,6,6,126,126,126,24,120,0,126,126,126,110,126,60,255,0,0,126,126,0,0; frame 2; left .byte 0,0,0,96,126,6,6,126,126,126,24,120,126,126,126,123,126,60,255,0,0,126,126,0,0; frame 3; left *=$8100 shape2 .byte 0,0,0,00,90,126,24,0,0,0,24,24,195,129,153,153,219,0,255,231,0,231,0,231,0; rest .byte 0,0,0,0,26,2,2,0,0,0,24,24,0,32,32,60,0,0,255,0,221,129,1,238,0; frame 1, right .byte 0,0,0,0,0,26,2,2,0,0,0,24,0,32,64,120,0,0,255,0,238,1,129,221,0 ;frame 2, right .byte 0,0,0,0,0,0,26,2,2,0,0,0,0,32,64,224,0,0,255,0,119,128,129,187,0; frame 1, right .byte 0,0,0,0,88,64,64,0,0,0,24,24,0,4,4,60,0,0,255,0,187,129,128,119,0; frame 1; left .byte 0,0,0,0,88,64,64,0,0,0,24,0,4,2,30,0,0,255,0,119,128,129,187,0; frame 2; left .byte 0,0,0,0,0,0,88,64,64,0,0,0,0,4,2,7,0,0,255,0,238,1,129,221,0; frame 3; left DLIST .byte 112,112,112 ; blank lines .byte 68,<scr,>scr ; 24 lines of ANTIC 4 .byte 4,4,4,4,4,4,4,4,4,4,4,4,4,4,4 .byte 4,4,4,4,4,4,4 .byte 65,<DLIST,>DLIST ; Jump to top *=$5000 ;scr .ds 40*24 ; 960 bytes for screen scr .sbyte "****************************************" .sbyte "* *" .sbyte "* *" .sbyte "* *" .sbyte "* ===============*" .sbyte "* ===============*" .sbyte "* *" .sbyte "* *" .sbyte "* *" .sbyte "* *" .sbyte "* ================ *" .sbyte "* ================ *" .sbyte "* *" .sbyte "* *" .sbyte "* *" .sbyte "* ========== *" .sbyte "* ========== *" .sbyte "* *" .sbyte "* *" .sbyte "* ========== *" .sbyte "* ========== *" .sbyte "* *" .sbyte "****************************************" sclo .ds 24 schi .ds 24 Quote Link to comment Share on other sites More sharing options...
Eagle Posted April 20, 2011 Share Posted April 20, 2011 You test me? You lost two bytes in your data *=$8000 shape .byte 0,102,126,0,0,24,60,126,60,36,24,0,255,255,231,165,36,60,255,24,24,0,0,0,0; rest. Note, pm is 26 bytes tall .byte 0,6,126,96,96,126,126,126,24,30,0,0,126,126,126,114,126,60,255,0,0,126,126,0,0; frame 1, right .byte 0,0,6,126,96,96,126,126,126,24,30,0,126,126,126,118,126,60,255,0,0,126,126,0,0; frame 2, right .byte 0,0,0,6,126,96,96,126,126,126,24,30,126,126,126,222,126,60,255,0,0,126,126,0,0 ; frame 3, right .byte 0,96,126,6,6,126,126,126,24,120,0,0,126,126,126,78,126,60,255,0,0,126,126,126,0,0 ;<- you lost 1 byte here (last zero) - frame 1; left .byte 0,0,96,126,6,6,126,126,126,24,120,0,126,126,126,110,126,60,255,0,0,126,126,0,0; frame 2; left .byte 0,0,0,96,126,6,6,126,126,126,24,120,126,126,126,123,126,60,255,0,0,126,126,0,0; frame 3; left b1 *=$8100 shape2 .byte 0,0,0,00,90,126,24,0,0,0,24,24,195,129,153,153,219,0,255,231,0,231,0,231,0; rest .byte 0,0,0,0,26,2,2,0,0,0,24,24,0,32,32,60,0,0,255,0,221,129,1,238,0; frame 1, right .byte 0,0,0,0,0,26,2,2,0,0,0,24,0,32,64,120,0,0,255,0,238,1,129,221,0 ;frame 2, right .byte 0,0,0,0,0,0,26,2,2,0,0,0,0,32,64,224,0,0,255,0,119,128,129,187,0; frame 1, right .byte 0,0,0,0,88,64,64,0,0,0,24,24,0,4,4,60,0,0,255,0,187,129,128,119,0; frame 1; left .byte 0,0,0,0,0,88,64,64,0,0,0,24,0,4,2,30,0,0,255,0,119,128,129,187,0; <- you lost 1 byte here (first zero) frame 2; left .byte 0,0,0,0,0,0,88,64,64,0,0,0,0,4,2,7,0,0,255,0,238,1,129,221,0; frame 3; left Quote Link to comment Share on other sites More sharing options...
Avram Posted April 20, 2011 Author Share Posted April 20, 2011 You test me? You lost two bytes in your data Please see video in post #14. That should explain my mistakes. Quote Link to comment Share on other sites More sharing options...
