peedenmark7 Posted August 22, 2011 Share Posted August 22, 2011 (edited) Vintage Commodore monitor cables in bulk packaging. Unsure as to which models they would be used on. Red/White/Yellow Rca's to an 8 pin connector . $5 each plus shipping/pp . Large box they came in is marked Commodore c-64 7 pin to NTSC composite, but I can not verify that and as such are sold as is. Edited August 22, 2011 by peedenmark7 Quote Link to comment Share on other sites More sharing options...
+save2600 Posted August 22, 2011 Share Posted August 22, 2011 (edited) Strange that they'd be yellow, red and white. You'd normally think composite video and left/right audio, but the C= machines did not output stereo. That plug, even though the colors are wrong, *may* be for use with the 1702 monitor in its separate luma/chroma mode. S-video basically. If you'd like to send me one, I could test for you and if it's wired correctly for the 1702, I'll buy it. My sneaking suspicion though is that these are regular stereo A/V cables for something like the Neo*Geo. Not even sure Genesis model 1 outputs stereo through that port. I do not believe mine does anyway. Edited August 22, 2011 by save2600 Quote Link to comment Share on other sites More sharing options...
labrat Posted August 22, 2011 Share Posted August 22, 2011 I was thinking that they might just have split the audio to use on both channels. Either way, I'll take a chance on a couple. I can always mod them for other uses. PM sent. Strange that they'd be yellow, red and white. You'd normally think composite video and left/right audio, but the C= machines did not output stereo. That plug, even though the colors are wrong, *may* be for use with the 1702 monitor in its separate luma/chroma mode. S-video basically. If you'd like to send me one, I could test for you and if it's wired correctly for the 1702, I'll buy it. My sneaking suspicion though is that these are regular stereo A/V cables for something like the Neo*Geo. Not even sure Genesis model 1 outputs stereo through that port. I do not believe mine does anyway. Quote Link to comment Share on other sites More sharing options...
desiv Posted August 22, 2011 Share Posted August 22, 2011 Large box they came in is marked Commodore c-64 7 pin to NTSC composite, but I can not verify that and as such are sold as is. Weird.. I'm pretty sure the Commodore video ports are 5-pin (Vic-20 and some C64) and 8-pin (later C64 and C128's).. These are 7? desiv Quote Link to comment Share on other sites More sharing options...
peedenmark7 Posted August 22, 2011 Author Share Posted August 22, 2011 (edited) Large box they came in is marked Commodore c-64 7 pin to NTSC composite, but I can not verify that and as such are sold as is. Weird.. I'm pretty sure the Commodore video ports are 5-pin (Vic-20 and some C64) and 8-pin (later C64 and C128's).. These are 7? desiv they are 8 pin. pic added to original posting as reference. Edited August 22, 2011 by peedenmark7 Quote Link to comment Share on other sites More sharing options...
desiv Posted August 22, 2011 Share Posted August 22, 2011 they are 8 pin. OK. . :-) Well, I don't have a working C64 right now :-(, but I think I'm in for one just in case.. Also, hey.. Is that a chicken-head (Commodore symbol) on that DIN? Real Commodore cables?? I'm guessing it's for the Commodore monitor then. 1 channel audio, separate chrom/luma. (Which I believe you can use a 2-to-1 RCA jack to combine them to make composite???) Or a 2 RCA-to-svideo adapter and use them on an svideo TV. I'll pm you... desiv Quote Link to comment Share on other sites More sharing options...
peedenmark7 Posted August 22, 2011 Author Share Posted August 22, 2011 (edited) I got the cables from a former commodore dealer [80's] . Original post says it is a monitor cable. a better pic of the logo. I would have to believe it to be original as Commodore would not have let someone hijack their logo on a molded plug. Edited August 22, 2011 by peedenmark7 Quote Link to comment Share on other sites More sharing options...
desiv Posted August 22, 2011 Share Posted August 22, 2011 I got the cables from a former commodore dealer [80's] . Original post says it is a monitor cable. Yep, looks original and from Commodore to me.. I'm pretty sure it was a 7800 thread on this site where someone was doing an s-video mod, but didn't include an RCA composite jack. He just said to combine the chroma/luma jacks together for standard composite, so this cable should work for a commodore monitor and/or composite.. Haven't tested that myself, just throwing it out there.. Now I just need to fix mine or buy a new C64 as mine apparently really likes the color black when I power it on.. ;-( desiv Quote Link to comment Share on other sites More sharing options...
+save2600 Posted August 22, 2011 Share Posted August 22, 2011 I'll take a chance on one. PM incoming! Quote Link to comment Share on other sites More sharing options...
jkonstan Posted August 22, 2011 Share Posted August 22, 2011 PM sent ... Quote Link to comment Share on other sites More sharing options...
bandit Posted August 22, 2011 Share Posted August 22, 2011 I have a few of those cables, there for the 64C and later c128. they give you the extra chroma you need. You can use 5 pin on them also for composit.. You can also use them on Sega model 1 / which you can also use 5 pin ones also. Quote Link to comment Share on other sites More sharing options...
desiv Posted August 22, 2011 Share Posted August 22, 2011 I have a few of those cables, there for the 64C and later c128. That's what I thought/read, but my (now broken) breadbin C64 has the 8-pin video. So at some point, they did the 8-pins on the old style C64s also. desiv Quote Link to comment Share on other sites More sharing options...
skosh Posted August 22, 2011 Share Posted August 22, 2011 PM sent. Quote Link to comment Share on other sites More sharing options...
peedenmark7 Posted August 23, 2011 Author Share Posted August 23, 2011 Guys... When you pay please enclose your full name and address [as paypal does not always include it in your payment info ] Along with your AA handle so I can keep track of who gets what thanks ! Quote Link to comment Share on other sites More sharing options...
+save2600 Posted August 23, 2011 Share Posted August 23, 2011 (edited) Guys... When you pay please enclose your full name and address [as paypal does not always include it in your payment info ] Along with your AA handle so I can keep track of who gets what thanks ! Received PP info and just paid, thanks! Edited August 23, 2011 by save2600 Quote Link to comment Share on other sites More sharing options...
carlsson Posted August 23, 2011 Share Posted August 23, 2011 Strange that they'd be yellow, red and white. Not so strange if you looked at the back side of a Commodore monitor and saw the inputs actually are colour coded red, white, yellow. Which is which is another matter, but these indeed should be S-Video cables for C64, C128 and C64/Plus4. Regarding old breadboxes having 5 or 8-pin DIN, all the ones I have seen had 8-pin DIN. I think only the very first C64, the Silver Label ones might have 5-pin DIN. The 8-pin horseshoe DIN connector is indeed worth its value on its own as other systems, e.g. Sega Master System and Megadrive/Genesis use the same connector but with completely different pinouts. Nowadays it is somewhat easy to find 8-pin C-shape connectors while the U-shape (horseshoe) is getting scarse at most electronics resellers. 1 Quote Link to comment Share on other sites More sharing options...
+save2600 Posted August 23, 2011 Share Posted August 23, 2011 Strange that they'd be yellow, red and white. Not so strange if you looked at the back side of a Commodore monitor and saw the inputs actually are colour coded red, white, yellow. You're right! Just took a look at the back of my 1702. Guess it's been too long since I did the reach-a-round and looked back there. Quote Link to comment Share on other sites More sharing options...
bigbee99 Posted August 23, 2011 Share Posted August 23, 2011 You could always just do a simple continuity test to see what pins the RCA's are connected to. The SG1, SMS, and Neo Geo all have the same pinouts, but they are different from the c64. At least the ground pin is the same. (Ignore the SCART stuff ) B Quote Link to comment Share on other sites More sharing options...
Neo Geo Posted August 23, 2011 Share Posted August 23, 2011 I thought these were RGB cables. My Commodore monitor only has RGB, one video, and one audio. Quote Link to comment Share on other sites More sharing options...
Chris Union NJ Posted August 23, 2011 Share Posted August 23, 2011 PM sent.. Quote Link to comment Share on other sites More sharing options...
peedenmark7 Posted September 9, 2011 Author Share Posted September 9, 2011 still have a a few left. Quote Link to comment Share on other sites More sharing options...
peedenmark7 Posted September 15, 2011 Author Share Posted September 15, 2011 8 left in the package, 6 left out of the package. Quote Link to comment Share on other sites More sharing options...
thgill Posted September 16, 2011 Share Posted September 16, 2011 These might be useful. PM sent. Quote Link to comment Share on other sites More sharing options...
Chris Union NJ Posted September 16, 2011 Share Posted September 16, 2011 I got mine on monday thanks peedenmark7.. Chris Quote Link to comment Share on other sites More sharing options...
thgill Posted September 22, 2011 Share Posted September 22, 2011 bump Anyone heard from the seller within the last week? I have sent him a couple messages with no response. Looks like he hasn't been on since the 16th. Quote Link to comment Share on other sites More sharing options...
